09-04-2023, 05:55 PM | #111 | |
The Seeker
14175
Rep 3,422
With 25K on my 2018, I think it's time I changed my diff and trans lubes (diff is slightly leaking as well, even though I'm super easy on the car). It looks like the Redline DCTF is what I'll be using for the trans, but what about the diff, do you recommend the OE SAF-XJ 75-140 or something superior? |
F87source7365.50 |
09-04-2023, 06:30 PM | #112 | |
Rep 3,844
F87source7365.50 ///MPhatic14174.50 |
09-04-2023, 06:43 PM | #113 | |
Rep 7,539
I don't think they would just spring that service on people when the car is in for work. It would be much better to have the item on the CBS system instead and now the car alerts and forces you to do the work. That's an even better way to milk their customers for more servicing work. Yeah I think these diffs just have trash seals, so you're probably going to have to replace them. Good call, I like redline dctf as well - I was supposed to do it a year earlier than my scheduled service this summer but I ran out of time so I am pushing it to next year. For the diff just run OE SAF-XJ just in case.
///MPhatic14174.50 ericold7.50 |
09-04-2023, 07:51 PM | #114 | |||
The Seeker
14175
Rep 3,422
Will do! |
F87source7365.50 |
09-06-2023, 08:31 PM | #115 | |
Rep 1,494
It is really simple. |
F87source7365.50 |
09-07-2023, 04:56 AM | #116 |
Rep 598
I changed my diff at 23,500 and my manual trans at 27,655. Using Redline DCTF in the trans, I, too, noticed improved shifting - not significant but noticeable. My car is mostly a track car at this point, so I wanted to be safe. I'll probably change it every other year or so (about 10,000 miles).
chris7197393.50 |
09-10-2023, 12:59 AM | #117 |
Rep 70
absolutely true! life span about 8 years- 80.000 miles, i say!
09-10-2023, 01:56 PM | #118 | |
Rep 70
then they told me that there is an instruction, which is never told to the customers, but there is, if someone wants to change his manual fluids to do it no more than 50.000 miles.and then at 100.000 . if you pass the limit of the 50.000 then don't it. when i learned about it i was at 50.000 miles so i did it.but now that i am at 100.000 i am thinking of it. because nothing changed.shifting is the same as before.its the design of the transmission in bmw . |
09-11-2023, 07:47 AM | #119 |
~Spyder
645
Rep 879
Drives: '19 M2C Hockenheim 6sp
Jumping on this thread…I normally like/prefer Motul stuff (just did a brake fluid flush with their RBF 600).
My M2C has just over 10k miles, and never had its manual transmission fluid flushed (don’t recall this being a ticket item at its 1200 mi break-in, nor a maintenance item during the 4yr warranty, which has expired) So, what do the experts say: Motul Multi DCTF or Redline DCTF? Price delta is negligible; I keep seeing many mention Redline, but I thought Motul has slightly better quality fluids (me thinks, but what do I know eh?). My beast is a weekend warrior, carving those world famous the Texas canyons (umm, I mean flatlands) not a track toy, so chasing ms on track ain’t my thing. PS I do have Auto Solutions SSK, med bushings/10% reduction - which IMO, has to be the best mod I have ever done. Would either Redline or Motul diminish that ‘bolt action’? Thanks y’all!
Skål från Sverige...via Texas y-all
F87source7365.50 |
09-11-2023, 12:14 PM | #120 | |
Rep 7,340
No_curebimmer645.00 F87source7365.50 |
09-11-2023, 04:48 PM | #121 | |
Rep 7,539
Different fluid won't dimish the shifter feel because that is a function of the mechanical linkages in the transmission - which is very nice on the autosolutions ssk. Fluid will make the notchiness go away which is really nice, because my car has always been notchy from 1-2.
chris7197393.50 No_curebimmer645.00 |
09-11-2023, 07:12 PM | #122 |
New BMW owner
328
Rep 846
Hate that 1-2 part of the shifting. Just couldn’t get it to shift fast to 2nd. My foot on the clutch is already heading up and my hand is just able to get it into 2.
