06-23-2021, 02:09 PM | #134 | |
~Spyder
653
Rep 879
Drives: '19 M2C Hockenheim 6sp
Also, I do have the valves always open (BimmerLink coded). Don't see how that could be the culprit…but I will put them back to stock (Auto mode) and test again…
Skål från Sverige...via Texas y-all
06-23-2021, 02:58 PM | #135 | |||
Rep 659
Drives: M2C
Your cold start video sounds nothing like mine. Mine sounds worse. Are you sure it was truly a cold start? Car wasn't running for many hours? Net-net for me I think I get nice sound (imo) even at low revs but only after the pipes have warmed up. Prior to that it does not sound good and having valves open only makes it worse. So I run valves closed for the first few minutes after a cold start. I can try to get iPhone videos to try to compare more apples/apples. |
06-23-2021, 03:07 PM | #136 |
~Spyder
653
Rep 879
Thanks OP…the start-up vid I posted yesterday was at lunch time, after the car sat for ~4 hrs.
However, at the end of the work day…here is another cold start, and the rasping sound was clearly evident at 6 seconds mark. See here https://drive.google.com/file/d/1GRD...w?usp=drivesdk I can't seem to always reproduce the bad sound, but this vid really shows it…
06-23-2021, 03:35 PM | #137 | |
Rep 659
Drives: M2C
Only reason I hesitate is I just made my videos and my cold start didn't have that nasty sounds @ your 6 second mark. So not sure what makes it happen vs not but I've been trained to expect it which is why I doubted you! Anyways -- here are some clips. Draw your own conclusions. I think I now hear what you're pointing out in the "small revs cold" video but it doesn't bother me and I've never hit it in "real" situations. And I think as the "warm" video shows, it is only temporary until pipes get warm. This is probably why I don't feel like I hit the tinny sound while doing normal driving. Btw second two clips include both valves closed (efficient) and open (sport). Cold start: Small revs after cold start (cold pipes) Small revs after ~8 mins of driving (I suspect even just 3-4 mins of driving would be enough since that is when I tend to turn on sports mode) |
No_curebimmer653.00 |
06-23-2021, 03:38 PM | #138 |
Rep 659
Drives: M2C
Also both my videos in OP were after like 2-3 hours of driving
06-23-2021, 08:01 PM | #139 |
Rep 245
day 2 EL and MPE ... so my 1st real oppty for cold start and slight vibration for only about 5 to 10 seconds and no issues after / driving to operating temperature. As far as the sound ,,,, it is freakin great !!!! this combo is better than i expected
06-24-2021, 10:23 AM | #140 | |
~Spyder
653
Rep 879
FYI... as I pretty much EXCLUSEVELY drive the car in Sport+ mode, all my vids that I posted in the last few days were taken in the Sport+ mode. My normal start up sequence: start car, wait 1-2 mins, and drive off in Sport+ mode, so I think it's fair to say I'm not really in tune (see what I did there??) with how my car sounds in Efficient or Sport modes, even when I had the stock mid-pipe. Ok...lastly. Unfortunately, I suffer from upgraditis, so I may have started a domino effect: I think the car is still quiet inside, even with the non-resonated EL midpipe. Outside, the exhaust is the bee's knees, but inside it's still too muted for my taste (and yes, I have the AD coded off). I am in Texas with temps well over 105, so driving with the windows open isn't an option during the summers. I am not looking to spend 2-3 mortgage payments (like the MPE or the Akra typically demand) on a muffler job, so what is the most recommended and somewhat cost efficient backbox/muffler pairing with the non-resonated AA EL to increase the exhaust note inside the cabin? Remus Race, Remus Sport, Dinan, AA Valved?
06-24-2021, 01:51 PM | #141 |
Rep 99
It sounds like they're all great options with remus race being a louder/somewhat raw sound, and the sport being more dialed back, and from videos the AA sitting in the middle. I have the Aa valved on order (which is supposed to be in stock and shipping) to match with currently installed nonres EL, but I've had silence for two weeks from them/xph on when it'll ship.
06-24-2021, 02:34 PM | #142 | ||
Rep 1,683
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
06-24-2021, 06:25 PM | #143 |
~Spyder
653
Rep 879
Within a few weeks of getting my car last year, I used BimmerLInk to code out the burbles and force open the exhaust flaps. I DEFINELY can confirm that the burbles are saved to the DME, but I really can't comment re: flaps, as I can't really distinguish between the valve modes BimmerLInk offers (ON, OFF or AUTO). Currently I reverted to Auto, which I think it's the OEM mode.
06-24-2021, 10:27 PM | #144 | |
Rep 659
Drives: M2C
06-24-2021, 10:54 PM | #145 | ||
~Spyder
653
Rep 879
06-24-2021, 10:56 PM | #146 | |||
Rep 659
Drives: M2C
But I've found that hard to confirm. When revving in neutral it's certainly not true. |
06-25-2021, 10:26 AM | #147 |
Rep 35
Please post video!
06-25-2021, 12:42 PM | #148 | |
~Spyder
653
Rep 879
Would love to get ONLYACTIVE or Mike@X-PH feedback on this. I am totally fine in having this bad noise only at start-up or for the first few mins while the car is warming up...but not my case. Sure, my car sounds bad-a$$ past 3k RPM, but unfortunately I would still need to wound up the engine to get to the good sounding part. Could this be bad install, exhaust leak, or some mechanical vibration? as to why, once engine/pipes are all warm, I can't get a clean consistent exhaust note across the entire RPM band. Wasn't AA EL midpipe supposed to address this?
06-26-2021, 09:46 PM | #149 |
Rep 245
[/URL][/URL]
A couple 5k pull vids and one inside the cabin vid. EL midpipe and MPE with stock downpipes. Over the next week or so, will look to find some open road and gets some vids revving the car out a bit. check replies for 2 other vids. |
06-28-2021, 09:11 AM | #154 | |
26136
Rep 194,596
Vibration or drone is caused by a bad install. The equal length has minimum clearance, the install has to be perfect for it not to drone. i ran into the same issue on my own car and had to reinstall it to get rid of the vibration
