M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Rear tail light failure
      07-07-2022, 06:31 PM   #133
chris719
Drives: '08 M Roadster
Originally Posted by H2O_Doc View Post
I just had my passenger side rear taillight throw a warning. It does the blinky-blinky muy rápido. My service adviser seemed not-at-all surprised.
Yeah, I am pretty sure this is a design "flaw" and every single car will do it eventually. Whether or not the coding is a proper solution or a band-aid is TBD in my opinion, but something definitely changes over time. When this happens to me, I will tear mine apart for science and compare every component on the PCB to a new one to find the root cause. Whatever it is, it's a shit design and they should be ashamed for not correcting this with either a revision to the light or software change.
      07-07-2022, 08:25 PM   #134
Rk-d
Rk-d's Avatar
625
Drives: GT3 Touring, 993 C4S, M2C
Replacing the light did nothing for me. Replacing the REM module fixed it. For now.
chris7197788.00
      07-07-2022, 09:13 PM   #135
chris719
Interesting
      07-08-2022, 09:37 AM   #136
rwemersonrw
rwemersonrw's Avatar
550
Drives: BMW M2 Competition, Acura TSX
I've posted on the maintenance forum, but thought I post here to see if there was more feedback.
R rear tail light failure warning came up. Happens intermittently and resets when the car is turned off. I took it to BMW and they replaced the tail light but that did not resolve the problem.
Has anyone in here had this problem and found a definitive solution? BMW is wanting to hold on to the car now and it could be weeks that they'll have it trying to trace the problem.
Had to have left and rear light assemblies replaced. Free of charge!
chris7197788.00
      07-13-2022, 09:14 PM   #137
Zeese
a coffee drinker
Zeese's Avatar
Drives: 2017 BMW M2 6MT (LBB)
Dang it
2017 BMW M2 OG - Pre-LED Taillights. My story ;-)
Ground shorts out in the right rear taillight. Five years / 50k miles? I think this was the warranty for the taillights. Oh well. 8/2016 build .. in service on Oct 15, 2016.
Did a bit of reading. Ordered the following to fix the right side taillight and get ahead of the problem on the left side.
Code:
Part Number	Part Name	Price	Quantity	Total
61-12-2-448-168	Repair Cable Tail Lights 611013	$26.51	2	$53.02
Code:
63-21-7-370-291	Socket Panel	$59.01	1	$59.01
63-21-7-370-292	Socket Panel	$59.01	1	$59.01
Easy fix. A little patience, wire strippers and crimpers are handy to have (one can fake it).
Stepping back to admire my work, I noticed both taillights were cracked Subtle, but once seen, impossible to ignore. The cracks radiate from the center of the plastic lenses. Wish I had noticed this sooner... too many plates spinning ...
LED Retrofit!
The USA M2C taillights (red turn signals/indicators) were an option. Opted for EUR w/ amber turn signals. Black Line version.
There are some indications that dealers will still fix the taillights as a courtesy, at their discretion. Oh well.
Now, of course, I have to read this thread more closely to understand what may happen next!
chris7197788.00
      07-29-2022, 04:52 PM   #138
blitzyo
Drives: 19' M2C
Originally Posted by pablom2c View Post
It happened again this morning and I recorded it, coding is done as indicated previously.
[IMG][/IMG]
Same issue, same light. I had the LED lights coded from day 1. I coded the lights the same time I coded off the fake sound.
chris7197788.00
      08-05-2022, 12:41 AM   #139
Zeese
a coffee drinker
Zeese's Avatar
LED Tail Light Voltages
This evening, I installed the EUR Black Line taillights. Rather easy. At the same time, I replaced the reverse light bulbs with LEDs.
Coding! Used BimmerCode. It takes some patience looking through all the options in Expert Mode. Thinking I got it right.
Voltage? In in this thread M2 LCI tail lights retrofitted on pre-LCI M2, there are some excellent notes. And, a spreadsheet indicating voltages for Pre-LCI and LCI cars.
Originally Posted by CommitConfirm View Post
DIY Guides:
%snip%
UPDATE A: I was able to get my hands on a UK RHD LCI to read the coding BMW have use. The link below is to a spreadsheet detailing the differences from the pre LCI vs LCI: https://www.dropbox.com/s/gof7lh1sg8...-0.2.xlsx?dl=0 THESE VALUES HAVE BEEN APPLIED TO MY PRE-LCI AND CONFIRMED AS WORKING
%snip%
100% = 64 for all of the voltage values, except the reverse lights.
100% of what?
Originally Posted by Nezil View Post
I use E-Sys, and for my 2018 LCI OG M2, the info you want is here:
This is a screen shot which included voltage information (see the cropped screen shot attached).
100% of 14V.
For the reverse lights (Rückfahr-Scheinwerfer), the OEM LED taillight ships with a non-LED bulb. The spreadsheet lists that requirement as 13.5V = 87. I am not clear on whether or not these values are for the original bulbs or not.
The same spreadsheet has some additional values that are not found in most forum posts and DIY videos that may be interesting to LCI owners. For example,
Code:
MAPPING_BREMSL_L_FIXED_PWM	fixed = 01
MAPPING_BREMSL_R_FIXED_PWM	fixed = 01
Thanks for reading.
