M2 Technical Topics >
Suspension | Brakes | Chassis >
BMW M2: Turner Motorsports Carbon Fiber Corner Braces review
| 11-24-2022, 07:24 PM | #68 |
Rep 8,603
Oh yeah they look great! Perfect if you like to upgrade your engine bay's looks!
https://f87.bimmerpost.com/forums/sh....php?t=2038326 |
| 11-24-2022, 07:42 PM | #70 |
Rep 8,603
| 11-24-2022, 07:46 PM | #71 |
Rep 7,477
Drives: 2018 M2 AW DCT
I have both also. It did increase the steering feel. I am happy I did it.
F87source8729.50 Sungillest113.00 |
| 11-27-2022, 02:04 PM | #72 |
Rep 1,646
Drives: 2015 Audi S6 | 2017 BMW M2 | 2011 E90 BMW M3
Very nice.
I too will be adding some custom corner braces in to add some carbon. I did add the M2C carbon u brace to help with adding rigidity. |
| 11-27-2023, 12:26 AM | #74 | |
Rep 8,603
Also, I would personally go for something other than a fixed strut brace (unless its the AFE one because it has superior rigidity to all others due to its very nice tubular design - but apparently it hits the engine cover so that's something to consider), because the strut tower bolts are single use (unless you have after market coil overs or camber plates) and that means every time you want to remove the strut brace you have to replace the strut tower bolts - which can get expensive and annoying. So I'd go for a 2 piece strut tower brace like the racing dynamics one.
ZM23387.00 |
| 01-24-2024, 02:41 PM | #75 |
Rep 1,771
How similar is the CF weave to the eventuri intake?
I'm considering infinity design intake, not saying they use the same CF but they're related products (same engineer). Deciding between matte for intake so it's different to the turner braces or keep everything gloss CF but we all know unless OE the weaves will be slightly different and I suppose, different weaves can be viewed as interesting too... First world problems right here folks |
| 01-24-2024, 03:35 PM | #76 | |
Rep 943
Drives: LCI M2
F87source8729.50 |
| 01-24-2024, 03:41 PM | #77 | |
Rep 8,603
Me personally I am not too concerned about matching and I went with a matte carbon intake from TMS and still have the gloss corner braces lol.
| 01-26-2024, 12:25 AM | #78 |
Rep 1,771
Wow very similar thanks for the reply guys.
I think either would work then matte intake or gloss and the gloss braces (wet sand then anyone?!) Hehe In reality we don't stare at the engine bay all that much but still nice to have it look...well... nice. |
jello227.00 |
| 02-04-2024, 10:37 PM | #80 |
Rep 1,771
Brace back in, I shoved it rearward so that the front mount holes are touching the bolts, I figured it's used in tension being CF hopefully so removed the play in that area.
So quite immediately you notice the whole car is taughter in feel is how I put it. It is noticeable. It feels like it's dancing on the surface a bit more without being skittish perse. Without the brace the car is more relaxed. Initial turn in very slightly sharper with CF in. With very abrupt foolish turning I feel the car 'tuck' more than I would expect, not sure what ramifications of this are..then again I didn't do such foolish turning without the CF hehe So I will continue taking it in and out as it's V easy. I feel it does do something. Enough to notice so at least 15% of something but probably not more than 25%!? Last edited by 3t3p; 02-05-2024 at 04:37 PM.. |
| 02-04-2024, 10:50 PM | #81 | |
Rep 8,603
| 02-05-2024, 04:38 PM | #82 |
Rep 1,771
I'd love to loan a set of turners and see if it gets you 80% of the CF brace or what it does tbh.
Still they're like six hundred bucks so you've got to be commited! |
| 04-17-2025, 04:59 PM | #84 |
Rep 1,771
Please help. It's unclear where the long bolt goes.
Looking at real OEM for stock steel part it appears it goes on the second hole location of counting from the front of the car as reference? Thank you Ok so long bolt IS second hole. Next question do I torque it down so much that these two area meet and sit flush? Currently suspended in the air... Feels like doing that will certainly load the brace unsure if good or bad?! Going to use stock bolts, wider washers and look more OE and contrast to the CF. Ahhh now wondering if one brace is warped? It's up in the air at strut tower mount point Vs the other which went down totally flat If I do the left brace top and bottom bolts first, I am then presented with it lifting on the outermost edge bolt location as so a few mm. Last edited by 3t3p; 04-17-2025 at 05:53 PM.. |
| 04-17-2025, 06:47 PM | #85 | |
Rep 8,603
3t3p726.50 |
| 04-17-2025, 06:54 PM | #87 | |
Rep 8,603
I dont remember if the stock carbon brace creaked, all I could hear was my ratchet clicking. |
| Bookmarks |
| Tags |
| bmw m2, carbon fiber corner braces, corner brace, turner motorsports |
