11-15-2018, 08:34 AM | #89 | ||||
Plenipotentiary
2614
Rep 3,046
11-17-2018, 11:14 AM | #90 |
Rep 780
Either way on the anti dazzle...I was referring to VLD. I'm not seeing a whole lot of response. Do you think this is a hardware issue? Mine is a January 18 build.
11-17-2018, 11:34 AM | #91 |
Rep 780
They are definitely different part #'s between the Euro and the USA....and that has always been the case with the LCI.... so how come some say that works...?
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo Last edited by GregoryK; 11-17-2018 at 11:43 AM.. |
11-17-2018, 01:22 PM | #92 | |
Luxury at the redline :)
9108
Rep 7,563
I have pre-LCI Xenon and had someone record me while drove in the back of them to test out the coding; seems both worked fine. No blinding or dazzle, just "dancing headlights." I can't speak for LED headlights but according to some, including this guy in Canada with a new M4 CS, it's fully codeable. Then there are others who say that new LEDs headlights doesn't work properly due to hardware differences, including the poster above.. No one car give a definitive answer on the subject. I am just as confuse as you are and I'm usually a nerd when it comes to these things.. : https://www.newtis.info/tisv2/a/en/f...ght/1VnXSt1qI7 |
11-17-2018, 04:36 PM | #93 |
Rep 780
Guess I'll just code it and see what happens. The LED layout on Lemetier's post look to be the same to my eye. I agree it is not as obvious as he states and also why would they go to the expense of making 2 sets of any part when they don't have to. Much easier and cheaper to code it out!
11-17-2018, 05:31 PM | #94 | |
9108
Rep 7,563
And also, LEDs generate heat that could shorten its lifespan.. There is actually fans inside headlight to cool the LEDs.. So why include unnecessary LEDs to generate extra heat, that's not really going to be used in the US or Canada. Now all this is just assumptions until someone actually has irrefutable proof. I am still not convinced there is a difference. I asked several times but lemetier refuse to share the source of his claim, so that LED PCB cluster he supplied could be from a UFO or maybe he's right and it really is from a US/Euro 2 series headlight.. : Without the proper labeling and source, it's still all up in the air.. https://www.bimmerpost.com/forums/sh...php?p=23947011 |
11-17-2018, 08:55 PM | #95 |
Rep 780
Well just VO coded my M2. Removed both 5AP and 8S4. The difference compared to the coding I did with Bimmercode is night and day. I'll go in tomorrow with Bimmercode and check the codes to see what they say. I couldn't really check out the Antidazzzle but Auto High beams seem way more sensitive. VLD is really great now and headlamps turning seem quicker to respond.
11-17-2018, 10:08 PM | #96 | |
Rep 801
Can you share exactly what coding you did? |
11-18-2018, 07:08 AM | #97 |
Rep 243
Drives: 2018 MGM 6MT M2
GregoryK thanks for the info. Is your M2 an LCI? Can you share your build month and the full specifics of your coding? Thanks!
11-18-2018, 08:42 AM | #98 |
Rep 276
I'm on the same boat. I have production date of 4/18. Wondering if should have the VLD and Anti dazzle coded or just the VLD?
2010 AW E90 335i M Sport
2012 GTR 2017 STi Limited 2018 LBB M2 DCT |
11-18-2018, 08:46 AM | #99 |
Rep 780
My car is a 2018 -1 build.
Straight forward VO coding: Saved the cars VO to the desktop. Removed the 5AP and 8S4. Then VO codes back 4 modules (FEM_BODY, KAFAS2, FLE(43) & FLE(44). I did not write the modified FA back to the car and made a backup copy of the original VO. As I said I have not tested the antidazzle as of yet. The VLD is perfect.
