03-18-2023, 05:08 AM | #112 |
Rep 255
Before jumping straight to Stage 2+ MM, I wanted to take some logs of stage 2 MM with different E%. Just got home. Unfortunately Car turned into Limp mode on 6th pull.
First, I added 25% E85 and drove 30 minutes after the flash. Pulled 3 times, looks ok. https://www.bootmod3.net/log?id=6415...0b43b90e351ab6 Then added more to 34-35% E85 and did couple pulls, 1st pull everything feels great, car felt strong and consistant. https://www.bootmod3.net/log?id=6415...729bc86d8d36f3 2nd pull had a hiccup in between, exhaust had a really short burble sound(~0.1sec). nothing more. https://www.bootmod3.net/log?id=6415...0b43b90e351abe 3rd pull turned into limp mode https://www.bootmod3.net/log?id=6415...90c6177ea5458a I noticed overboosting issue, dunno why. other than that, everything else looks ok. DSC OFF. Sorry for posting Stage2 MM data in Stage2+ MM topic. thanks for helping. Diagnostic Codes below from both BM3 and Bimmerlink: |
03-18-2023, 07:32 AM | #113 | |
Rep 3,715
Also take a look at some of my logs and turn on some of the BM3 flex fuel parameters so we can verify that your flex fuel set up is working correctly. I would also send the logs to PTF. |
ericlr1225138.00 johnung4552.50 |
03-18-2023, 04:35 PM | #114 | |
Rep 255
I'm using bm3 IOS version. It looks like PTF disabled all (RAM) or flexfuel parameters for IOS version. I'll try to reinstall to see if it work. (Edit:It fixed after the reinstall) I was comparing your switchable stage 2+ E30 map test with my logs, parameters curves look similar. I couldn't see anything major happening. Maybe bc I'm running stock turbo/OEM 0.33''-0.35'' gapped borsch plugs? Let's see what PTF says and I'll do more logs next Monday. Have a nice weekend. BM3Flexfuel kit functions : sensor, map switching, anti-lag are working well. Tips: I followed your experience to wait 2min(surprisingly exact 2min LOL) after filling in E85 with engine on, also usually it will go up 3-4% after couple minutes driving/couple heavy throttle. very consistent. Last edited by ericlr1225; 03-18-2023 at 06:57 PM.. |
ZM22839.50 |
03-18-2023, 07:29 PM | #115 | |
Rep 3,715
ericlr1225138.00 |
03-19-2023, 12:25 AM | #116 | |
Rep 5,413
Drives: 2015 BMW 335i x-Drive Auto
IMO folks should start with stock plugs and stock gap and let the condition of the plugs indicate whether to go to a colder plug or a shorter gap. |
ericlr1225138.00 |
03-20-2023, 11:02 AM | #117 | ||
Rep 255
I still have a new set of NGK stock gapped ready for it. BTW, PTF respond my email and said they updated all N55-M2 maps and they are ready for downloading today. Halim said it will fix all the issues I addressed but he didn't mention what exactly was going on(probably related to boost) LOL./ |
ZM22839.50 |
03-20-2023, 05:43 PM | #118 | |
Rep 3,715
I see all the updated maps. Altho, the 2+ maps haven’t been updated. |
03-21-2023, 01:00 PM | #119 |
Rep 5,413
03-24-2023, 12:31 PM | #120 | |
Rep 255
I flashed MM v1.2 and turned bunch of RAMs on according to your logs. I also turn on Misfire Count Cylinder 1-6 to monitor. It's kinda happening randomly but mainly cynlinder 1-5-6.(misfired cyl 1&4 under high load last time). 2 times each cylinder during 15min normal driving. Other than that, nothing special, car feels good, idling perfect around 660rpm, no CEL. I'll try to gap down to 0.028-0.030'' first and update logs with new version map. Last edited by ericlr1225; 03-24-2023 at 05:52 PM.. |
03-24-2023, 12:49 PM | #121 | |
Rep 3,715
Another thought is maybe one of the plugs isn’t quite right. I might do an FCP Lifetime return order and gap the new set of plugs down to knock out two potential issues at once. |
ericlr1225138.00 |
03-24-2023, 05:19 PM | #122 | ||
Rep 7,542
ericlr1225138.00 |
03-24-2023, 05:27 PM | #123 |
Rep 3,715
ericlr1225138.00 F87source7368.50 |
03-24-2023, 05:32 PM | #124 | |
Rep 7,542
OP did you by chance use antiseize on your spark plugs? What kind of plugs are you using anyways?
ericlr1225138.00 |
03-24-2023, 05:44 PM | #125 | |
Rep 255
I don't know if they antiseized them or not. Plugs are OEM 330A, stock gap 0.032'', according to plugs discussion in N55 forum. Coils are Eldors. OEM EU6 injectors anyway, I'll try to log v1.2 map with new RAMS parameters this weekend without changing anything. Maybe there are some clues thru the data. Hope I won't blow it on freeway LOL. |
F87source7368.50 |
03-24-2023, 05:54 PM | #126 | |
Rep 7,542
1) If you used antisieze that is a huge red flag. These plugs are coated from BOSCH so that they do not require any antiseize and will never get stuck in the cylinders. Anti seize can get onto the plug tips and foul them, and then cause massive misfires. So you should check with your shop. 2) Did your shop register the new injectors? That could be another issue, because even stock replacement injectors are never exactly the same, all injectors have small tolerance differences so you must register them to the car.
ericlr1225138.00 |
03-24-2023, 06:00 PM | #127 | |
Rep 255
2) I just called them, and of course they said they coded it. To eliminate this, I scheduled another appointment next week to recode. Frustrating. Last edited by ericlr1225; 03-24-2023 at 06:39 PM.. |
03-24-2023, 07:13 PM | #128 |
Rep 7,542
The thing is you need to be able to read the numbers on the injectors to code them. So they might need to come out again, and that means new seals and couplers. I can't remember if they're on the boxes, but problem is you don't know what cylinder each injector went into, so a box is useless.
ericlr1225138.00 |
03-24-2023, 09:56 PM | #129 | |
Rep 179
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
F87source7368.50 ericlr1225138.00 |
03-24-2023, 10:13 PM | #130 |
Rep 7,542
Oh yeah that's right eu6's only need to have the small mixture adaptation reset performed.
ericlr1225138.00 |
03-25-2023, 12:04 AM | #131 | |
Rep 255
btw local shop called me and they confirmed 200% they coded as a standard injectors swapping procedure for every bmw. so I guess I need to trust them on this. Also I checked my log again, lambda and bank 1 seemed perfectly match up. I think it means two banks are pretty even also my A/F Ratio looks fine. What will happen if I add more E85 to E50mix to run Stage 2 MM, would it be better for ignition or even worse under my condition? Do you guys need me to flash to Stage2+ MM to log some pulls so that it could be easier to check data? |
03-25-2023, 12:20 AM | #132 | |
Rep 7,542
I literally just wrote up a review on protool: https://f87.bimmerpost.com/forums/sh...php?p=29968185
ericlr1225138.00 |
