08-25-2020, 08:07 PM | #133 |
Rep 618
I’ll chime in with regard to the altered timing. Some are starting from the premise that the burbles are a natural result of BMW’s ignition timing designed for performance, reliability, anti-lag, etc. I disagree with that premise. I believe that BMW altered the timing from what would otherwise be considered optimal solely to produce the burbles due to market demand. Therefore’ I argue that the altered ignition timing to produce burbles comes at the expense of overall efficiency and performance.
In support, look back in time to old car carbureted engines with mechanical ignition systems. The bangs and burbles let you know that your ratty old Maverick needed a tune up and timing adjusted. If it ran without burbles you had a good tune and were maximizing gas mileage, performance, and smoothness. I’d rather have the car with optimal ignition timing no what era or how it is achieved. Just my .02 adjusted for inflation since my dad’s ratty old Maverick graced the driveway. Last edited by Gizmo 335i; 08-26-2020 at 08:08 AM.. |
08-26-2020, 05:05 AM | #134 | ||||
Luxury at the redline :)
9108
Rep 7,563
I hate to impose but is anyone willing to check to see if disabling the burbles triggers any error within the ISTA's control unit tree - i.e. shadow codes.. Disabling the ASD has been known to be a byproduct of this... Thanx in advance.. |
08-26-2020, 07:26 AM | #135 | |||||
~Spyder
645
Rep 879
Drives: '19 M2C Hockenheim 6sp
I presume I'll use the Veepeak dongle + BimmerLink app and look for any error codes?
Skål från Sverige...via Texas y-all
08-26-2020, 07:49 AM | #136 | ||||||
9108
Rep 7,563
08-26-2020, 09:46 AM | #137 | |
~Spyder
645
Rep 879
I'll check later today and report my findings. |
Poochie9107.50 |
08-26-2020, 01:18 PM | #138 |
~Spyder
645
Rep 879
So I messed about BimmerLink and Veepeak BLE dongles- attached a few screenshots for traceability.
Side note A: I bought the car pre-owned with about 3400 miles (now I'm close to 4300 miles - it's NOT my DD and 1/2 the time I work remotely) so unsure if the previous owner did anything to the car. Side note B: earlier in Aug, I also turned on a few BimmerCode features, but decided to turn everything OFF. Question: I believe the way to turn everything to stock/OFF in BimmerCode is to go through each module and select the oldest backup available...which is what I did. Is that correct? I wish BimmerCode app had a 'default' mode that will turn everything to stock mode...as it stands its UX (user experience) and GUI (graphical user interface) are more convoluted that they need to be. Any-who, BimmerLink Scanning Features are as follows: 1. Error memory 2. Info memory 3. Permanent memory My results: - zero (0) PERMANENT MEMORY errors, - 2 from ERROR MEMORY front electronic module (D90D37)+ Central Gateway module (CD0487) - 27 from INFO MEMORY (see this link for the error log https://drive.google.com/file/d/1fLb...ew?usp=sharing). Does anyone know if these codes are indicative of major issues? I plan on taking the car to the dealer in a few months...not sure if these will flag my car? Regardless, Stephan @ BimmerLink provides 100% solid support and is always helpful, so I also reached out to him to see if those codes are anything to worry about. Cheers and Be Well everyone! Last edited by No_curebimmer; 08-26-2020 at 01:30 PM.. |
08-31-2020, 05:04 PM | #139 |
~Spyder
645
Rep 879
Another week using the BimmerLink's Sound Tuning feature in OFF position...no issues to report. Simply works as designed
I love how my bimmer now sounds. Risking to repeat myself, it keeps reminding me of my old 6 speed E46 330ci: clean sounding, w/ deep(ish) guttural overtones, truly sounds like the BMW engines of old, N/A not turbocharged (unless I push it if course, the turbos do spool up nicely closer to redline). I like it so much, I am trying to talk myself out of upgrading to a Dinan exhaust that I've been eye-balling... PS the only other feature I've also engaged: turned the exhaust flaps to always ON, but I kept the ASD ON. I can't complain...as I don't miss the immature (to me) burbles.
Poochie9107.50 |
08-31-2020, 05:08 PM | #140 | |
~Spyder
645
Rep 879
All cars seem to have some info memory errors, despite not being tuned or being messed about with their DMEs (I'm not tuned in any way, I coded out the darn burbles).
Poochie9107.50 |
09-04-2020, 10:12 AM | #141 |
Rep 1,424
Turned mine off two days back with BM3, its a absolute pleasure to hear the actual sound. A d I have my ASD off as well. I love deep loud exhaust but after my neighbor fitted MP to his M4C, I got sick of hearing the dam burble lol. Also bunch of kids around my area have the burble turned up on their cars so there was another reason I had to turn mine off. Before this I had it set to low setting via BM3 but now it's completely off. Will be going with the AA EQ when they are ready. Hopefully that will take help with the rasp noise.
09-04-2020, 01:04 PM | #142 | |
~Spyder
645
Rep 879
1. Dinan exhaust + x pipe 2. Or the equal length AA midpipe (I suspect it'll be about 1/2 the price of Dinan) ...and with the immature burbles turned off, either option should sound amazing! The only decision is: save some gold coins by going the EL AA midpipe route (and keep the cow udder) or Dinan exhaust (not quite full exhaust replacement as Dinan isn't going all the way to downpipes).
09-04-2020, 01:19 PM | #143 | ||
Rep 1,424
09-04-2020, 01:27 PM | #144 | |||
~Spyder
645
Rep 879
PS will either EL AA midpipe or the Dinan exhaust interfere with emissions checks or give a CEL light?
09-04-2020, 01:30 PM | #145 | ||||
Rep 1,424
09-04-2020, 02:38 PM | #146 | |
~Spyder
645
Rep 879
I've met my share of Trafik Polis |
09-07-2020, 05:46 AM | #149 |
Not great. Not terrible
7453
Rep 2,700
Just had a small bimmerlink update for Android..., ran down to check for burble removal..., not yet.
Current: 2024 BMW X3 M40i.
09-07-2020, 02:38 PM | #150 |
Rep 3
Reverse bimmercode mods before using bimmerlink?
I’m considering using bimmerlink to get rid of the burbles. Do I need to reverse the mods I made with bimmercode before using bimmerlink?
09-09-2020, 11:49 AM | #151 | |
~Spyder
645
Rep 879
Can't use one to undo features set by the other. Last edited by No_curebimmer; 09-09-2020 at 12:00 PM.. |
09-11-2020, 10:23 AM | #152 |
Rep 3
Thanks, but what I was asking was, can I use both Bimmerlink and Bimmercode on the same car? I.e. I’ve already coded out ASD with Bimmercode. Can I now use Bimmerlink to remove burbles?
09-11-2020, 10:33 AM | #153 |
Rep 32
