05-30-2023, 03:53 PM | #133 | |
Rep 4,218
Mods: Yes.
05-30-2023, 08:38 PM | #134 | |
Rep 7,543
Either way bm3 has eliminated this paranoia, you can now go fully offline and use the same table editors and map definition techniques as MHD. This has brought back some tuners like twisted tuning. 2) I'm almost certain you can view every table in bm3 ots maps, and this means if a tuner sees their tables copy and pasted they can likely press charges. So I really doubt bm3 would do this, they've worked so hard on every aspect of bm3, so there's no way they're going to put that all at risk to steal an ots map made for a specific car run in specific conditions. There's a reason halim@hcp is on the bm3 team, and it's to make killer oys maps. 3) you have it completely confused on this part. You keep thinking bm3 = boost based and MHD = load based and that is fixed, but this thinking process is completely backwards and all wrong. When you do custom tuning you don't have to make it boost based or load based. When you custom tune you can make bm3 boost based or load based it doesn't matter, because you have access to the same tables MHD does, because those tables are going to be what the damos file for the ecu has. Technically from bm3's map editor you have way more tables than mhd's public xdf, so you're already starting a bit further ahead. Anyways, you can even make MHD boost based - you got the same tables you just have to change your tuning style. You don't seem to understand, tuning is pretty much the same regardless of platform you have, you are changing the same finite tables on the ecu. The only time it gets different is when you start using custom race roms which add custom logic to the ecu. So in summary you have the same tables (not considering custom rom), what differentiates it is how you tune it (boost or load based), the tuning platform doesn't restrict this. 4) bm3 has a significantly better logging system. You have so many more channels and so much more customization vs. MHD. Imo mhd's data logging is garbage after using bm3. 5) the entire UI on bm3 is light years ahead of MHD, and that comes from the team of GUI developers they hired. Everything is customizable, down to the color of the guage and about of decimals you want. You don't have that level of control on MHD. 6) bm3 seems to support all roms versions of an ECU, while MHD only uses a few specific ROM versions. What does this mean? If your rom isn't supported by MHD you'll have to flash their ROM version, and this means you'll have a mismatched ROM version vs. your software level of the car. This will make spotting a tune even easier, if you care about such things.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 06-12-2023 at 04:29 PM.. |
05-30-2023, 09:54 PM | #136 |
Rep 7,543
Same here!
Especially about oil, lots to learn there because it changes so fast.
05-30-2023, 10:14 PM | #137 | |
Rep 1,543
Drives: M235i
I reached out to Pro Tuning Freaks and they do not offer anything native outside of their OTS maps. Pure recommends Wedge for tuning, which uses MHD exclusively, so with that information in mind I'm making the switch. I opted for the upgraded inlet from Pure. |
05-30-2023, 11:54 PM | #138 | |
Rep 7,543
If you want an alternative to wedge (Steven is an excellent tuner don't get me wrong), you could try David shoup - he tunes bm3. I think those 2 guys are at the top of the game when it comes to bmw tuning.
06-09-2023, 01:42 AM | #139 |
Rep 93
I have pure500 installed on n55 ewg 14’ 335i, mppk intake and exhaust. Arm intercooler, b58 hpfp gen 1, catted CTS downpipe, pure turbo inlet. I only did virtual dyno between when I had oem turbo running on e20 mhd stage 2+ which was showing 408whp vs 449whp mhd custom e30 tune by Jordan tuned, pure500 turbo, I know it may not be as accurate as real dyno but it shows how much better powerband is with pure500 turbo. Overall I’m very happy with it.
Ewg n55 turbo vs pure 500, @6200rpm oem turbo made 360whp vs 420whp pure500, I did run in 4th gear until 6500rpm, at 6500rpm oem turbo made 330whp vs 416whp pure500, definitely seems like it’s making 60-70whp in upper range. Last edited by arekuf3x; 06-15-2023 at 11:25 AM.. |
4
06-11-2023, 06:06 PM | #140 |
Rep 1,592
Thanks arekuf3x finally some data. This was what I was hoping for, the gains to redline and the bump in peak was more than expected too. Are you planning on doing any more runs and who tuned it?
