BMW M2 Forum > BMW M2 CS Model > M2 CS 6spd vs M2C 6spd and M2C DCT driven and compared
      09-08-2021, 12:12 AM   #67
Piets94
Piets94's Avatar
677
Drives: 94 M3, AW 1M, M2 CS
Originally Posted by chris719 View Post
I am willing to give the benefit of the doubt to software controlled components like the steering, diff, engine, and DCT since they are close to black boxes. They also have an established track record of being able to have their character changed significantly with software-only changes.
Exactly. These identical hardware components have been fine-tuned to give the driver the experience that many owners and magazines describe. I'm sure if you could load these software changes into a C you'd be close enough to the raw driving feel of a CS. Add in the adaptive dampers and tuning for these, nicer interior materials, expensive carbon exterior panels and trim and you'd have your CS - except it would still be a C at resale time.
Closer to the OP topic, I look forward to driving a manual C or CS to be able to compare more one day, but the DCT in the CS is very 'engaging', and satisfying to punt hard or cruise.
chris7197334.00
      09-08-2021, 02:39 AM   #68
Jimjamz
Jimjamz's Avatar
4583
Drives: G81 M3 Touring (Frozen Black)
For example, I do not consider the roof a plausible explanation for 6MT shift quality differences when the engine and transmission are mounted with soft rubber to a chassis that is already stiff and already has a roof..
I've never read anyone saying the roof improves the 6MT shifting experience. That's a new one
      09-08-2021, 08:52 AM   #69
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
Pretty sure they used special blinker fluid in my M2 CS. It should last the life of the car. My blinkers are so much smoother and more quiet than the blinkers in my M2C
This also enables me to enjoy the shifter experience more as I'm shifting without the additional noise from the blinkers with the old fluid.
Maybe it's just me but me thinks that makes a big difference when comparing the C to the CS.
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy)
Appreciate 5
Megator517.50
smknjoe234.00
Davil6524.50
Jimjamz4583.00
mathys202.50
      09-08-2021, 04:54 PM   #70
300f87
300f87's Avatar
51
I am willing to give the benefit of the doubt to software controlled components like the steering, diff, engine, and DCT since they are close to black boxes. They also have an established track record of being able to have their character changed significantly with software-only changes. Where we have evidence of identical parts I am far more skeptical. Not dismissing it off-hand, but would prefer to entertain plausible explanations.
Not trying to side with anyone here, but I wanted to point out that in the recent iSTEP (F020-21-03-545), we have:
1. Three different GHAS settings (DSS TASC / DSS IPM):
  • F087 = Base (OG)
  • F087CP = Competition
  • F087CS = CS
2. Three different MDM settings:
  • F87 = Base (OG)
  • F87_CP = Competition
  • F87_CS = CS
3. Two different EPS settings :
  • F87 = Base (OG)
  • F87CS = Competition/CS
So, it seems like different software settings for GHAS/MDM is a contributing factor. I have the CS GHAS/MDM/EPS settings coded for my OG, and I felt significant difference in steering/handing characteristics. I am not sure about available coding options for DCT, as I have a manual transmission.
More information can be found here:
https://f87.bimmerpost.com/forums/sh....php?t=1605090
chris7197334.00
smknjoe234.00
      09-08-2021, 05:04 PM   #71
chris719
Drives: '08 M Roadster
  • F087 = Base (OG)
  • F087CS = CS
  • F87 = Base (OG)
  • F87_CS = CS
  • F87 = Base (OG)
Yep, there are DCT options also. It's been known for a while as you mentioned. I also wonder if those settings do different things with 2021 ISTEP. I thought there were 3 EPS settings?
      09-08-2021, 07:02 PM   #72
300f87
300f87's Avatar
51
F87CS MDM setting was not available in the older iSTEP versions, while F87CS EPS and GHAS settings were.
I was hoping for 3 EPS settings in the new iSTEP (with an additional unique setting for CS, so I could experiment), but there are only 2 settings for F87 (F87 for OG and F87CS for M2C/CS). See the last photo attached above for all available options. A lot of people have used F82GTS steering on F87 as an additional option.
Megator517.50
      09-09-2021, 01:49 AM   #73
Megator
Megator's Avatar
518
Drives: M2 Competition
I have the GTS EPS, MDM, and Diff coded
The first 2 I don't really notice. Steering is a bit heavier but it's hard to say it has more feel.
