BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos > I created a vacuum cleaner attachment to help with car detailing
      02-27-2020, 04:17 PM   #1
Vulcan50
Vulcan50's Avatar
433
Drives: e92 335i
I added the M3 gauge rings to my car an in doing so got some dust and lint in there. Every time I wipe up a fiber another is left behind.
So, I was brainstorming and thought about the little dental suction device. Obviously that's unrealistic ($$$) so I kinda forgot about it.
But later, I came up with something. I found a small vinyl tube - 1/8" id and 3/16" od. I then got a brass barb fitting with an id the same as the tube. I had to heat the tube to get it over the barb. I did this so I didn't have a bottle neck at the fitting. Then, I threaded it into a 2" pvc cap (pick the size that fits your vacuum). I chose to make a gasket with some rubber sheet that goes in the cap, sealing the cap to the hose. The suction holds it in place.
clee1982796.00
      02-27-2020, 05:22 PM   #2
Emilime75
Drives: 2010 335i E92 LeMans Blue
...and then?
      02-27-2020, 05:27 PM   #3
TboneS54
YNWA
TboneS54's Avatar
Drives: 2004 M3 6spd & 2011 M3 DCT
Use a MF cloth that doesn't have lint?
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      02-27-2020, 07:33 PM   #4
N54Yankee
N54Yankee's Avatar
Drives: N54 135|Cobb|M3 control arms
Necessity is the mother of invention. Red Neck engineering at its finest. Well done
"The Constitution was never construed to authorize Congress to infringe the just liberty of the press, or the rights of conscience; or to prevent the people of the United States, who are peaceable citizens, from keeping their own arms.” Samuel Adams
      02-27-2020, 08:47 PM   #5
Vulcan50
Vulcan50's Avatar
433
Drives: e92 335i
Originally Posted by Emilime75 View Post
...and then?
I vacuum the fibers and dust out.
There's lint/fiber that I can't reach as well.
      02-27-2020, 09:18 PM   #6
BzsBimmer
BzsBimmer's Avatar
3235
Drives: '23 G80 FO M3, M3 & MY Tezzy's
Use a thin plastic stick and grab it via static or adhesive
Either way, as long as your method worked... you get an atta boy
clee1982796.00
Vulcan50432.50
