04-22-2023, 12:13 PM | #1079 | ||
24528
Rep 191,521
VRSF offers a good intercooler with a high-density core. I also recommend you check out MAD/BMS, they offer high-density intercoolers as well, for a better price and support in my opinion.
04-22-2023, 12:29 PM | #1081 | |
24528
Rep 191,521
You can examine the 3rd and 4th gear datalog. If the Intake Air Temperature (IAT) increases significantly, causing a drop in timing, you must replace the intercooler.
04-22-2023, 12:33 PM | #1082 | |
Rep 323
Keep in mind I did this around late winter/early spring so the ambient temps were below 70 Currently running the vrsf 5" and fitment was perfect.....Running about 10deg above ambient while moving, does rise significantly while idling/going slow. Cruising above 35 and it drops back down to 10 over ambient... |
04-22-2023, 07:19 PM | #1084 |
Rep 4,218
Stage 2 is basically a Stage 1, Stage 2 plus is more on line with BM3 stage 2.
The VRSF, BMS, and MAD 5” are pretty much the same and should perform similarly, get the best deal. I would just wrap the charge pipe in gold reflective tape for additional IAT reduction. |
04-23-2023, 10:31 AM | #1085 |
24528
Rep 191,521
Good to know
04-24-2023, 05:09 PM | #1086 |
Rep 78
Currently stage 2 MHD on my F87 M2
Best FMIC / Chargepipe? I’m thinking ARM motorsports FMIC and charpipe, but am unsure of the fitment of the ARM FMIC. Thoughts? Also when I install the chargepipe and FMIC, do I need to upgrade the boost pipe and inlet? Thanks in advance |
F87Tomei270.00 |
04-24-2023, 05:38 PM | #1087 | |
Rep 165
Nothing wrong with doing extra though to reduce the risk of failure and the ability to capitalize the full capability of the car 👍🏾 |
04-24-2023, 05:40 PM | #1088 |
Rep 78
Gotcha yeah. I just need to see some first hand opinions on the fitment of the ARM FMIC. Heard it’s great performance wise but fitment can be tough and I wanna know for sure
04-24-2023, 05:44 PM | #1089 |
Rep 165
04-24-2023, 08:48 PM | #1091 |
Rep 165
It’s aluminum. The FMIC was a super easy fit too.
04-24-2023, 08:57 PM | #1093 |
Rep 165
Just running BM3 stage 1 91 octane. I live in California so I’m trying to stay compliant by not running a aftermarket DP.
As for the lag don’t really feel it with this car. This car feels always felt very much like an NA car to me. What I did notice with the FMIC is that there is a lot less power loss towards the top end. If you want to help with turbo lag, try changing out your DV. Turbo smart has a pretty solid one. The stock DV is known for turbo leak. |
04-24-2023, 09:23 PM | #1095 |
Rep 78
Anyone here buy ARM motorsports FMIC?
https://www.armmotorsports.com/colle...RoCqjUQAvD_BwE Reading through it says the core is 36% larger core than OEM so I assume that’ll help with cooling and have little lag hopefully? |
04-24-2023, 09:36 PM | #1096 | |
Rep 4,218
More frontal area cools better, so the ARM would do better than something like the VRSF 5” - but you may have to take off the bumper to make it fit. |
04-25-2023, 10:00 AM | #1097 | |
24528
Rep 191,521
Regardless of your option, both should meet your needs without causing any noticeable lag.
04-25-2023, 11:45 AM | #1098 | |
Rep 323
Race intercoolers will require removal of bumper/etc…Smaller ones will be direct fit and be gtg. Its like $350 and you can install it yourself..not that difficult…watch a youtube vid… |
04-25-2023, 11:47 AM | #1099 |
Rep 78
Yeah haha I know just trying to triple check, but I ordered the ARM Motorsports so 🤷🏽‍♂️
But I do have a question, the VRSF is 5” but I can’t find that on the ARM one |
