12-06-2020, 08:49 AM | #287 |
Rep 618
I can wait 6 weeks I guess. I also have the UCP ready to go! I already swapped the E9x slave cylinder (CDV delete) and it was a marked improvement. I hope the UCP and SSK are equally transformative.
12-10-2020, 03:00 AM | #288 |
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
182
Rep 302
Can you please elaborate on the CDV delete with part number and how it improved the drive?
12-10-2020, 08:37 AM | #289 | |
Rep 618
The clutch stop takes away a good amount of dead space between fully depressed and the engagement point. Mfg Part #21526785964 https://www.ecstuning.com/b-genuine-...r/21526785964/ |
n8dgr84182.00 |
12-15-2020, 10:16 AM | #290 |
Rep 15
UCP is really good
I have the SSK on the way. I did just install the UCP. I put in middle position and only the smaller inner spring. Its a must do, the stock clutch throw is horrible...its like a leg press its so long. I added the clutch stop and that helped but you still have to pick you leg up too high and its not in line with the brake. Horrible design in a car at this price. Shifts are smoother now. Once my SSK gets here and I remove the CDV I will be where I want to be with the transmission.
Gizmo 335i376.50 n8dgr84182.00 |
12-19-2020, 11:55 AM | #291 |
383
Rep 731
Don't understand all the talk of long clutch throw with this car. I never throw my clutch all the way in when shifting. I know exactly how far to throw it just from rote. In three years of ownership have never heard any gears grinding.
At a Point above 7,000 RPM.
12-20-2020, 07:55 AM | #293 |
Rep 13
First, I would like to thank members' opinions here.
I installed my UCP a few days ago and I used the stopper which was provided with the product. I chose the setup which was recommended here: stock location without removing any springs, immediately I noticed it’s a good solid item, but I didn’t like the fact that: 1. After pressing the clutch, it did not return back fast enough as the OEM. 2. The travel was almost the same as my original pedal with a custom 10mm stopper that I made, the UCP felt that the actual engagement was to far at my M2C, So I ended up adding 7mm plastic washer to the original stopper, I made sure that I still have enough travel much before the engagement point, so It will not cause gear issues at the future. That thing made huge improvement, now the clutch travel is short and it doesn’t bother me that it’s not returning back fast, second I ordered a CVD and may be the slower clutch return will actually work to my advantage. Now I can say it’s a wonderful mod ! As for the SSK, it's on the way with 70A.. |
12-24-2020, 04:01 PM | #294 |
Monkey
119
Rep 241
Just installed mine. The shifting is so precise now and there's no slop.
I actually didn't take off the prop shaft and was able to wiggle the shifter on and off. YMMV but seems to work fine for me. |
12-25-2020, 09:21 PM | #295 |
Rep 244
Drives: 2018 M2 Alpine White
Got my SSK installed and also did the UCP. Amazing transformation! The clutch pedal is sooo much better. The way it should be. I'm using the stock setting. It's hard to imagine the sport or race setting because this engages the gears so smooth. Shifts in the SSK are really tight and almost zero slop. I don't mind the slight notch. Occasionally engaging 1st and 4th need a little more effort, but there's give and take with any shift mechanisms. The improvements are immediately felt. Almost wish i could have enjoyed the shifter without the new pedal first because the pedal really is the best mod I've ever installed in a BMW. It's that much better. No regerts!
12-31-2020, 01:59 PM | #296 |
Rep 119
Got my AutoSolutions shifter installed, picked it up today. AMAZING transformation. Love it. Definitely do this if you're thinking about it.
