BMW X5
      12-24-2020, 03:37 AM   #89
QF8
Drives: X6M Competition 2021
Who would want a box on wheels ie X5M when you can have an X6M.
r33_RGSport13122.00
      12-24-2020, 08:23 AM   #90
evanaswan
Yngwie J Malmsteen
Drives: F93 M8 GC - G07 X7
Originally Posted by r33_RGSport View Post
Originally Posted by evanaswan View Post
Originally Posted by IND-Distribution View Post
Glad they arrived safely!
Question: Have these been tested on the F96 x6m. I spoke with MMS month or so ago and they stated not ready for x6m. I'm sure the fitting and set up are the same, but dynamics may be different with less weight.
I'm ready to lower this 4x4 look.
Done it. Here are the pictures of X6M that I've done.
Need this in my life.
r33_RGSport13122.00
      12-24-2020, 08:39 AM   #91
r33_RGSport
General
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Well, if MSS UK doesn't flakes out, I can have it under your Christmas tree tomorrow.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL"
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
QF8221.00
      12-24-2020, 11:28 AM   #92
Powerbeast
Powerbeast's Avatar
Drives: F80 M3 RarriRot
QF8221.00
      12-24-2020, 03:35 PM   #93
denaliman
denaliman's Avatar
480
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
QF8221.00
      12-28-2020, 11:13 AM   #94
evanaswan
Yngwie J Malmsteen
Did you get them in?
r33_RGSport13122.00
      12-28-2020, 12:29 PM   #95
r33_RGSport
General
Nope, I think they are on another COVID lockdown.
      12-28-2020, 12:56 PM   #96
Powerbeast
Powerbeast's Avatar
Best modification to the XM5
Appreciate 6
r33_RGSport13122.00
jsnkim320.50
GlennC321.00
X5MC_LI617.00
ed41393.00
155ND961.00
      12-28-2020, 05:01 PM   #97
QF8
Looks Great.
What difference has it made to the ride?
      12-28-2020, 05:31 PM   #98
Noneya
Drives: '21 X5MC, '14 X1 35i M sport
2021 X5MC  [0.00]
Forgive my ignorance, but how can you get a better ride with lowered stance? Don't the wheels have less travel and thus would have less space to absorb bumps?
Also, how much is the drop and is it possible to get these and NOT lower the car? I wouldn't mind a more comfortable ride, but depending on how much the drop is this could be a deal breaker for me.
      12-28-2020, 06:43 PM   #99
mokest03
mokest03's Avatar
Drives: F95 X5MCS
Softer springs....
2009 E92
2013 S4
2016 RRS SC
2018 440I GG
2019 M550i
      12-28-2020, 06:43 PM   #100
Tenac
Tenac's Avatar
4603
Drives: All
Better ride does not mean more travel or less. Its all about spring rate and shock absorption. These can be set to stock height.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
Noneya252.50
      12-28-2020, 07:25 PM   #101
xmanpro
Drives: 24 M8C 24 X6MC 21 M3C
Looks great! If you had to black out your rims, would you got matte black or gloss black?
2024 M8C; 2024 X6MC; 2021 G80 M3C; 2022 P992140
RETIRED: 2021 F93, 2021 F96,2019 F82 M4C, 2018 F80 M3C, 2018 F86 X6M- black fire, 2015 F13 M6, 2015 F10 M5, 2012 F10 550i M-Sport, 2012 F13 650i X-Drive, 2009 E60 535i M-Sport, 2007 E60 530i
      12-28-2020, 10:09 PM   #102
Powerbeast
Powerbeast's Avatar
I personally don't like an all black wheel but if I had to choose, Gloss black or semi gloss.
S68 X5MC274.50
      12-29-2020, 10:40 AM   #103
Noneya
2021 X5MC  [0.00]
Thanks - didn't realize these can be set to stock height!
Regarding your 2nd sentence - imagine having 0 wheel travel and it should be clear that the statement as you wrote it is incorrect.
      12-29-2020, 06:52 PM   #104
Tenac
Tenac's Avatar
4603
Drives: All
That is a rather extreme assumption but yes my statement is correct. I don't know of anything on the road that has zero, that would be plain stupid. My answer to you is correct unless you have zero... wow?
2015 M235 Manual
      12-30-2020, 09:57 AM   #105
Noneya
2021 X5MC  [0.00]
If you agree that it's incorrect for zero, you must believe in some weird discontinuity for your statement to be true for a small non-zero value. Discontinuous phenomena are very rare in nature and are all very special. Instead most likely result is that comfort continuously increases from zero and saturates for some large enough wheel travel (because bumps on the road have finite size and car speed is finite). So to answer my original question - this saturation must be happening before stock height and stock is presumably overly conservative.
In any case, physics aside, I perused the X3M forums where this has been out for a longer time, and most people there were seeing worse subjective comfort than stock if lowered by more than about an inch, so that'll be a good guess for X5M as well.
I need to do a bit more research on installers nearby, but this will be a very tempting proposition once I switch back to summer tires. I don't know if this is me just getting used to it, but ride seems pretty nice since I've switched to winter tires.
      12-30-2020, 10:20 AM   #106
Tenac
Tenac's Avatar
4603
Drives: All
That once again is not how suspension works... You are working off of extremes only with your comments. And no its not true that because you get closer to zero you are getting worse. You are not understanding the spring rate, or rebound.... My suggestion is you call MSS ask to speak with an engineer (they might have to call you back). It's not like you are going over to a Honda civic putting a torch to the spring and watching it get lower, you are asking about engineered parts designed for comfort and handling in mind. The MSS springs have 3 total rates built into them to allow for the adjustability.
2015 M235 Manual
      12-30-2020, 10:27 AM   #107
Noneya
2021 X5MC  [0.00]
Ok, if we can't agree on the very basic math and physics proposition of continuity of comfort as a function of wheel travel, then this discussion can't go any further. Thanks again for the original tidbit about stock height adjustment.
      12-30-2020, 05:32 PM   #108
evanaswan
Yngwie J Malmsteen
To those who have installed. I just moved from Orange County Socal to a lake house in South Carolina. I have a shop here that quoted me $750 for install on the MMS springs for the F96. I swear when I lowered my F85 it was $500 for install.
What are you charging or being charged for install? I feel like I walk in and $$$ signs are on my forehead. I'm in a major remodel on the home and addicted to carbon fiber so every dollar counts. Especially if my wife finds out.
r33_RGSport13122.00
155ND961.00
      12-31-2020, 10:28 AM   #109
xmanpro
I'm at around that amount for a quote I got at a local shop. The older cars didn't need to have all four corners done like these new ones from what I was told.
      12-31-2020, 02:18 PM   #110
evanaswan
Yngwie J Malmsteen
xbimmers
