| 08-30-2018, 07:51 PM | #68 |
Rep 132
I just did a quick search on google and found this so with more research i could find other kits cheaper
2011 BMW X1 28 (sold)
2013 BMW 328 Sportline (sold) 2018 BMW M2 LCI (current) |
| 07-05-2019, 12:15 PM | #69 |
![]() ![]() ![]() ![]() 613
Rep 691
Hey everybody, I just did the Porsche GT3 air ducts in stall on my '18 F87, and wanted to leave the installation video and couple of pictures here in case anyone else is going to attempt a DYI in the future.
Buy the duct kit here: https://www.ecstuning.com/b-genuine-...hoCpuMQAvD_BwE Picture of the original air ducts as well as the modified ones,including tools needed for the install: |
| 07-05-2019, 03:32 PM | #71 |
![]() 189
Rep 299
+1 thanks for sharing !
does anyone know..does the Porsche have the backing shields similar to ours ?? How do they channel the air flow toward the center hub ? On our cars, Its hard to imagine that sufficient air will actually get to the hub center with the shields in place and unmodified. |
randyt224.50 |
| 07-05-2019, 07:33 PM | #72 | |
Rep 691
| 07-16-2019, 09:48 AM | #73 |
![]() ![]() ![]() ![]() 568
Rep 603
Completed the long overdue brake duct diy over this weekend. Wasn't too bad, took about 3 hours taking my time. Had to buy a few new tools (oh no) including a drill, some bits and a hole saw and an assortment of parts. The parts totaled about $200, add another $100 for new backing plates if you ever want to return to stock.
I'll be at Limerock for the PCA event this Monday to see if this makes a material difference. I fear my testing will be anecdotal as I don't have a way to measure a difference and my calipers have long turned black. I hope that at least these ducts help prevent cracking of brake pads, which has become a problem recently. I got guidance on everything from the following post, although I think his duct mounting points were better located: https://f80.bimmerpost.com/forums/sh...=brake+cooling |
bentom2347.00 |
| 07-19-2019, 06:34 PM | #75 |
Rep 35
Drives: 2017 Mineral gray M2 DCT
I got tired of make-shifting some brake cooling ducting and finally dove in the rabbit hole! I found a set of M4-GT4 brake ducts from a racing friend of mine and decided to make it work on my M2. It took some work, taking off the front bumper cover and all related shields, etc. plus modifying a few areas to get the duct through, but I think I have some decent brake cooling now.
It consists of a 2.5" hose from the front of the nose with the M4 scoop, and a 3" hose from a scoop under the A-arm. The GT4 backing plate replaces the stock shield, is carbon fiber, and has provisions for both the 3" and the 2.5" hose. The scoop is plastic and is one I had lying around, not part of the GT4 setup. I did cut out the bumper cover to fit the GT4 small scoops for the 2.5" hose, but I'll get over it. The M4 nose is not exactly the same shape as the M2 nose, but I think it looks OK and it works. All this is after I gave up on the stock M2 brakes and went to AP calipers and rotors. Just thought it might be of interest to some of you guys. |
8
bentom2347.00 skier_du159.50 mcvaughan710.50 GasBurnlife(landapanda)613.00 M2guru661.00 subliminalaudio325.50 sly1types499.50 E90convert467.50 |
| 07-20-2019, 12:24 PM | #77 |
Rep 35
The CF backing plate replaces the stock backing plate, and the two hoses are directed into the eye of the rotor, not onto the rotor itself. I blew air into the front of the car and could feel it coming out of the vents in the rotor, so it works. I'll try and get a pic of the CF backing plate and post it.
| 08-31-2019, 07:42 AM | #79 | |
The G8X is a disaster. 🤮
910
Rep 988
https://f80.bimmerpost.com/forums/showthread.php?t=1379690&highlight=Revozport I tried it, and I’m picking up the front scoops again soon. I still have the rotor shields as well (including the one with a bit of burn through), but I plan on modifying the stock aluminum shields with duct connections. |
| 09-10-2019, 08:48 PM | #80 |
Rep 2,584
Installed the 997 Turbo Rear Brake Cooling Duct Kit. Figured the additional rear cooling couldn't hurt. Slight modification needed for clearance.
mcvaughan710.50 E90convert467.50 |
| 09-11-2019, 06:10 AM | #83 |
![]() 3387
Rep 4,180
I added the Porsche air deflectors to the rear a while back, but also cut away a quadrant of the backing plate so cool air can make it into the hat.
It surprisingly made a noticeable improvement. |
| 09-11-2019, 11:17 AM | #84 |
![]() 3387
Rep 4,180
If you cut the correct portion of the protection plate and align your deflector correctly, the air flows right into the hat where you want it—same as the fronts. You don’t have to remove the whole plate.
| 09-12-2019, 05:09 PM | #85 |
Rep 624
| 09-12-2019, 05:15 PM | #86 |
Rep 2,584
| 09-26-2019, 02:03 PM | #88 | |
910
Rep 988
Any idea where I could at least find scoops like you have connected to your lower arms? I’m not willing to cut my bumper just yet. Snaking the cooling hose through the narrow gaps between the body brackets and the various radiators doesn’t sound like fun, either. I’ve already spent a lot of time looking around the area inside the wheel arches trying to find a path for the cooling hoses, and everything is a compromise. Did the M4 rotor backing plates fit correctly on the 372mm rotors? |
| Bookmarks |