Last edited by Zeese; 08-05-2022 at 03:12 PM.. Reason: summarizing voltage requirements
      08-14-2022, 04:11 AM   #140
zellatc
Drives: M2 LCI
Hi all,
After fixing the rear left lights last year (and ZERO issues since then), last month I started getting the problems in the right one.
Again, I dismounted, checked there were no burns or strange marks, so I just cleaned the pin and connectors:
Also, to assure better contact, I bended the pins slightly . Here you can see 3 of them already bended:
4000 kms later, not a single failure.
So here are my recommendations, before you take the car to the dealer to replace the lights (that WON´T olve the issue) and before you start coding the car (that is just a workaround):
MAKE SURE THE PINS ARE CLEAN AND MAKE SURE THEY MAKE GOOD CONTACT BY BENDING THEM!
chris7197788.00
      08-14-2022, 04:12 AM   #141
zellatc
Drives: M2 LCI
[IMG][/IMG]
Check previous post
      08-24-2022, 03:58 AM   #142
blitzyo
Drives: 19' M2C
Originally Posted by zellatc View Post
Hi all,
I've cleaned mine with electric contact cleaner. It worked for a day and started doing the same thing again. Haven't tried bending the pins.
      08-24-2022, 08:36 AM   #143
zellatc
Drives: M2 LCI
Bend them. You can also try to squeeze the socket a little bit (pushing from one side) but don't do much pressure, they're quite soft.
Tell us if it works
(Mine still working without problem!)
chris7197788.00
      08-27-2022, 12:35 PM   #144
alkatraz
56
Drives: 2016 BMW X5M
Had it happen, one tap to rear light fixed it for now. Will take to dealer about that REM module replacement. Thank you,
      08-28-2022, 04:30 AM   #145
doughboy
doughboy's Avatar
1602
Drives: 2007 E85 Z4M Roadster
Tell us if it works
Yeah Id tried squeezing the female sockets a little, but it came back.
I think bending pins a a better idea, i'll try that.
      08-30-2022, 01:36 PM   #146
M Fifty
862
Drives: M2 & 330CI
7 pages of posts about an issue that's considered 'normal BMW driver behaviour'* in many markets...
*failure to indicate
      08-30-2022, 05:41 PM   #147
Fred Conoway
Fred Conoway's Avatar
Drives: 2021 F87 M2 Competition
I use my turn signal religiously so that I don't fall into this camp
2021 F87 M2 Competition, Sunset Orange, 6-speed
2010 E60 535i xDrive, Space Gray, Auto (sold, but still in the family)
      09-17-2022, 12:41 PM   #148
bmxcamel
bmxcamel's Avatar
Drives: 2011 E90 M3, 2021 G01 X3 m40i
Anyone who has bent the pins had this issue recur yet?
      09-17-2022, 10:11 PM   #149
Zeese
a coffee drinker
Zeese's Avatar
Related...
Anyone cleaning the connections and using dielectric grease? Seems moisture and corrosion may be a problem.
Best stuff to use on electrical connections?
DeoxIT® D-Series?
Thanks!
      09-18-2022, 04:56 AM   #150
doughboy
doughboy's Avatar
1602
Originally Posted by Zeese View Post
Related...
DeoxIT® D-Series?
Thanks!
Yes I cleaned / dried and used silicon electrical grease which fixed it for about a year...
Zeese100.50
bmxcamel733.50
      09-18-2022, 10:01 AM   #151
Zeese
a coffee drinker
Zeese's Avatar
Good to know! Disappointing to hear the problem came back. Crazy.
Thanks!
      09-19-2022, 12:49 PM   #152
davidk
Drives: 2018 X3 M40i, 2018 M2
I tried cleaning the pins and using some dielectric grease, and thought it was fixed, but the issue returned again after about a month. Is the only fix to replace the light, and does that actually fix it?
      09-27-2022, 11:19 PM   #153
chris719
It does, until the replacement light does the same thing.
Even though I disagree with him on the issue, I would code your car as Poochie suggests if you are out of warranty because it appears to buy you more annoyance-free time.
It's pretty obvious there is a flaw in the lights that causes the check to fail intermittently with increasing frequency as the light ages. This never happens to brand new cars and it goes away for a while once the light is replaced. Points pretty strongly to something in the lights aging out of spec over time.
The other argument being presented is that the lights are fine and the check is just improper for these lights. I might buy that if I haven't heard of several fail eventually after coding this to suppress the error.
Once my lights fail I will most likely tear apart a "bad" light and a new light to compare behavior at all points of the circuit inside. If it's as simple as replacing a FET or something it should be able to be substituted with a more robust part.
      10-11-2022, 04:45 AM   #154
Jinjer
Romania
Drives: BMW M2 2018
Heya!
Same issue on my M2's right side. Since dirty and water is going in, I don't think that bending the pins is the answer but finding a solution so nothing gets in anymore. In search for a solution... If someone has any idea, please let me know. Thanks.
Although I cleaned it 2 weeks ago, this is how it look now :/
