06-20-2020, 03:00 AM | #133 | |
Rep 488
I did not have the lag issue though, that appeared when I updated from the car's original ISTEP (dated 2015), to a post LCI ISTEP (dated 2018). Funnily enough I did post about the issue back then, but it didn't really go anywhere - perhaps that is the post that Nezil is referring to in the very first post in this thread. |
06-21-2020, 02:45 PM | #134 | |||
Plenipotentiary
2614
Rep 3,046
If you don't mind giving this a shot: - Code GHAS and anything else changed to M2GTS back to M2 Std. - Scan for faults with ISTA, clear if any. Find and copy event log file to a familiar folder. This is über important. If you're unsure which one, locate the program data folder and search for the text file using these keywords (fault, implausible, ignored, test, bogus, cross, your, fingers, brick, car). - Road Test and Log with: - DSC off - Throttle Sport and no pedal multiplier mapping added (pedal position equal to torque request) - If burble map applied, disable. - Speed 65 mph at start if possible but above 62mph and below 124mph - Engine speed between 2500-5500 - WOT before and after gear change - Gears 2-5 as needed to meet the conditions above. - Share results |
06-22-2020, 01:49 PM | #136 | |
Rep 488
Re the logging, are you after logs from ISTA or Bootmod3? Cheers. |
06-22-2020, 02:28 PM | #137 | ||
Plenipotentiary
2614
Rep 3,046
widetyres280.00 |
06-22-2020, 03:43 PM | #138 | ||||
Plenipotentiary
2614
Rep 3,046
F82GTS has its own set of issues but shares one thing in common with M2GTS (M2Racing Club Sport Variant): DCT load-reversal dampening, which I suspected earlier. |
widetyres280.00 |
06-23-2020, 09:56 AM | #139 | |
Rep 1,466
This error could be benign, or could have an impact on other things drivetrain related.
2018 ///M2 LCI, LBB, 6MT...
06-23-2020, 01:01 PM | #140 |
Rep 488
06-23-2020, 03:52 PM | #141 | |
Rep 488
After this drive (which I really enjoyed BTW down some great roads), the error log was empty. @Lemetier: Please can you let us know the situation that causes the load reversal dampening, and which module is responsible for this protection function? (we can then avoid coding that in future). Thanks. |
06-23-2020, 04:01 PM | #142 |
Rep 488
Just went and did the logs.
I put my car back completely back to standard M2/F087 coding. After doing this, I immediately (without driving) got the two “regulated differential lock” errors, which I cleared. From what I can see from the logsm they confirm Nezil’s findings. Apart from the time that I overcooked the revs (and the engine held boost between shifts), the pattern when shifting below 5.5K seems to be: 1) On gear change, DV dumps boost. 2) On release of clutch, the wastegate closes completely, but only momentarily. 3) The wastegate then opens as the throttle goes down, even though the boost is below target, thereby delaying boost build up. lemetier: I will send you the logs directly. What do you reckon is happening? Thanks. Last edited by widetyres; 06-23-2020 at 11:35 PM.. |
06-25-2020, 04:25 PM | #143 |
Rep 289
Noticed this comment in another thread and curious what effect it would have for this application. Any thoughts?
“ Coding, "Start engine without clutch" switches off auto rev-matching in all modes.. Be aware, it kills the clutch position sensor and any related features that depends on this sensor for data, which includes but is not limited to; anti-stall, hill hold (to cancel with the clutch pedal), one push start button, ect..” |
widetyres280.00 |
06-26-2020, 09:59 AM | #145 |
Plenipotentiary
2614
Rep 3,046
06-26-2020, 10:12 AM | #146 | |
Plenipotentiary
2614
Rep 3,046
- 9 indexed faults are displayed - 3 indexed faults are not displayed - I stopped counting at 100 un-indexed faults that are not displayed. |
ZPrime611.50 |
06-29-2020, 06:10 AM | #147 |
Rep 488
For the benefit of others, here is an extract from the log in question:
07-08-2020, 07:41 AM | #148 |
Rep 4,529
Vlogger with MT M2 commented lag felt much less post install of TS DV & MST inlet pipe and FTP rigid TIP.....
Current '22 X3M LCI.. |
Yellowflash21369.50 |
07-08-2020, 10:56 PM | #149 | |
Rep 1,094
After that I'll look into DV. I already bought GFB DV+ but I'll look at Turbo Smart before going through the trouble of installing it. Thanks for sharing this. |
07-08-2020, 11:14 PM | #150 |
Rep 1,466
I think I also reported less lag after installing the GFB diverter valve. Having said that, it wasn’t less lag between shifts, it was less lag when going on and off throttle in the same gear.
The software induced lag is only between shifts, and diverter valve upgrade cannot fix that I don’t think. |
07-20-2020, 11:00 PM | #152 |
Rep 289
07-20-2020, 11:36 PM | #153 |
Rep 1,466
I have lag, no changes to flaps that I'm aware of... tune might have software changes but I had lag with the stock map as well.
07-22-2020, 05:15 AM | #154 |
Rep 557
I have the exhaust flap fuse removed (so flap locked open). I've had 3 track days in the last 6 weeks, the most recent after getting a BM3 custom tune which didn't affect this issue. Whether I get the lag or not on wot shifts seems to be consistently related to shift speed.
Deliberate/quick shifts (Auto Solutions SSK 20%, stock clutch) never result in lag but if I'm just a little casual the lag returns. It's not the perfect situation though does make me more focussed when going hard! |
