01-28-2021, 05:13 PM | #23 | |
Rep 3,703
And as he said he's breaking in a new turbo... |
01-28-2021, 09:11 PM | #24 |
Rep 463
Yeah, the turbo was installed approximately 500 miles ago, the oil was changed and I planned on changing it again around the 1000 mile mark. I haven't observed any weird smells or smoking so I don't think it's burning oil. When its on the lift tomorrow I'll take a closer look to insure there are no leaks I could have missed. But also, I've had gremlins before. Like the iDrive system completely freaking out and resetting one time about a month after I took delivery(only happened once and never again in 4 years). So that said, I def do not think its actually low on oil but instead a glitch in a sensor or dme.
Also, the reason why I am not just adding oil is because the warning isn't sustained. I know the warning will go away if I just cycle the ignition. So by adding oil I won't know if that's really "fixing" it as the warning will go away regardless. Last edited by M2OG; 01-28-2021 at 09:17 PM.. Reason: Edit: I reserve the right to be wrong |
01-28-2021, 11:06 PM | #25 |
Rep 3,703
I’m still placing my bet on the oil is right at the minimum level (whether not enough was added, or there is a larger engine issue related to the needed turbo replacement) and it triggers the add oil message every now and then.
That message going on & off isn’t uncommon for guys that track their cars and get some oil burn, and I doubt it’s related to the one time full iDrive freak out you had 4 years ago. Let us know how it goes at the shop. |
01-29-2021, 01:30 AM | #26 |
Rep 463
I wasn't implying its at all related to the iDrive freakout. Im just illustrating that BMW puts shit electronics in their cars and as such, I've experienced gremlins throughout owning this vehicle and other BMWs.
01-29-2021, 09:40 AM | #27 |
Rep 350
The other argument against it really being low on oil, the original poster says after it happened the first time and he reset things, let the engine run until he was able to run the full engine oil level check through iDrive and it said it was at the ideal level. If the oil was a low level then that check should have shown the oil as on the lower end of the range.
01-29-2021, 10:24 AM | #28 | |
Rep 3,703
Based on my experience this situation is being overblown and overthought, but let’s see what the OP finds. There may be more to this story. |
RollingInDubs17.50 |
01-30-2021, 03:25 PM | #29 |
Rep 463
Tiny update. I didn't change/measure the oil as I didn't have time but it's now been several days and the message hasn't returned.
My strong suspicion is can bus weirdness. I'm realizing that my flex fuel sensor being wired to the cig lighter for power is causing some weird sleep issues. I suspect it's all related. I'm going to find a new power source for that and see how things flush out |
02-02-2021, 04:39 PM | #30 |
383
Rep 731
Chaecking oil level
Oil drains from the Oil Filter Housing to the Crank Case. The Oil Filter Housing is on a slight angle, the only oil you will see here is in that slight divet at the bottom of the Housing that can't drain to Crank Case. Anyone who thinks they can "Check the Oil Level" there doesn't know what their talking about.
At a Point above 7,000 RPM.
02-02-2021, 07:44 PM | #31 | |
Rep 3,844
02-20-2021, 04:41 AM | #32 | |
Rep 2,882
