12-11-2015, 10:00 PM | #111 |
Rep 763
12-13-2015, 08:15 PM | #112 | |
Rep 869
1. no it's NOT the same block, google pics of the engine bay, it looks completely different. It's already mentioned the closed case deck is different. 2. Again, only Forges crankshaft, crankshaft bearings, pistons and sparkplugs. You do know what those are right? Crankshaft can be the same size, just forged or cast. Bearings, pistons and sparkplugs are just a small components. Any current N55 engines can put the "S55 sparkplugs" in. I'd assuming crankshaft bearings and pistons would be the same size, most likely just forged to improve stability and performance of the component. So once again, no it's a completely different engine. Ps. Now turbo is a major component, components to run a twin turbo vs a single twin scroll turbo ALONE, would require many different major engine components. Haven't even got to the different radiators, different cooling system, different FMIC, different intake etc. etc.
12-13-2015, 08:21 PM | #113 | |
Rep 869
12-13-2015, 10:10 PM | #114 | |
Rep 833
12-13-2015, 10:50 PM | #115 | |
Rep 869
In terms of what else is similar? The M2 engine is 95% the same as the M235i. From what I've read, the pistons is actually the same as the standard N55 except for the top ring, and S55 spark plugs, which anyone can just switch. Basically, from the look of things, it's just stability and reliability reinforcement for a higher standard N55 tune. As a few 2ers have switched to the S55 spark plugs after stage 1 tune, which is producing more power than the M2. At the end of the day, M2 is all about handling.
12-14-2015, 06:38 AM | #116 |
Rep 2,404
Edit, looks like I was incorrect...
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
12-22-2015, 05:12 PM | #117 | |
Rep 700
As for the "Major different engine components" for a single turbo vs twin turbo setup. There are no modifications that need to be done to actual engine components (Head, cams, valvetrain, rods, pistons, crankshaft) just because one has one turbo and the other has another. When it comes to differentiating engines especially in terms of engine code designation, the engines internals are what define it not what cooling system is bolted up, or what turbo/turbos are bolted up, but the actual internals. So go ahead and make yourself a chart with a column for the tradtional n55 (not the one in the m2) and the s55 and write down what engine internal components are shared under the respective column. The m2 doesnt even have cast in iron sleeves like the n55 in the 35i's |
12-28-2015, 04:14 AM | #118 | ||
3161
Rep 9,134
12-29-2015, 02:37 AM | #119 |
Rep 83
First thing I did when I heard that vid was email Akrapovic. The U.K. Agent told me they will have an exhaust available from April/May. So should be the same everywhere.
12-29-2015, 03:03 AM | #120 | |
3161
Rep 9,134
12-30-2015, 05:28 PM | #121 |
Rep 2,856
12-31-2015, 08:27 AM | #122 | ||
Rep 13,167
///M is art ↔ Artemis