I never use MDM, on the street it's full traction because these cars like oversteering at any moment lol.
On track I run DSC off so no difference.
The diff made a huge difference, it locks way sooner and harder now making it great to put the power down out of a corner but more likely to do a fat drift if you lack throttle control.
Might try the CS steering.
chris7197334.00
      09-09-2021, 03:35 PM   #74
Jimjamz
Jimjamz's Avatar
4583
I think you're onto something. I've had a suspicion the extra weight of the 'CS' badge on the rear right side perfectly offsets a minor left-side weight imbalance caused by the battery location. This adds to the perfect left-right 50:50 weight distribution of the F87 CS which makes it the best car in the world of all time.
FaRKle!4017.00
      09-10-2021, 01:41 AM   #75
buckybadger
BMW forever!
buckybadger's Avatar
Drives: BMW
Originally Posted by 6CylindersEveryDay View Post
Pretty much every enthusiast with enough money to buy a CS is well aware of modified cars and probably has purchased plenty of mods for cars in the past. At this phase in my life I don't want to rip apart their car and shred the warranty in the process. I don't want to spend a bunch of time and money trying to get the suspension components dialed in to have great performance but also be comfortable on public road surfaces. If my only option was the M2C I would have purchased a Cayman GTS 4.0 or possibly Cadillac Blackwing instead.
Most M2C owners don't have Cayman GTS money though
Not true, I have an X5, M2C and looking to buy the M3C. I could also get a Porsche but that's not on my radar.
Some of us get cars we like!
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
chris7197334.00
      09-10-2021, 02:38 AM   #76
chris719
I hope to drive a CS soon to see how it is. I have to say, I hope it’s lighter than the other F8x steering.
My Z4M had much more honest steering than any E9x or F8x I’ve driven, and without being overly heavy. I used to complain about E9x (non M) having artificially heavy steering, and to my disappointment, BMW seems to have kept the weight only as if they believed weight == feedback. I almost exclusively use Comfort on the M2C as do most of the instructors in Spartanburg.
Ultimately, it’s not a big issue with the car as a daily driver. As a track tool I’m not sure. I suggest people that think any BMW after E46 has good steering feel drive a Porsche 997 or 997.2 911. Those racks make the Z4M feel mediocre. Closer to E36 levels of feedback.
Time marches on, so I’m not expecting anything new to steer like a car from 1996. Still, it would be nice for BMW to stop pretending that more effort means better. I blame journalists for this.
      09-10-2021, 06:18 AM   #77
M3R1
Drives: ///M2cs
Coming from an E92 M3 and having had 2 E46 M3's as well as a few built N54 cars, I would agree with every review out there that the EPS has lost much of the feedback that the hydraulic steering provides. As a street only car, at this stage in my life I prefer the EPS over hydraulic. I know 95% of you are thinking i am crazy, however as I get older what i want out of a car has changed. I leave my steering in comfort all the time, sport and sport+ are too heavy.
BSM ///M2cs, 6spd
chris7197334.00
      09-10-2021, 06:37 AM   #78
Jimjamz
Jimjamz's Avatar
4583
I always drove comfort steering in my f80 for 6 years and 70,000 km - the others were unusable for me. The F87 CS feels very different to the point that 2-3 weeks ago I shifted my steering default setting to sport.
chris7197334.00
      09-10-2021, 07:08 AM   #79
M3R1
Drives: ///M2cs
Sport is not terrible, just a little too heavy for me. I will say sport suspension is also not terrible, however comfort is just right for me.
The car is spectacular with everything in comfort.
BSM ///M2cs, 6spd
      09-10-2021, 08:47 AM   #80
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
It's the programming, not the EPS itself. My 2004 RX8 has EPS. If you drove it you wouldn't know if I hadn't told you.
      09-10-2021, 10:04 AM   #81
fleetfoot
fleetfoot's Avatar
Drives: 2017 M2, 2013 E92 328i
Yep. Drive a brz with eps. The steering feel and feedback is phenomenal. Bad eps is just a tuning problem (or choice) in my opinion.
