07-16-2022, 06:51 PM | #1145 |
3035
Rep 13,778
Aware of the issues. I've had little issue
~loud noises~
07-18-2022, 05:27 PM | #1146 |
Rep 56
Took the car to my detail guy (Detail Boss) and had the following done:
1) Remove my wheels and performed a thorough cleaning of my wheels which included removing all glue from old weights, etc. and serious detail of the calipers front and back. 2) Actually my wheels had some funky like glue residue on a few of them so they went one step further and polished my wheels 3) Then coat them with Ceramic Pro. Came out amazing and my calipers look so much more red now.
2020 M4 CS - Black Sapphire Metallic
07-29-2022, 04:22 PM | #1147 |
3035
Rep 13,778
Getting super excited! My M235iR trunk has finally reached the LA distro hub. It took nearly 3 months for IND to secure one and paint it for me so can't wait to slap that on with my massive APM GT4 wing on there.
~loud noises~
sdhotwn2128.50 |
07-30-2022, 03:08 PM | #1148 | |
Rep 135
Drives: 2020 M2 CS
Haven't done the fronts yet, waiting to do my HAS's also this week.
2011 135i M-Sport Cabrio (DCT, Black Saphire, Coral Red, Seibon Carbon 1M body, FBO Stage 2+)
2020 M2 CS Manual (6MT, Hockenheim Silver, GLD 763M) |
JPMD171.00 |
07-30-2022, 03:12 PM | #1149 | |
Rep 135
Drives: 2020 M2 CS
Speaking of which, I really want the CSR wing and carbon door inserts.
07-30-2022, 06:17 PM | #1151 | |
Rep 135
Drives: 2020 M2 CS
Plus I don't really need more downforce for a once in a while track car at the cost of drag. I'm asking IND if they can paint match the side stands along with the gloss carbon airfoil, I think will look sharp.
07-30-2022, 06:30 PM | #1152 | ||
3035
Rep 13,778
~loud noises~
08-01-2022, 07:57 PM | #1153 |
3035
Rep 13,778
~loud noises~
8
RideM317.00 Jimjamz4599.50 tunawi7cheese219.00 chris7197374.00 aka_m8rty34.50 inTgr8r2434.50 prompt292.00 ///MPhatic14102.00 |
08-07-2022, 04:31 PM | #1154 |
Rep 692
Just installed the Mosselman oil thermostat. Oil temp def lower and looks awesome.
Vic
08-12-2022, 01:20 PM | #1155 |
3035
Rep 13,778
Eventuri CF chargepipes are in. Now working on brake ducts....I'm in too deep, but I should have just paid someone to do it for me. lol
~loud noises~
08-13-2022, 05:47 PM | #1156 |
Rep 577
How do you have all of this but not the simple cover?!
Instagram: @MinionM3
Current Garage: 2012 M3 ZCP, Mineral White, DCT: Track Build 2020 M2CS, Misano Blue, 6MT |
08-13-2022, 05:57 PM | #1157 |
3035
Rep 13,778
Honestly not a fan of that cover. I figured that part of the intercooler is meant to expel heat, and adding a metal piece on top just, to me, looks to help retain heat. I could be entirely wrong.
~loud noises~
08-14-2022, 04:57 PM | #1158 |
Rep 892
Drives: F87 M2CS
No you're correct. That's where all the coolant is flowing to cool the air rushing across it from the charge pipes into the j pipe down below. Idk how much of a difference it will make though but it being black plate obviously will retain a bit more heat.
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
MinionM3493.50 |
08-16-2022, 07:27 PM | #1159 |
Rep 4,714
Added the Akrapovic evolution system.
RideM317.00 Jimjamz4599.50 JPMD171.00 jessief29812440.00 tunawi7cheese219.00 ashmostro1254.00 aka_m8rty34.50 |
08-19-2022, 07:22 AM | #1161 |
Rep 413
08-19-2022, 01:33 PM | #1162 |
3035
Rep 13,778
I'm not sure. I don't recall the thread I was reading about opening up these ducts. I had these sitting on the shelf for months but hadn't had the time to get to these until yesterday. But I'm sure I lost value in my car doing this.
~loud noises~
LammaLamma18.00 |
08-19-2022, 04:59 PM | #1163 |
3035
Rep 13,778
From some guy who messaged me on IG that makes these carbon knobs for the CAE.
I'm glad he didn't run off with my money.
~loud noises~
08-20-2022, 05:15 PM | #1164 |
Rep 4,088
That looks incredible. What shifter mechanism is that?
I have cobbled together the below which I really like the feel of, particularly on the track. The knob assembly is from Black Forest Industries, the boot is factory OEM with the original knob snapped off the boot collar, and the spacer in between them is a part I 3D-printed. Most recent significant mods is converting every suspension arm or bushing to SPL pillow ball / adjustable bits (front lower camber, T-C, tie rod ends; rear trailing, toe, upper camber). The track performance and street handling is immensely improved from the new alignment, as well as the reduced deflection. NVH only went up slightly, and really only on the sharp impacts. Normal suspension movements produce no more sound than stock. This was one of my goals, as I have found camber plates to always introduce more NVH than I like no matter what the bearing design. Last edited by ashmostro; 08-21-2022 at 08:37 PM.. |
krm347.00 tunawi7cheese219.00 |
08-31-2022, 01:41 PM | #1165 |
3035
Rep 13,778
~loud noises~
