03-25-2023, 03:09 AM | #133 | |
Rep 255
I just got hands itchy and went out fill up E40. Did 5 pulls using updated IOS BM3 with new interface(kinda look like MHD now LOL). Thank god nothing weird happened. But auto log seems having bug to record and upload. It only captured my first run after fill-up. First run was manually activated logging. https://www.bootmod3.net/log?id=641e...729b1d13425927 1.knock detected 2.cylinder 3 is pulling timing in, probably because it's the first run and system was trying to adapt new fuel blend. But I'll keep an eye on its coil and spark later. Looks like overboosting issue got fixed with v1.2 Stage2 MM. It pulls all the way to the redline. Feels fast and safe I would say. I'm wondering why E40's timing performed same as E30 and E25 in this map. 8 degrees around 6-6.5k rpm. Should I add more E? Thanks Last edited by ericlr1225; 03-25-2023 at 03:15 AM.. |
03-26-2023, 07:05 AM | #134 |
Rep 599
Thanks for all of the helpful information in this thread!
I just got BM3 installed on my 2018 M2 (coming from VF Engineering/HEX). Engine-related mods are: Fabspeed cat, charge pipe, CSF FMIC. Running the Stage 2 Multi-map v1.2. I recorded my first datalog yesterday after winter storage (Minnesota). A couple things seems strange to me when I compare the various logs from this thread (THANKS AGAIN!): 1) HPFP actual vs target near the end of the pull seems WAY off (like half of what it should be for a quick fraction of a second) and 2) the timing is much less than expected. I have it set on ACN91 even though I have 92 in the tank, so I think that explains the timing being lower than I expect. It's the HPFP being off that concerns me. I don't see this any other map that I looked at on this thread (I didn't look at them all). Would my HPFP really be crashing already? I feel like a Stage 2 tune with ACN91 should be asking that much of it, but let me know if I have wrong thinking. https://bootmod3.net/log?id=641f1b7dc090c6a84d063168 Thanks again! |
ZM22839.50 ericlr1225138.00 |
03-26-2023, 07:28 AM | #135 | |
Rep 599
03-26-2023, 08:58 AM | #136 | |
Rep 3,715
M2guru425.50 |
03-26-2023, 09:02 AM | #137 | |
Rep 3,715
ericlr1225138.00 |
03-26-2023, 09:46 AM | #138 |
Rep 599
ericlr1225138.00 |
03-26-2023, 10:02 AM | #139 | |
Rep 3,715
Plus, the stock HPFP performance degrades over time and they're now 5-7-years old in our OG M2's. |
ericlr1225138.00 |
03-27-2023, 12:04 AM | #140 | |
Rep 255
Once I installed the upgrade one, all shits gone. BTW, low fuel pressure could cause serious problem to engine especially tuned cars with higher boost target. My advice to you is tune back your car to stock tunes, and try to do some logs as I did, double check your fuel pressure under WOT. Then decide where to go. Either keep your stock tune and WOT anytime you want and enjoy the car. Or upgrade HPFP and try the fun part LOL Good Luck Last edited by ericlr1225; 03-27-2023 at 12:13 AM.. |
03-27-2023, 04:48 PM | #141 | |
Rep 599
I dropped the tune down to Stage 1 91 from Stage 2 ACN91 and my HPFP can keep up with that, so I don't plan to go back to stock. One thing I am looking at now is the boost pressure and timing between the two datalogs. I am surprised to see Stage 1 91 at a target boost of about 16.5psi and Stage 2 ACN91 target boost at 17psi - not much difference. The timing of Stage 1 91 of 5-8 and Stage 2 ACN91 of 3-4.5 also doesn't seem like much difference. That's not much of a difference. So I am guessing I am right at the limit. |
ericlr1225138.00 |
04-09-2023, 06:11 PM | #142 | |
Rep 255
Car stuttering crazy above 3.5k rpm, looks like it's misfiring but didn't trigger drivetrain malfunction light. Tried couple times later same happened and went into limp mode finally during last run. https://www.bootmod3.net/log?id=6431...0b430492cb3da7 everything looks ok thru the log. tried map 3 93oct, some stuttering too but not as serious as map 1. I guess every car is different and there is no one for all plan. We basically have exactly same mods, except i'm running stock turbo for now. I'll start lowering plug gap a little to 0.025'' and see how it perform. |
04-09-2023, 06:52 PM | #143 | |
Rep 3,715
ericlr1225138.00 |
04-10-2023, 07:07 AM | #144 |
Rep 255
how to do a full flash? I just simply flash any map by pressing flash. Would "full flash" make any difference?
