05-16-2023, 02:25 AM | #67 | |
Rep 557
Just looking at the post above, OG LCI doesn't have the option to tick 'Shift Point Indicator', it on full-time (I turn off the efficiency stuff). edit: I just tried Enabled's coding using Bimmercode and got same result as samsamdar, the box/gear suggester disappeared altogether. Last edited by David.m; 05-16-2023 at 02:47 AM.. |
Enabled1424.00 |
05-16-2023, 09:45 AM | #68 |
Rep 1,821
I connected to samsamdar's car yesterday and have some info and tester data we'll be looking to try.
His cluster was actually on a newer firmware than mine. Same firmware ID as M2C, so this will likely be possible, pending some tests that I have planned.
05-16-2023, 09:46 AM | #69 | |
Rep 1,821
Well there's a small bit of hope that it would not be the firmware revision!
chris7197393.50 Fred Conoway365.00 |
05-16-2023, 10:36 AM | #70 |
Rep 7,537
Any idea if this will ever work on the OG m2 (pre LCI grey back ground cluster)?
05-16-2023, 11:10 AM | #71 |
Rep 1,821
I don't see why it wouldn't honestly. The clusters can show gear number just fine, but it'll be a combination of settings that tells the cluster where to get the data for it.
You can bet I'll be trying to figure it out on the pre LCI cluster too. Then the other lingering question would be is if the M3/M4 is more like the OG M2 (needing a bit more of something) or the M2C/S for it to work.
05-16-2023, 02:17 PM | #72 |
Rep 842
Enabled you are a coding madman!
Just confirming that your coding parameters worked on my 2021 M2C. Thank you (and all involved) for going through the process and figuring this out. https://drive.google.com/file/d/19qE...w?usp=drivesdk It's a nifty feature, much better than the (useless) factory function of suggested gear. Last edited by (K); 05-16-2023 at 02:38 PM.. |
05-16-2023, 03:19 PM | #73 |
Rep 1,821
Your gif is even cooler. Love it
05-16-2023, 03:27 PM | #74 | |
Rep 7,340
05-16-2023, 06:23 PM | #75 |
Rep 1,821
Well we confirmed that it's not related to any instrument cluster differences in OG M2, I just coded the cluster to full M2C, and made those changes, it still didn't show it. Sigh
I'm guessing the data stream is just slightly different from the DME to the cluster. The gear position sensor from transmission to DME is the same part number, so it's not that.
9
05-16-2023, 07:21 PM | #76 | |
Rep 7,537
05-19-2023, 11:01 AM | #77 |
Rep 1,821
Yesterday I noticed with the changes I described on page 2 that if you check the box for Shift point indicator on, it will show a completely new and improved gear suggestion method. (M2C / M2CS only for now. Still working on OG M2).
It's completely beyond me why it wasn't like this from factory.
05-19-2023, 11:57 AM | #78 | |
Rep 21
To confirm, there would be 3 changes to get to a display like this? SPA_ENABLE, SPA_IST_GANG_ENABLE, and Shift point indicator? |
Enabled1424.00 |
05-19-2023, 12:29 PM | #79 | |
Rep 1,821
-Shift point indicator checked on shows current gear and suggested gear smaller -Shift point indicator checked off shows just current gear and that's it
05-19-2023, 12:30 PM | #80 |
Rep 1,821
What was your previous car?
05-19-2023, 01:18 PM | #81 | |
Rep 21
A Focus ST. The M2 is my first BMW but it is pretty wild how many quality of life things are missing from it (android auto) compared to a 5year older Ford :-P |
Enabled1424.00 |
05-19-2023, 01:20 PM | #82 |
Rep 7,340
I think the F8x cluster shows it like that too if I’m not mistaken.
Possibly relevant thread: https://f80.bimmerpost.com/forums/sh....php?t=1058837 |
Enabled1424.00 |
05-19-2023, 02:06 PM | #83 |
Rep 1,821
It seems a bit of a hit an miss on F80/82/83 according to that thread too. But yea, something isn't sending the same type of data from the N55 DME for it to work like the S55 dme gear data. I need to look through the tune and define it further to see why.
05-19-2023, 02:27 PM | #84 | |
Rep 507
Drives: 2018 M2 6MT
Enabled1424.00 |
05-19-2023, 03:06 PM | #85 |
Rep 842
I believe it's just the factory recommendation for "best gear" (which we all know is comically optimistic). The coding doesn't change the recommended gear parameters, it just displays them along with current gear.
05-19-2023, 05:44 PM | #87 |
Rep 1,821
I can easily change the recommendation gear and rpm in the tune (it's different in efficient/eco vs. sport), but my comment was more about the delivery and display of the recommended gear.
jefe2000785.00 |
05-19-2023, 06:32 PM | #88 |
Rep 7,340
Do you think there's a way to change the car's default modes on startup? It drives me nuts that the M2C starts with steering in Sport.
