M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > MST Inlet
      11-05-2023, 01:34 AM   #133
///M TOWN
///M TOWN's Avatar
Drives: M GmbH
2018 M2  [9.01]
No need to remove the water pump
Move it, yes… Remove it, NO❕
But I can contest to the fact that it’s a bitch to install
I’d pay a mechanic if given the opportunity to start over
Also, MST completely fucked their end-user by installing the PCV junction incorrectly… Resulting in a completely unnecessary removal and reinstallation so it will line up correctly
Ratbastards ❕
      11-05-2023, 10:27 PM   #134
c0riolis
Drives: 2018 M2 DCT
Yes, sorry if I was unclear that's what I meant by this:
by unplugging and removing the coolant pump (or rather, rotating it to the side)
Basically disconnect both hoses (inlet/outlet), disconnect the electrical connector, and unbolt the two bolts you can see, this way you can rotate it out of the way while it is still held by the third bolt.
Yup...
///M TOWN22185.50