Also I sent logs to PTF and Halim said he released new version of stage 2+ multimap, overboost related. Last edited by ericlr1225; 04-11-2023 at 07:36 AM.. |
04-14-2023, 10:55 AM | #145 |
Rep 3,715
I see v1.2 of the multimaps with adjusted boost and load targets. I wonder if that means less power?
04-16-2023, 04:13 AM | #146 | |
Rep 255
1. stage2+ multimap seems to have some programing issue, I dunno if it's just me or it would happen to others. Idling got rough after flash. I tried to give some gas while idling and the rpm just went up and down crazy. pre-throttle boost parameter pinned at -1.4psi. I got every settings right, double checked. 2. My car just couldn't run NGK stock gap. When boost goes above 17.5ish, it will start misfiring. Even happened a little with stage2 multimap(E49fuel) in high rpm(tiny stuttering without codes). I tried stage2+ multimap and instant limp mode at 4k rpm. Tried again couple days later, same result. https://www.bootmod3.net/log?id=6431...0b430492cb3da7 (It is version 1.1, upload logs to PTF and that's when he update v1.2) 3. I multimeter tested 97506 and all my coils, re-gapped to 0.023''. Flashed to Stage 2+ E30 single map running same tank of E49 fuel. Car is happy than ever, no matter which gear WOT, 1st&2nd car just move sideways instead of forward LOL. I finally felt what you described freight train. even I'm running stock turbo. https://www.bootmod3.net/log?id=643b...729b710de1cf05 https://www.bootmod3.net/log?id=643b...90c635ce74d4fd 4. I'm still obsessed with "largest gap without misfire" theory but my car just won't cooperate. I bought a set of BMW NGK F8s recommended by F80/F82 forum, will give it a try to see if I can run larger gap like you. Also I will try to lower the gap of bosch OEM 330s to 0.028'' to see how it act. https://www.fcpeuro.com/products/bmw...mw-12120042724 But let me enjoy the car for a while longer LOL. Would u pls take a look at my logs? Also anyone can flash to v1.2 Stage2+ multimap to see if it's broken would be nice. Welcome to jump in. Peace! Last edited by ericlr1225; 04-16-2023 at 04:22 AM.. |
04-16-2023, 04:55 AM | #147 | |
Rep 7,542
04-16-2023, 07:17 AM | #148 | |
Rep 255
Yeah, I guess 0.030'' work on ZM2's car perfectly but 100% not with mine. We have very similar mods except turbo. Maybe turbo is the reason I dunno. Anyway, as long as gapping down is working well, I'll just leave them be for now. If something is going wrong in the future, I guess upgrading B58 system is the way. btw It has fitment issue with N55 M2, I really don't want to cut OEM wire plastic cover and O2 bracket. Also testing BMW F8s is my next step, According to F80/82 forums, F8s solved a lot of issues for them. They are built for E85, also capable to run pure pump gas. they are more like enhanced version of 97506 since we all run ethanol mix. They compared both logs. Looks like F8s got the cleanest timing and Idling also last longer than 97506. I'll keep updating. Thanks for your info Edit: btw, how to do a "full flash" with BM3? Still haven't figured it out. Last edited by ericlr1225; 04-16-2023 at 07:26 AM.. |
04-16-2023, 09:33 AM | #149 | |
Rep 3,715
04-16-2023, 02:41 PM | #150 | |
Rep 7,542
Yeah if you have to gap down, you have to gap down. I didn't know that the nexsys kit doesn't fit the m2, that's interesting and good to know.
04-16-2023, 04:20 PM | #151 |
Rep 75
The nexsys fits the m2
2018 M2 with a few mods.
Charge, boost and inlet pipes, Nexsys, Stage 2 HPFP, Stage 3 LPFP, Stage 1 injectors, TC Klines, Phoenix intake manifold, Bend Calibration fuel filter, Turbosmart BOV, PTF BM3 Flexfuel kit, BM3 custom tune, xHP trans tune, CTS Boss turbo, Full SPL, diff bushings, motor & trans mounts |
F87source7367.00 |
04-16-2023, 04:32 PM | #152 |
Rep 7,542
Did you have to cut or modify anything?
Can the engine cover still fit with the new coils? Also the pnp harness wiring looks super short and strained, not sure if that is just due to the images.
04-16-2023, 04:49 PM | #153 |
Rep 75
no cutting, none of the wires are strained and I don't bother with the cover anymore.
F87source7367.00 ericlr1225138.00 |
04-16-2023, 05:19 PM | #154 | |
Rep 7,542
BTW will the engine cover fit if someone wanted to use it? Or would it hit the cables?
