02-15-2017, 12:28 PM | #177 | |
Doc Brown
1178
Rep 2,174
So basically what I want to know is if everyone installed the software for the Vgate onto their phone first, (then the in app purchase for bimmercode) and did they pay $9.99 to do it (for ios)? Or do you just plug the vgate in and use it with the bimmercode app. It looks like if you download the vgate app there is a bunch of diagnostic stuff you can do and that is what they charge you for.
02-15-2017, 03:29 PM | #178 | ||
Rep 231
02-15-2017, 05:19 PM | #180 |
Doc Brown
1178
Rep 2,174
Thanks, I just got home and tried it. And it works no problem!!
02-17-2017, 06:19 PM | #181 |
Rep 6,638
Does this app allow me to remove the key fob feature that rolls down the windows when the unlock button is held down? Don't want it accidentally rolling down the windows when I lean on a table.
02-17-2017, 09:25 PM | #182 |
Rep 837
02-18-2017, 11:39 AM | #183 |
Rep 616
Drives: M2, X2 M35i, X6,328i,230i
Garage List 2017 BMW 230i [0.00]
2022 BMW X2 M35i [0.00] 2015 BMW 328i [0.00] 2008 Jeep Commander ... [0.00] 2017 BMW M2 [0.00] 1997 BMW Z3 1.9 Roa ... [0.00] 2014 BMW X6 xDrive35i [0.00] |
I didn't even know this feature existed!! What's the purpose of this? I can think of reasons why I would want to roll the windows up with the FOB (you left your windows down and it's starting to rain) but I can't think of any reasons why you'd want to to roll them down with the FOB.
02-18-2017, 12:49 PM | #184 | |
Rep 837
The ability to roll up the windows remotely has been disabled in North America for liability reasons. Wouldn't want to accidentally pinch an animal or a human, leading to a lawsuit against BMW North America. |
02-18-2017, 01:21 PM | #185 | |
Rep 616
02-18-2017, 06:59 PM | #186 | ||
Rep 1,431
The rolling windows up remotely feature would def come in handy. Too many times I've left my windows down a bit so as not to overheat inside, only to look out my office window as a pop up thunderstorm/downpour fills my car up |
02-18-2017, 11:03 PM | #188 | |
Rep 6,638
I also can't find the option to turn off rolling down windows when unlock button on key fob is held down. Does anyone know where this option is in the Bimmercode app? Also will messing with any of these settings void any part of the warranty? Forgive my ignorance here... |
02-19-2017, 06:28 AM | #189 | |
Rep 1,431
Looks like this would be it. Description reads- FEM_BODY 3040 CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK aktiv nicht_aktiv If Auto-Lock is enabled, then all doors will unlock at ignition shutoff. *pls note that I have not tried this myself. |
M2OG400.00 |
02-19-2017, 06:32 AM | #190 | ||
Rep 1,431
In FEM module, expert mode: FEM_BODY 3053 KOMFORTOEFFNUNG_FB aktiv nicht aktiv Open Windows/Fold Mirrors when holding Unlock on Key Fob. Warranty is fine. These are options that are already preprogrammed into the car. You are simply activating/deactivating them. Where you would run into problems is if you screwed something up ie your coding session is interrupted, car is disabled and you can't restore it yourself. This app is pretty fool proof in that it automatically generates backups but it's no guarantee I guess. I know with the guys coding via E-Sys, you can potentially really mess things up if you hit that dreaded 'code default values' button ...could brick your system I believe. |
02-19-2017, 02:52 PM | #191 | ||
Rep 390
Best,
Charlie 2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp |
M2OG400.00 |
02-23-2017, 12:36 PM | #193 |
Rep 6,638
02-23-2017, 05:21 PM | #194 |
Doc Brown
1178
Rep 2,174
So I cant figure out what I changed, but how do I STOP the windows from cracking when I unlock the car? I can't figure it out. Thanks.
02-23-2017, 06:45 PM | #195 | |
Rep 45
Now if they crack open while unlocking that's different...never seen that before |
02-23-2017, 06:51 PM | #196 | |
Rep 1,431
It's because the door is frameless. Like ceeto said, it's to create a proper seal. In order to get that proper seal, the window needs to be cradled by the foam seal on BOTH sides. So it has to come down before the door closes so that it could go back up and be seated properly into the foam seal. I wondered the same thing with my last car |
02-23-2017, 07:16 PM | #197 | |
Doc Brown
1178
Rep 2,174
No, that I know, this is not my first BMW. this started today for the first time after coding. Just so you know I have done some coding with this app a few days ago and this was not an issue. when I hit the unlock button on the remote the windows, (both driver and passenger side) drop a 1/4 inch, before I ever touch the door handle. then when I touch the handle to open the door it drops to the normal level set from the factory. then when I close the door it raises a little and stops a 1/4 inch from closing all the way and then I have to close both driver and passenger windows with the window switch once the car is running. Something happened with the coding. If the car is locked and I just grab the exterior handle it operates like it should. Also if the windows are all the way down and I lock the car with the remote while the engine off the window go up about a 1/2 inch and stop, which never happened before today either. I even tried restoring it from a previous backup from the other day and it did not change any of the settings. even the ones I did today
02-23-2017, 09:19 PM | #198 | ||
Rep 1,431
