07-01-2023, 06:51 PM | #1 |
Rep 2
Will an M2C Leather Steering Wheel Work on an M2CS?
Can anyone confirm if I'm able to replace my OE BMW M2CS Alcantara steering wheel, with a heated M2 Competition’s black leather steering wheel? I’m not a fan of the Alcantara CS steering wheel, but I'll keep it in storage. I'd prefer the smaller grip and feel from the black leather M2C steering wheel.
I’m concerned that since the M2CS is not wired for a heated steering wheel, this replacement heated M2C steering wheel may possiblysend a fault code in the electronic system or cause other problems? I’d appreciate it if any experienced M2C or M2 CS owner who may have already done this swap can confirm if this modification will work without any negative issues due to being wired for heating? Thank you! |
07-02-2023, 12:10 PM | #2 |
Rep 4,088
Won't cause any issues. If you had a car with the feature and then removed the heated wheel, then you may have to do some coding but in your case the connector just won't be used.
07-03-2023, 05:33 PM | #4 |
Rep 2
Thank you ashmostro for your positive and thorough explanation and to M3R1 for supplying your photographic confirmation that you've already performed this exchange for a full leather wheel. I was hoping that the the only difference is that the wiring for heating function would not be connected! That's such good news, so thanks guys!
ashmostro1254.00 |
07-03-2023, 07:31 PM | #5 | |
Rep 2,366
BSM ///M2cs, 6spd
07-06-2023, 02:00 PM | #6 |
Rep 10
I have a question. All the M2CS units have the Alcantara steering wheel? Because I saw two without it. What does it mean? The steering wheel was replaced or that it is actually an optional?
07-06-2023, 03:14 PM | #7 |
Rep 2,366
Replaced... It is a very easy swap.
BSM ///M2cs, 6spd
07-08-2023, 10:10 AM | #8 |
Rep 10
After some research, I’ve found that In Europe it’s actually possible to find some CS with an OEM leather steering wheel. It’s not like the one of the Competition models. It’s thicker, but it looks exactly the same.
08-03-2023, 10:46 PM | #9 |
Rep 488
Drives: M2CS
I actually don't like this thick steering wheel.
It's too thick. What other options are out there? |
08-06-2023, 11:26 AM | #10 |
Rep 1,232
Drives: BMW F87 M2 CS (6MT)
Every M2 CS came with an alcantara steering wheel from the factory.
Sometimes, the simplest recipes, done well, with quality ingredients, are the tastiest, - evo Car of the Year 2020
2020 BMW F87 M2 CS - 6MT - Misano Blue Metallic |
08-08-2023, 10:56 AM | #12 |
Rep 116
Drives: 2020 M2 CS
08-08-2023, 12:30 PM | #13 |
Rep 1,232
