06-02-2021, 05:16 PM | #815 |
Rep 4,146
Reviewing your logs now - Load control looks good, boost control looks good timing on the first run - good, but second run is kinda rough. Outside of the higher IATs, it looks fine to me. How many miles on the plugs and coils?
Also, I don't know why, but it doesn't show me your absolute timing values, just deviation, same with WGDC.
Mods: Yes.
06-02-2021, 05:50 PM | #816 |
Rep 289
Thanks for taking a look. I may not have them active.
Original plugs and coils, 32k. Have been looking into replacing soon- shop wants to go one step colder due to the tune, though I’ve heard OEM is fine on the M2 as they’re already colder than other N55s. |
AmuroRay2282.50 |
06-03-2021, 02:58 AM | #817 | ||
Rep 6,637
06-03-2021, 06:47 AM | #818 |
Rep 289
06-03-2021, 07:08 AM | #819 | |
Rep 4,146
But for his uses and weather, that may be ok. For my uses (even on the street) and my region, I can't get away with it. 74 degrees ambient https://datazap.me/u/amuroray/log-16...g=0&data=15-24 https://datazap.me/u/amuroray/3rd-4t...-30&zoom=49-99 Also cool note - according to the torque output on the log, the car is making 440hp. Last edited by AmuroRay; 06-03-2021 at 02:50 PM.. Reason: Additional data |
06-03-2021, 11:19 AM | #820 | |
Rep 5,372
06-03-2021, 11:54 AM | #821 | |
Rep 289
As always, you get what you pay for. But it also makes no sense to pay for what you do not need. This is not the worlds best intercooler, nor is it priced as such. But it does exactly what I need it to without it costing much. My cars see 35k miles a year and get replaced in 2-3 years. It just doesn’t make sense to invest thousands of dollars of parts into them. Last edited by Dasnub; 06-03-2021 at 01:46 PM.. |
06-03-2021, 12:43 PM | #822 | |||
Rep 4,146
But here is a VERY recent review of the VRSF race: Thread here Quote:
Also Quote:
https://www.bootmod3.net/log?id=60b2...0b432b33dceed2 found in this thread He starts at 76F and drops down to 68F during the run (52F ambient) Also note none of these runs are to redline, so it's possible the temps could increase, but notices they stay stable even after he lets off.
Mods: Yes.
06-03-2021, 12:46 PM | #823 | |
Rep 4,146
Mods: Yes.
06-03-2021, 01:16 PM | #824 | |
Rep 6,637
69 degrees, stage 1 ACN tune so not super aggressive but does create more heat than stock. I had been driving for a while. I spent 10-15 minutes fooling around and never got IATs that would give me issues at least on a 70 degree day. I figure I should be okay up to 85-90 ambient which is rare here. On the track would be another thing but I can't be 100% throttle on the street all the time because of safety and police and also curvy roads. Mashing it at every opportunity I have to do so doesn't result in high enough temps to cause me issues. I don't usually make it very far into 4th gear as I don't want a triple digit ticket. These are just to almost the top of 3rd before and after. In these situations my IATs tend to not change until after I'm off throttle. Notice on this one it was a second pull shortly after the previous pull and IAT did creep up between pulls but didn't change during the 3rd gear pull. |
06-03-2021, 01:57 PM | #825 | |
Rep 289
06-03-2021, 02:53 PM | #826 | ||
Rep 4,146
You'll note on the Stage 1 application, he noted that the temps DECREASED during the 3rd gear pull, and slowly crept up during the end of the 4th gear pull.
Mods: Yes.
06-07-2021, 01:32 AM | #827 |
Rep 18
Did some pulls after my brother and I finished installing VRSF Charge pipe and VRSF comp HD 6.5" instercooler. Pulls were on BM3 Stage 1 93 oct. Houston, TX so LOL 90% humidity and 85F after sun went down.
1-4 gear pulls would start 95F, and end at 88F. We were dead laughing because those same pulls on stock intercooler would start 104F and end at 140F. |
AmuroRay2282.50 |
06-07-2021, 11:30 AM | #828 |
Rep 5,372
I did some logging with my Wagner EVO Comp I intercooler over the weekend as temps in Kansas City finally got up into the 85-90 degree range.
Stop and go traffic in 88 temp ambient air On a completely heat soaked motor after driving 30 minutes, at a stop light, IATs would creep up to 110-120 degrees. Within seconds of leaving the light, IATs would drop to 105 degrees. A swift punch of the throttle in 2nd would drop IATs to 95 degrees almost instantaneously. When going a steady 35-45mph, IATs would hover right at 102 degrees. 6MT 3rd gear run from 55mph to 110mph in 88 temp ambient air At the start of the run and no throttle, the IATs were around 100-102 degrees. Within 2 seconds of the start of the run, the IATs dropped to 93 degrees. Right at the end of the IATs, the IAT was at 97 degrees. While coasting in 6th, IATs almost immediately climbed to 102 degrees. A half stab of the throttle in 6th at 75mph nearly instantly dropped the IATs from 102 degrees to 93 degrees. It would do this every time.
06-07-2021, 03:38 PM | #829 |
Rep 126
Finally i got my CSF intercooler and chargepipe installed tomorrow.
Can't wait if there is any difference or hp gains
@Rub1con76
06-07-2021, 04:32 PM | #830 |
24204
Rep 190,807
Pictures, please
06-08-2021, 09:35 AM | #831 |
Rep 126
Here you go
@Rub1con76
Sundinisagod107.00 |
06-26-2021, 12:00 PM | #832 |
Rep 427
I know none of us need convincing that the stock intercooler is insufficient for track use in warmer weather, but I liked the added visual of overlaying the IAT on a video session to see where it’s getting hottest, and that it never comes close to recovering to Ambient temp. It was around 88-90 degrees according to the car’s temp display.
I have a CSF intercooler and AA charge pipe on order. If it gets here in time, I’ll be back at the same track on July 8 and will do the same thing if the weather cooperates. Worst case, I’ll be at another track on the 10th and 11th that’s in a hotter part of the region that should give me similar conditions. |
06-26-2021, 12:07 PM | #833 | |
Rep 83
06-28-2021, 09:15 AM | #834 |
24204
Rep 190,807
07-04-2021, 01:22 AM | #835 |
New BMW owner
325
Rep 843
Finally got my CSF. I hope it’s straight forward install like the FTP charge pipe.
I had to loosen the hose clamps connecting the charge pipe segments so the lower part would engage with the IC. 1.5 hrs later…. Wow. Is it psychological or is the car more powerful with the new intercooler? I feel like the car charges much more. Myb it helps that it just rained so the weather is cooler. I don’t feel it added any lag but then again I’m no expert. I just feel when I step on the gas and a second later, the rear wheel is spinning (wet road). Sport+. CSF, for Pete’s sake. Would it kill the company to include a bigger (or proper rectangular) washer so the IC isn’t looking like it’s going to fall off? The washer tilts to one side. Precariously sitting to one side and looks like it could slide out. I had to put a nut (rummaged thru my bin of random crap) in between the space so it doesn’t shift to one side. This IC have been shipping to customers at least 3+ yrs now, I guess they don’t intend to improve this aspect. Weird though that I received 4 sets of washers and screws. Would have been a nice touch if they spec’d it with torx screws instead of what looks like stainless wood screws but that would be asking too much considering the washer. Sorry no nearby street (that's not congested) to do any logs. Last edited by vrooooom; 07-04-2021 at 08:23 AM.. |
07-05-2021, 08:47 AM | #836 | |
24204
Rep 190,807
