03-09-2021, 09:37 AM | #1 |
M2 Pilot
138
Rep 165
OG Shark: Dude, we've gotta talk. Those are supposed to be blue.
Me: Blue calipers are for people who don't track. OG Shark: No, dark blue calipers are for people who track. Yours are black. ———————— I think I really over-cooked them. Was running RSL29 pads, 3.5 days old, on stock rotors. Castrol SRF fluid. Maybe my braking technique really sucks. Pads had 35-40% left going into Saturday, failed Sunday second session going into turn 19 a little over 90 mph. Lesson learned on misjudging pad life. Going to AP BBK, and will work on technique. Other thoughts?
America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt
'17 BMW M2 |
03-09-2021, 09:47 AM | #2 | |
M2 Pilot
138
Rep 165
'17 BMW M2 |
03-09-2021, 10:09 AM | #3 | |
Rep 2,526
Anyways, nice job on the brakes, welcome to the club |
CrashFL137.50 |
03-09-2021, 10:20 AM | #4 |
Rep 340
First off... yikes! Your phew at the end says it.
Everything came out ok, yeah? T19 is a scary place to go off like that, but it looked like you went into the trap relatively straight. What was going on Sunday? COTA seems to be ok on brakes and T19 seems like an odd place for them to fail, but I guess it could happen anywhere. I'd expect them to be hottest somewhere between T12 and T15. I think you may be correct in your assumption of misjudging pad life for a weekend. Essex has a good writeup on pad life on their site (See: Predicting pad wear rates and Inspecting pads for wear). If it's in the budget, AP is surely the way to go. If you want to get crafty and experiment, I've seen some interesting brake cooling options coming around lately. |
CrashFL137.50 |
03-09-2021, 11:05 AM | #5 | |
M2 Pilot
138
Rep 165
This was at Chin track days. I usually get some brake fade around t15, but they've recovered by 19. First thought: no brakes. Second thought: has the wall always been so close? Thanks for the links!
'17 BMW M2 |
03-09-2021, 02:01 PM | #6 | ||
Rep 2,526
CrashFL137.50 |
03-09-2021, 02:26 PM | #7 |
4693
Rep 2,542
Oh CrashFL - nice humble brag about being fast enough to kill the oems
The pads actually weren't awful - think they just went below the thickness threshold to be able to dissipate enough heat at that time in relation to what he was running. And he has been beating on these poor things mercilessly. I've seen the funky off-blue (the rears on his car are there) but black is taking it next level!
243Racing1447.50 |
03-09-2021, 03:06 PM | #8 | |
M2 Pilot
138
Rep 165
Totally agree it wasn't my ferocious speed or anything subpar about the pads. I just let them get too thin. I've been happy with RSL29s, other than their short life. Hoping the AP kit will give: - same stopping power - a little better feel - more endurance before fading - better pad life Will also be looking into ducts.
'17 BMW M2 |
243Racing1447.50 |
03-09-2021, 03:38 PM | #10 | |
4693
Rep 2,542
The Essex/AP kit should definitely please in all those areas - plus the reduction in unsprung weight. I would not recommend ducts with them though. Try them first - think you will find they are perfectly capable of handling the temps without fading for your use. Ducting might actually be a negative - cool them off below their optimum operating range. I run them on my M2 with no ducting. Also run a very similar set on my race M3 with no ducting at a much quicker pace & do not have a need for ducting (and that thing is still a bit of a pig too). He definitely did win the prize! Thankfully victory lane was in the gravel trap and not the wall though!
243Racing1447.50 |
03-10-2021, 01:37 PM | #11 |
Rep 1,823
Nice save! Good work scrubbing speed sideways.
I came close once. I had about 25% pads left on a set of Carbotech R10, and decided to run them for a day. All was fine on track, but after they cooled the friction material fell off on the way home. Backing plates were bent. Had to do a roadside pad swap to OE pads. Better that than losing them on track. Learned my lesson. Swap the pads when they get to 35%. Adhesive layer is weaker than friction layer. |
03-10-2021, 04:38 PM | #12 | |
M2 Pilot
138
Rep 165
I didn't know that about the adhesive layer, but I'm learning And HUGE thanks to all the instructors at NCC & Tarheel chapters!!!
'17 BMW M2 |
5.M0NSTER3353.50 |
03-11-2021, 01:35 AM | #13 | |
Rep 1,823
I was tired and forgot to brake for the Keyhole at Mid-Ohio. Went through the chicane at over 120, and just didn't brake for the following 180 degree turn. Dumb! Trap got me slowed down enough to re-enter the track, and after that I blacked flagged myself.
2017 BMW M2 German Spec
CrashFL137.50 |
03-12-2021, 02:29 PM | #14 |
Rep 340
You're welcome 👏🏻. How is driving with Chin—I'd like to drive COTA with them or PCA (no idea how to find out about PCA) and see how they compare to Edge Addicts.
03-12-2021, 02:39 PM | #15 | |
1448
Rep 1,414
My buddy blew the water pump in his Corvette ZR1 |
CrashFL137.50 |
03-12-2021, 03:27 PM | #16 | |
M2 Pilot
138
Rep 165
PCA does Schnellfest at COTA. I thought it was twice a year but it might be 3x. https://austinschnellfest.clubregist....net/index.cfm
'17 BMW M2 |
03-13-2021, 07:22 AM | #17 |
Rep 89
in your dash I can see the tire warning light on, looks like you lowered your tire pressure before your session and did not reset the tire pressure in your board computer which can be an issue since the car does not let you turn traction control off with that tire pressure warning light on!
traction control can lead to overheating brakes as well since the brakes try to balance the car by brakeing and you don't even realize that |
03-13-2021, 08:03 AM | #18 | |
M2 Pilot
138
Rep 165
None of the DSC modes work well for me on track. They fight rotating the car, and don't like putting power down out of corners with steering angle or yaw. And you're right about the brakes— it'll cook them. The car is really well balanced; it's more fun + smoother without DSC.
'17 BMW M2 |
BFLY78.50 |
03-13-2021, 12:02 PM | #19 | |
Rep 89
did you do something to the deactivate the tmps sensors? |
03-13-2021, 01:08 PM | #20 | ||
M2 Pilot
138
Rep 165
'17 BMW M2 |
03-15-2021, 10:09 AM | #21 | |
Rep 340
03-16-2021, 11:46 AM | #22 |
4693
Rep 2,542
Chin also seems to have a better on track flow at COTA. Not quite as many trains, better point by manners, etc. And generally just had a better pace. Still a lot of cars on the track at one time - but you can usually get some uninterrupted laps in.