06-11-2023, 08:09 PM | #141 |
Rep 4,218
Part of the gains are that the MHD tune does cut power down towards redline, so it’s not entirely turbo related.
I think I usually see about 360WHP or so at redline on a. BM3 E30+ tune. |
06-11-2023, 08:38 PM | #142 | |
Rep 3,715
Add a Dorch and the Stg 2+ E30 tune to the stock turbo and peak is 440-445whp and redline is ~380whp. Add a Dinan turbo and you’re at 445-450whp peak & 410whp redline. Add a TTE460 to the same setup and you’re at 475-480whp peak and redline. Will be interesting to see how the Pure 500 slots in between the Dinan & TTE once we get some actual dyno curves. Last edited by ZM2; 06-12-2023 at 10:47 AM.. |
06-15-2023, 11:31 AM | #143 |
Rep 93
Planning to do actual dyno runs, I had remove my high flow cat for smog, once it’s installed again. I will try get actual dyno run. It was tuned by Jordan tuned, who was great, we did about 10 revisions. Turbo can do more, my b58 hpfp began crashing above 21psi, with dorch stage 2 probably be close to tte460.
06-15-2023, 12:02 PM | #144 | |
Rep 4,218
06-15-2023, 01:58 PM | #145 | |
Rep 7,543
The pure 500 is similar because it has a reworked turbine, I'm not sure if it's larger than stock, but it's guaranteed to be reworked and optimized for flow and not just clipped. So it has the potential to reach 500 whp if all the conditions are right, but it's not guaranteed.
06-15-2023, 04:18 PM | #146 | |
Rep 3,715
A 23psi map we tried hit 494whp, but power dropped lower than the <21psi map starting at 5.7k and dropped to 450whp at redline, so I’ve skipped continuing to run that map. Still interested to see where the Pure 500 stacks up as a low cost turbo upgrade. |
F87source7368.50 |
06-15-2023, 04:31 PM | #147 | |
Rep 7,543
06-15-2023, 04:34 PM | #148 | |
Rep 4,218
Mods: Yes.
06-15-2023, 04:56 PM | #149 |
Rep 3,715
Thems da curves.
Stg 2+ E30 with E30. Stg 2+ Multimap with PTF FlexFuel sensor and E50. Stg 3 beta (23psi) with E50. I’m working on a little different map with Halim at the moment. Dials back the boost in upper RPMs on the Stg 2+ MM and will increase ethanol to E60. The idea is similar power as Stg 2+ Multimap with E50, while keeping the turbo deep in its efficiency zone. That’s what the logs are showing, but I need to hit the dyno to confirm. |
F87source7368.50 |
06-15-2023, 07:59 PM | #150 | |
Rep 7,543
Are these maps going to be published eventually? But damn that's a lot of power, it's going to be a struggle keeping it cool on track.
ZM22839.50 |
06-15-2023, 09:12 PM | #151 | |
Rep 3,715
However, the Stg 2+ Multimap ended up being a little too much for the stock turbo guys, so v1.2 was released recently.That meant a little less power for my setup, so I’m working with Halim on getting some power back but with less boost and more ethanol timing to keep the turbo super happy. |
F87source7368.50 |
06-15-2023, 09:18 PM | #152 | |
Rep 7,543
It would be cool if bm3 would have upgraded turbo maps specifically, like stage 1 and stage 2 turbos.
06-16-2023, 12:12 AM | #153 |
Rep 179
Stage 3 was supposed to be the upgraded turbo map, But it was abandoned
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
ZM22839.50 |
06-16-2023, 12:37 AM | #154 |
Rep 7,543
I see, hopefully they bring it back, it would be nice to have an OTS map for that.