11-18-2018, 08:52 AM | #100 | |
Rep 780
We are thinking the next 2 days so will let you know how it goes. If it works it will be a guaranteed result.
randyt224.50 |
11-18-2018, 12:29 PM | #101 | ||
Rep 801
11-18-2018, 04:48 PM | #103 | |
Plenipotentiary
2614
Rep 3,046
For everyone else, image 1&3 are RoW ADB LED (16 1x1COB mounted vertically) shown with and without the Microoptic Lens. Image 2&4 are the Global Non-Adaptive and US/CAN* Adaptive LED Projector (horizontal mounted with PES reflector - 2x COB for low, 1x COB for High). *Canada legalized ADB in April and models capable of retroactive enabling with existing hardware can be done via dealer programming. Cars with HBA or KAFAS but lacking correct headlamps can be enabled after headlamp retrofit. |
11-18-2018, 05:19 PM | #104 | ||
9108
Rep 7,563
If you provide it, I will apologize for the back and forth and actually take your word for it. How hard is it to provide a link or photo? That's all I've been practically begging you for, 4th times already. Instead, you copy and paste some random photo with no context. What are we suppose to extract from that exactly ? At least I supplied a "Russian" technical training manual, in English Which is relevant and fruitful to the discussion. Anyone can spew any nonsense without backing it up, like I could tell you next year BMW is releasing flying cars, without any proof, there is no way to confirm that.. You're instead adamant about your claim and attempt to be condescending when I press you for your source of your information. I will ask again, where did you get this information? And please don't reply with another "opinion" piece. It doesn't do your credibility any favors and it just serves to confuse other members about this issue, even further.. LIKE THIS: Nothing mentions what you just claim. No "ADB" approved. See, I just proved you wrong with FACTS and it only took a me 8 seconds to do. http://www.tc.gc.ca/en/services/road...le-lights.html |
11-18-2018, 05:33 PM | #105 | |
Rep 780
I owned a BMW MINI and the headlamps did not move but the beam was all over the place with a way quicker response time than the BMW adaptive headlamps. What I think you are saying is that that the US/Canadian Adaptive LED headlamps cannot be tunneled to stop blinding the oncoming drivers. You are also saying that you are in some sort of government office that allows you to know this. Is this true?
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo Last edited by GregoryK; 11-19-2018 at 07:04 AM.. |
Poochie9107.50 |
11-18-2018, 05:41 PM | #106 | |
Plenipotentiary
2614
Rep 3,046
http://www.gazette.gc.ca/rp-pr/p2/20...ors43-eng.html |
11-18-2018, 06:01 PM | #107 | ||
9108
Rep 7,563
Canada is changing regulations to match with Europe, even though the US is reluctant to jump aboard. Interesting stuff. You could of saved a lot bickering by just supplying that info on Canada to begin with. That's the great thing about the copy & paste, dot.com era; it doesn't take much effort to prove your point. Can you please now provide any solid data on the supposed hardware difference between US/Canada and European spec headlights, which was the original topic.. I know there is a definite difference with Audi's US and Euro spec headlights but no one has a definitive answer on BMW's hardware, beside the different part number. Good to see Canada finally catching up to advance headlight technology, unlike the US. I guess my next "Euro spec" headlights will be ordered from Canada instead of Germany |
11-18-2018, 08:55 PM | #108 | ||
Rep 276
11-19-2018, 10:02 AM | #109 |
Rep 55
FWIW I used Bimmercode to get full adaptive functionality out of my ‘18 LCI and as far as I can tell it works perfectly. The headlights move all over the place and I’ve never been flashed by oncoming traffic. Not sure if this is the same way they work in Europe but it sure seems like it’s doing all the things as advertised.
I will say, though, that certain behaviors such as tunneling only seem to work above certain speeds, and obviously only on much darker roads which is hard to find living in a big city. |
11-19-2018, 10:08 AM | #110 |
Rep 55
I find that it also will only tunnel in very specific situations (following a car, at a certain speed and darkness, with no oncoming traffic). If I’m following a car and there is oncoming traffic it will generally just turn off the high-aimed light on the left side of the car. It tries to keep the right side aimed high at the side of the road, lighting up signs and stuff, pretty much all of the time.
