01-20-2020, 10:27 AM | #67 | |
Rep 7,539
Also, in regards to E50 I'd probably also run a top cylinder lube with that as well if you plan to use it full time just to avoid any additional wear and tear. I know alot of guys usually run a tank of gas in between every tank or two of ethanol to help with lubricity, but with too cylinder lube you shouldn't ever have to.
ZM22839.50 |
01-20-2020, 10:54 AM | #68 | |
Rep 3,715
01-20-2020, 11:00 AM | #69 | ||
Rep 488
ZM22839.50 |
01-20-2020, 11:08 AM | #70 |
Rep 3,715
01-20-2020, 11:38 AM | #72 | |
Rep 1,899
I'm layman terms basically the computer doesn't know the injectors are capable of more flow |
01-20-2020, 11:45 AM | #73 |
Rep 699
I didn't know that people were changing injectors. I was just referring to the pump itself. It seems that the stock injectors can flow enough to run the stock HPFP out of fuel.
01-20-2020, 12:05 PM | #74 | |
Rep 7,539
ZM22839.50 |
01-20-2020, 12:06 PM | #75 |
Rep 7,539
Still pretty new, but their hardware looks very nice, we will have to see as time progresses.
01-20-2020, 12:08 PM | #76 |
Rep 7,539
Yeah injector swaps are becoming a big thing now, xdi is making higher flow injectors.
01-20-2020, 12:14 PM | #77 |
Rep 3,715
Any recommendations on who to use and best practices for remote tuning when setting up both street & track tunes? Is it as simple as start on the dyno, and then log in the real world and make adjustments?
01-20-2020, 12:14 PM | #78 | |
Rep 1,899
01-20-2020, 12:39 PM | #79 | |
Rep 7,539
For me back in my Subaru days, I liked to start on the Dyno, so I don't have to have a phone or tablet in my hands while blasting down the highway, then having to pull over and wait to reupload tune revisions. The Dyno tune should be already pretty well dialed in for the street and track, but I always take a few logs on the street and track for the final fine tune adjustments to ensure its not too agressive my cooling system cant keep up on the track. Personally I only have one tune on my cars, and that's the track tune. The reason behind this is I like a consistent feel and I want to be familiar with the way my car behaves. If I'm so used to a street tune and have to readjust to my track tune every time I'm driving at the track, my laptimes will always suffer.
ZM22839.50 |
01-20-2020, 02:26 PM | #80 | |
Rep 3,715
F87source7365.50 |
01-20-2020, 04:44 PM | #81 |
Rep 7,539
01-21-2020, 06:26 AM | #82 | |
Rep 699
How do you account for the Supra pump then? No software needed yet flows more than stock. After the swap the vehicle starts right up. |
01-21-2020, 08:39 AM | #83 | |
Rep 3,715
Do the aftermarket pumps require a tune to run at all, or just to flow more fuel? For those of us with some warranty left, I’m wondering what an aftermarket HPFP does when you flash back to stock & lock the DME? |
01-21-2020, 09:00 AM | #84 | |
Rep 7,539
The car will not start or run if you have an upgraded hpfp.
ZM22839.50 |
01-21-2020, 10:46 AM | #85 | |
Rep 1,129
Twisted Tune will take your money and offer 0 service. Good luck getting hold of them! They are as twisted n crook as their name suggest! |
01-21-2020, 11:39 AM | #86 | |
Not Mids
64
Rep 85
I can also confirm the Fuel-It flex fuel kit with BT analyzer has been working well at calculating my fuel as I am also spot checking at the gas stations and has been consistent. I will continue to check it over time esp once I start mixing fuels more regularly. XDI-35 on the first Jordan tune 91oct map has the car pulling very strongly in normal driving conditions and throughout the power band. More to come and I may start a little build thread if anyone is interested in my tuning to E40-50
2013 135i N55 - FBO
SOLD 2020 X3 Competition - Alpine white, dp + stage 2 SOLD 2018 LBB M2 FBO, Pure Stage 2 turbo |
ZM22839.50 |
01-21-2020, 12:55 PM | #87 | |
Rep 7,539
01-21-2020, 01:16 PM | #88 |
Not Mids
64
Rep 85
Thank you, was this plug and play?
2013 135i N55 - FBO
