10-03-2023, 09:41 PM | #67 |
New BMW owner
328
Rep 846
Asking us wouldn't help you coz we've done it before. Some more than once. It could be just 30 mins for some of us to 4 hrs. Depends on if you're all ready and nothing gets in the way. you might get snag on the removal of the pipes. Hard for someone to tell you that. Best is to have the necessary parts and tools nearby.
10-03-2023, 09:46 PM | #68 | |
Rep 896
Drives: OG M2
mattr83229.00 |
10-03-2023, 10:06 PM | #69 | |
Rep 75
10-03-2023, 10:08 PM | #70 | |
Rep 75
10-03-2023, 10:50 PM | #71 |
New BMW owner
328
Rep 846
If my memory serves right, the 2 screws (stocks) are kinda short and rather small (gauge). I went one size bigger and definitely longer....plus the washer. I wouldn't "impact" those in as the brackets (part 2 & 3) where they are screwed unto is made of fiber reinforced plastic only. I believe some describes that as C-channel. That's also what keeps the new FMIC from going forward/backward I believe. I didn't need to make my washer that big bec what I did was put a nut (drilled inside thread) acting as a spacer and it sits on the huge space of the CSF's tab. This prevented the FMIC from moving and squirming itself out of the washer. If u can imagine that.
stock screws are apparently M6x20. I likely went course thread (possibly bigger) and 30+mm which would be needed in holding that significantly heavier IC. https://f87.bimmerpost.com/forums/sh...7&postcount=48 https://www.realoem.com/bmw/enUS/sho...diagId=17_0632
mattr83229.00 |
10-04-2023, 08:55 AM | #73 |
New BMW owner
328
Rep 846
If you want to be OC about the screws then skip the Allen and get torx that’s zinc treated or stainless. I didn’t care (ok at the time I did) and got the screws that would hold it up without dropping the IC.
Along the line of screws, u may want to get extras of those 8mm ones. The ones directly under the bumper that’s holding that black plastic pc. Those things rust and they snap. Winters aren’t going to be kind to those screws. There must be around 8-10 of them under.
10-04-2023, 08:57 AM | #74 | |
The Seeker
14175
Rep 3,422
I don't drive my car in the Winter months, so rust isn't an issue for me, but I agree with you, there are several under the car that don't work well with Winter salt. |
10-04-2023, 10:37 AM | #75 |
New BMW owner
328
Rep 846
Message wasn’t meant for you /Mphatic. I know that much coz your car is always spanking clean. . You’re on a diff level of OCness I can’t even compare. there’s no winter here but humidity is very high.
///MPhatic14174.50 |