2-3 is butter though. Would SSK solve that? Already on Redline. |
09-11-2023, 11:39 PM | #123 | |
Rep 28
Below is an excerpt from an email with their technical support staff: "As for our website recommending High Torque DCTF fluid, that is correct. The factory fluid as you had mentioned calls for a MTF LT-5 fluid and with regards to our Mutli-DCTF fluid, it meets the specifications of MTF LT-5, however, note that Multi-DCTF is a Technosynthese fluid, or a synthetic blend. Where our High Torque DCTF fluid is a 100% PAO synthetic Ester-based transmission fluid. The specs for MTF LT-5 is in fact a gear oil with a viscosity in the 75W range." The few differences between the two fluids include: - Multi DCTF – Technosynthese (Synthetic blend) - High Torque DCTF – Full synthetic PAO based with Esters
They did not comment on the composition of the full synthetic PAO blend with Esters. I'm certainly no expert but I doubt you will have issues going with either Redline or Motul. I've personally had no issues with running Motul products in my current/previous cars so I tend to stick with them when I can. |
09-12-2023, 01:46 AM | #124 | |
Rep 8,972
Is that a requirement in the US? Or can you use any brand that states it meets relevant BMW spec and still maintain warranty? (Approved or self stated) Aren't approvals mainly a marketing tool or is it all more honest and engineering led than that? Last edited by doughboy; 09-12-2023 at 02:40 AM.. |
09-12-2023, 01:49 AM | #125 | |
Rep 8,972
Went for redline instead which did state that. That has greatly improved 1>2 shift and all shifts when cold. |
chris7197393.50 |
09-15-2023, 03:39 PM | #126 | |
Rep 1,494
09-17-2023, 10:14 AM | #127 |
Rep 70
OEM fluid is ok. redline or motul are good but some oem fluids like this and brake OEM fluid are very good OEM fluids for normal use.but i insist there is no difference in shifting.maybe for first months then you don't feel any difference at all when cold weather comes.its the transmission design in bmws.
09-17-2023, 11:13 PM | #128 | |
Rep 557
As I posted 12mths ago, it had been a regular issue with the oem fluid commencing not that long after I bought the car new and continued even after replacing with oem MTF-LT-5 fluid @ 66K km. Changed to Redline @85K and the issue instantly disappeared. I won't swear there is any other ongoing improvement compared to oem but I'm 100% certain on the 1st gear selecting issue (which in fairness is an issue I've had in other cars). |
F87source7365.50 |
09-17-2023, 11:17 PM | #129 |
Rep 7,539
Personally I think the OEM fluid sucks. It seems to fade rapidly, with even a low mileage fluid swap yielding significantly smoother shifts. When I did my 6mt fluid after 4 years and 8-9k km I noticed a massive improvement in shift feel, so yeah I really don't like the stock fluid.
09-18-2023, 02:03 AM | #130 | |
Rep 8,972
The 1-2 synchromesh works better than ever with redline. Like yours, often when stationary had to select 2nd then 1st as 1st wouldn’t go in direct from neutral. I'm not a gear-slammer kind of driver, I'm a move stick against synchro, apply light pressure, wait, drop in. (All in a second or less). These bmw boxes respond well to that style and the Redline has reduced the syncro wait time to almost nothing in most cases. Generally it's better all round when cold too, but that could just be new fluid. Last edited by doughboy; 09-18-2023 at 02:09 AM.. |
chris7197393.50 |
01-16-2024, 02:25 PM | #131 |
Rep 1,389
Redline doesn't seem available in NZ. No Doubt could be imported at cost, does fcp euro stock? Have ordered from them before.
Liquimoly has a presence here and my garage use their oils, it's LT5 spec and appears as based on rather than fully synthetic? https://products.liqui-moly.co.nz/du....html?sku=3640 My car is now 38,000 miles. Occasionally get the can't get into first problem. Car is daily, no track, short commutes but engine does get to temp. Driven in anger now and then at a weekend. Thanks |
01-16-2024, 10:32 PM | #132 | |
Rep 7,539
If you can't get redline or dont want to import it, try motul dctf or motul dctf high torque. Honestly I don't like LM, so I don't recommend them at all, they seem way too over priced for what they offer.
