M2 Technical Topics > Track / Autocross / Dragstrip > Aim brake data
      04-06-2021, 03:01 PM   #1
juicy
juicy's Avatar
Drives: F80 M3, F87 M2
Aim brake data
Which channel do you guys use for brake. I have throttle data only. Don't know which channel to select for brake.
In the pic, I'm braking as u can see from the g force but the brake indicator is zero
      04-06-2021, 03:18 PM   #2
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
I dont recall offhand, and dont have any of my data files available. But I believe there is a brake pedal position % that I used.
Motorcity BMWCCA Member
Instagram | YouTube
      04-06-2021, 03:34 PM   #3
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
I just checked one of my old data files, it looks like I probably used "Brake_P_F" and/or "Brake_P_R". That should correspond to brake pressure front/rear.
Instagram | YouTube
juicy81.50
      04-06-2021, 06:30 PM   #4
dvas
dvas's Avatar
518
Do you connect the AIM through the OBDII or directly into the ECU? I connect through the OBDII and cannot for the life of me get brake or steering data or accurate throttle position data. None of my local BMW club data gurus seem to be able to figure it out either.
      04-06-2021, 07:38 PM   #5
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Yeah, I go direct to can bus, and this is exactly why I went that route
You get more data that way. I have all of those data points available to me. Feel free to check my YouTube, I have a few videos up there with data from my aim/gopro setup.
It's a bit tougher to get setup, and you'll certainly need some help if you're not comfortable with electronics, but it was worth it for me.
Instagram | YouTube
dvas518.00
      04-06-2021, 09:26 PM   #6
dvas
dvas's Avatar
518
Thanks for the reply. I'll take a look at your vids and, if you don't mind, reach out if I have any questions.
I initially hesitated to hardwire my AIM as I though the M2 was going to be a street/track car. But over the last year or two, I have barely driven it on the street and don't even take out my track stuff anymore. Hell, it's had Hoosiers on it since November - even took it to the dealer for an oil change with Hoosiers and brake ducts, haha. The mechanic's video was interesting...
      04-06-2021, 09:47 PM   #7
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Absolutely. Would be happy to help.
There are a couple caveats in hard wiring, that may be fixed in newer revisions. But I had issues with my aim unit pulling power from the canbus when the car was off.
This caused a warning to come up in idrive when I turned the cwr back on.
I made a small box that disconnects the canbus wires when the car is shut off via a relay.
Instagram | YouTube
      04-06-2021, 10:05 PM   #8
dvas
dvas's Avatar
518
Thanks. The youtube link in your signature appears to be broken.
      04-06-2021, 11:26 PM   #9
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Thanks for the heads up. Tried to fix it on my phone which apparently deleted it. Lol
Will fix tomorrow when I'm on my computer.
https://www.youtube.com/c/DetroitM2Official
Instagram | YouTube
      05-23-2021, 08:02 PM   #10
m4forum
Drives: M3
Hi DM2 could you share the diagram for the relay to disconnect canbus?
      05-23-2021, 08:58 PM   #11
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
I just sketched it out by hand when I built mine. I may have a crude drawing somewhere. I'll check my computer tomorrow.
If not, I can throw together a drawing real quick. It's a pretty simple circuit.
Here's a couple photos of the latest version I did on a prototype board. One of the outbound connectors is direct, the other is switched through the relays. I have my Zeitronix ECA-2 plugged into the direct, and the aim unit into the other. I designed and 3d printed an enclosure for it.
Instagram | YouTube
