M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > White Somme on take off
      04-29-2024, 01:50 PM   #1
Talx
Drives: M235i
I’m getting a tad of white (like just a bit of a mist) some on take off or after the car idles for a bit but nothing when I’m on throttle. I’m talking about hot running conditions
Not loosing coolent or oil, anyone have ideas?
Car has 20,000 miles on it stg 2 for 15,000
Doesn’t seem to be smoking enough to be a bad turbo. Also have open exhaust system with catless DP opf delete and open back box.
This hasn’t been the case for the 20,000 miles it’s a new occurrence.
Thanks for the help upfront 🙏
      04-29-2024, 02:06 PM   #2
Enabled
Drives: 328xd Wagon, M2 Competition
It can be normal if the exhaust pipes have not been heated up enough to evaporate all the condensation from combustion. If it doesn't linger or smell odd, I'd bet it's just condensation.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      04-29-2024, 02:12 PM   #3
Talx
Drives: M235i
Sorry forgot to mention I’m talking about hot running conditions
Also this hasn’t been the case it’s a new occurrence
      05-03-2024, 01:35 PM   #4
n8dgr84
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
182
Drives: M2C - 6MT - Flex Fuel
The charge cooler is probably leaking internally and you're burning the coolant. Check the coolant reservoir at the firewall.
      05-16-2024, 09:42 AM   #5
Talx
Drives: M235i
That’s what I thought, so I removed the charge cooler and there’s no oil on the hot side and no water residue or signs of water on the cold side.
Also checked water levels of charge cooler and engine coolant and I’m not missing any water.
I’m thinking maybe there might be a slight leak from the turbo, but if that was the case it would be smoking all the time.