But I've done more research on steering feel this year, and it can also be greatly affected by car weight, tire width, and suspension geometry. The BRZ weighs 700lbs less than the M2, has 30mm narrower front tires, and potentially has better suspension geometry from the lower center of gravity.
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9"
chris7197334.00
      09-10-2021, 10:04 AM   #82
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
Same. Comfort steering, suspension and Sport Plus Throttle for the most part. Maybe Sport if the roads are really curvy. Too much of a sensitive throttle isn't always a good thing.
For what it's worth. I track my CSR in rain mode and so do many other pro race teams. Who needs the extra wear and tear on the trans from slightly faster / more aggressive shifts?
Also rain mode makes shifting in the turns a breeze. Sorry a little off topic.
M3R12168.50
chris7197334.00
smknjoe234.00
      09-10-2021, 10:15 PM   #83
Davil
Davil's Avatar
6525
I switch between my M2CS and Z3 each time I drive. As many probably know the Z3 is known to have the best e36 steering with the quick rack and it was a popular mod to replace the stock rack in e30s and other e36 models. I also had all the front bushings replaced in the Z3 to bring it back to its original feel.
So. As I alternate just about every drive I get to experience the differences all the time.
If you distill it to one sentence. The Z3 feels organic and M2CS feels manic.
With the CS (I have Cup2) you can actually feel the surface of the road. It tramlines more. Turns in much faster and is probably far more irritating to the non enthusiast driver. But I love this. This I feel is the main difference to the C. The C has more of a comfort bias built in to appeal to more people and to make it less nervous. It still points well all the same.
I use sport in the CS. Steering weight is about the same in both cars. Neither are the overly light one finger steering Americans seem to love. They are just right for me.
I love them both. Very different experiences but both very therapeutic. That's what I want most from cars. Numbers don't matter to me. I just need them to make me feel good.
Jimjamz4583.00
      09-13-2021, 09:21 PM   #84
sdhotwn
Mmmm... Bavarian
sdhotwn's Avatar
2129
Drives: M2 CS, X5 45e, i3, Cayman S
Spending a lot of time in the M2 comp today and tomorrow with the M Advanced school. Then more time with my CS this weekend on track as well. Will be interesting I continue to compare and contrast them but the difference between in steering is so immediately obvious and different it is pretty amazing.
And on a side note, damn is the G80 impressive to drive.
M2 CS
2023 CB X5 45e
2018 i3 94
2014 Cayman S
      09-14-2021, 01:17 AM   #85
buckybadger
BMW forever!
Drives: BMW
Do you think the G80 is better than the M2C or CS?
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      09-14-2021, 04:09 AM   #86
Jimjamz
Jimjamz's Avatar
4583
They seem to be very different cars. To the point we're aiming to get a G81 to replace our G02 X4 end of next year - it will be the garage buddy for the F87 CS not a replacement for it. I wonder if many will cross-shop them?
      09-14-2021, 06:49 AM   #87
Davil
Davil's Avatar
6525
I stepped out of one after an extended test drive and into the other (my CS).
The answer is… it depends.
G82 is supremely confident. F87CS is supremely entertaining.
What floats your boat? I'm in the raw feeling entertainment camp. Others may not be and I get that. Depends what type of boat you want to float. G82 feels like a floating spaceship from another dimension. Pretty amazing really. F87CS feels like a car from at least 10 years earlier but still just as quick even though it requires a lot more participation. Much more sensation of speed and connection in CS. Effortless speed in g82 and you have no idea how fast you are going. What are you after? That decides your choice.
      09-14-2021, 09:08 AM   #88
sdhotwn
Mmmm... Bavarian
sdhotwn's Avatar
2129
Like the others said it's different. It drives much smaller than I expected. The steering is better than the M2C, but not as good as the CS. The transmission is both more refined and more sharp than the DCT in the M2C. The engine sounds fabulous, or whatever they've done with the active sound seems to work at least. The rear axle steers nicely with power, and man there is a lot of power! It feels faster a lot of the time even than the M5 Competitions we are hopping in and out of. If you gave me a choice at class to put down a confident fast lap between the G80, the M2C, and the M5C, it'd be an easy pick of the G80.
M2 CS
2023 CB X5 45e
2018 i3 94
2014 Cayman S
robopp1680.50
Tags
6spd, gold 763m wheels, m2cs
