10-03-2018, 07:36 AM | #133 | |
Rep 3,362
Then again, the M2C is probably going into A-street, so actually competing with it doesn't look appealing... Regards, Chuck
Current Stable:
10-05-2018, 03:22 AM | #134 | |
Rep 3,715
CSBM52756.00 |
10-08-2018, 08:30 PM | #135 | |
'17 M2 Mineral Grey
Rep 15
Dave Last edited by young1; 12-14-2018 at 06:04 AM.. Reason: removed broken picture links |
CSBM52756.00 Old Geezer205.00 |
10-09-2018, 06:12 AM | #136 | |
Rep 3,362
I've got the problem that 18" wheels won't fit the M2C, so I have to use 19s all around (or 20s, lol).
Current Stable:
10-10-2018, 04:19 PM | #137 | |
Rep 189
10-10-2018, 04:23 PM | #138 | |
Rep 1,084
10-10-2018, 04:27 PM | #139 |
Rep 189
10-19-2018, 11:56 AM | #141 |
Rep 189
Pretty sure the 788s are 29 front/40 rear, like the 437s. I suspect a 265/35-19 square setup would work. My concern is that a 275/35-19 in front would be too tall. Right now, there don’t seem to be any 30-series 200tw tires available in a 19. 😢
Proctor750426.00 |
11-06-2018, 02:03 PM | #143 | |
Rep 538
Definitely running re71 whatever the answer (unless the tire size doesn't exist) |
11-07-2018, 07:43 PM | #144 | |
Rep 189
You might read through this thread in the Wheels/Tires section: https://f87.bimmerpost.com/forums/sh....php?t=1439522 |
Proctor750426.00 |
11-09-2018, 06:11 AM | #145 |
Rep 1,001
Drives: 2024 M4 Comp X-Drive
Hi guys,
Thanks for all the great information. On a bone stock suspension with stock wheels what's the largest size tire you can run in the back without rubbing? (that is closest to OEM size and not too wide for the wheel) Is 295 the limit or would a 305 work? Appreciate it Chris
2024 Dravit Grey M4 Competition X-Drive
11-09-2018, 08:40 AM | #146 | |
Rep 462
For 19 437m and for 18 513m.
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude |
11-09-2018, 11:18 AM | #148 |
"The Midas Touch"
521
Rep 1,055
Drives: F87 LBB ///M2
I'm thinking running the following setup. Currently lowered on KW HAS (1.2" drop in the front and back)
19x9 +20 19x10 +35 What is the max rubber I can fit (thinking 265/30/19 and 295/30/19). Will this setup fit and can I go wider. Want it to be as flush as possible with no rub. Would love to get everyone's thoughts. Thanks l! |
11-09-2018, 12:47 PM | #149 | |
Rep 3,715
11-24-2018, 06:11 AM | #150 |
BMW Fanatic
331
Rep 1,076
I'm running 265/35R19 and 285/35R19 in the back. Was just wondering what tire pressures you all run?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
11-24-2018, 06:17 AM | #151 |
Rep 685
11-24-2018, 11:36 AM | #152 |
Rep 3,715
11-24-2018, 08:22 PM | #153 |
Rep 120
what are the largest tire sizes for front and rear that are still optimal for the OEM wheel range and do not rub?
I really want 100% no rub even under extreme compression, Ive read the posts in the thread but still seems a little inconclusive.
'19 BMW M2 Competition | BSM | DCT | Exec Pack | GC Camber Plates | Acexxon Reflectors | Pagid RS29 | Castrol SRF | 788m MP4S | 437m AD08R
11-24-2018, 10:53 PM | #154 |
Rep 3,715
Old Geezer205.00 OGM2C242.50 |