02-13-2021, 05:44 PM | #297 |
Rep 71
So I find myself in a weird (and quite possibly dumbest) dilemma. My new to me M2C has a UUC SSK installed, which I was all for since the stock shifter feels like a rubbery mess. The UUC feels WAY better than stock, but has a couple of major issues:
Firstly, the dingus who installed it must've not paid much attention to the very clear instructions and the ssk is in BACKWARDS. This leaves the shifter sitting high and to the right when in neutral and it drives me crazy just looking at it, not to mention any harm it may be doing to the transmission. The shift knob is also canted and not pointing straight, which may or may not be a side effect of the idiotic install. Secondly, its LOUD AF in all aspects. The NVH is pretty unbearable as it makes a whirring noise at higher RPMs and clanking noise when shifting into a gate. I've read some responses that the AS kit also has issues with the OE shifter, but I didn't know if people found the whirring/clanking so intrusive that they absolutely needed to go with another shift knob. Since my shop will need to get in there and go through 90% of the original install process to rotate the UUC ssk, I figured it may be worthwhile to swap it out entirely to AS kit. I spoke to Ronald who mentioned that he hasn't heard of any noise complaints for those who have selected 80a bushings and OE shifter, which gives me some confidence that a complete overhaul will be worth it. I'd also be going with a 25% reduction and stock height since the effort of the UUC was just fine (he estimated that UUC's reduction is about 25% as well). Anything I should be on the lookout for in terms of noise with the AS kit? Or has anyone had any time toying with the UUC ssk and can compare to the AS kit?
02-13-2021, 08:49 PM | #298 |
Remove Before Flight
6908
Rep 1,616
I really like my AS SSK. 74a bushings and a 20% reduction.
No noise that I can hear, but I've admittedly got a lot of high-frequency hearing loss due to over 30 years around jets. R.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
AKD75.50 |
02-14-2021, 03:59 AM | #299 |
Rep 8,972
I have AS kit with the hardest bushings (only option at time of purchase) and had bad noise until I fitted a heavy raceseng knob.
Around this time Ronald introduced softer bushing options, maybe why he did this. |
02-14-2021, 11:26 AM | #300 |
Rep 71
I'm assuming these were 95a bushings?
02-14-2021, 02:08 PM | #301 |
Monkey
119
Rep 241
I had a noise with the OEM shift knob until I put some athletic tape in the lock slot. I think the clearance of the shift knob and the clearance of the shift knob lock is slightly off so it vibrates at high rpms.
Otherwise it's been the best purchase for my M2 |
AKD75.50 |
02-15-2021, 12:43 PM | #302 | |
Rep 309
Drives: 2018 M2 LBB - 6MT
AKD75.50 |
02-15-2021, 01:38 PM | #303 | |
Rep 1,263
Since they're simply pushed down on the shift rod. My experience with Raceseng knobs has had zero NVH. My wifes OEM 2014 335 6 spd knob vibrates if you rest your hand on it.
AKD75.50 |
02-20-2021, 06:14 PM | #305 |
182
Rep 302
Just installed the UCP!
I am using it with the small spring only and no overcenter spring. Clutch engagement is nice and easy ; low and less tiring. |
02-22-2021, 09:47 AM | #306 |
Rep 40
I just installed mine on my 20 m2c and I can confirm that you can get around this without removing the prop shaft, you will have to lower the transmission like and inch and the once you unclip the selector rod from the shift lever it'll wiggle right out, to put the new one you will have to wiggle the shift arm alone and bolt it on, and from inside the car you will have to install the shift lever (tightening those 6 allen bolts WILL be a pita).
03-22-2021, 01:41 PM | #307 |
Rep 13
SSK experience
I installed the SSK 22.5% + 70a bushings, few days ago.It shifted my driving experience to a different level:
1 The gear change is so fast now that there is no annoying leg/hesitation time between first to second gear. 2 The tight tolerance reminds me of the H Ferrari old gears, it is so much fun and such an engaging experience. 3 Ronald is an amazing person- customizing the shipter to my driving needs and excellent communication until the product was installed. |
Kattanah139.00 |
05-04-2021, 11:49 PM | #308 |
Rep 71
Finally had my 25% 85a installed this morning and...just wow. It's so precise and has absolutely zero slop. The gates are so well defined and the throws feel so much more mechanical. Hands down the most satisfying mod I've ever done. Ronald is the man.
Here's a comparison to the craptastic UUC shifter. Not only was it misaligned and sloppy, but it made a terrible noise whirring noise since the shift nob wouldn't sit completely flush. Didn't matter how hare you pushed it down. None of these issue plague the AS kit. UUC SSK: https://1drv.ms/v/s!ArSMX3P4c2vlhPNm...JP97g?e=Yja2hF AS SSK: https://1drv.ms/v/s!ArSMX3P4c2vlhPVhnv9fDeLGNAdmRQ
