M2 Technical Topics > Suspension | Brakes | Chassis > Brakes : best option to start on track ? RECAP
      07-23-2017, 03:49 AM   #67
OLO-M2
Belgium
38
I tracked it with the Ferodo and it was no real improvement. The Pagid are much much better !
StefanV35.00
      07-23-2017, 04:11 AM   #68
Franzino
Franzino's Avatar
Belgium
861
Drives: M2 MY17 / Alpine A110 MY19
Ferodo DS-2500?
      07-23-2017, 04:13 AM   #69
OLO-M2
Belgium
38
yes
      07-23-2017, 03:06 PM   #70
peterpeter
Drives: mini
thats weird
I have them on a nissan GTR and they are awesome..
that car is heavier so strange that they are poor on the M2-
others seem to say they are a good bet
just worried the pagids would squeal
      07-23-2017, 03:19 PM   #71
OLO-M2
Belgium
38
The Pagids squeal less and are more performing, at least on my car ;-)
      07-25-2017, 03:45 PM   #72
M2 Belgium
Update on my car. After 2 calm trackdays I had the brake judder problem. After reading up on the problem I thought it was pad deposits on the rotors. These were clearly visible. Brought the car in at BMW and after measuring the 2 rear discs were warped and past the acceptable tolerance. Fronts just within tolerance. Discs will be replaced under warranty....
      07-25-2017, 04:38 PM   #73
OLO-M2
Belgium
38
Excellent news !
Haven't they argued when they noticed that you drove on track (eg tyres) ?
Did you still have your OEM pads or already swapped with Pagid or Ferodo ?
Would be nice if you could send me some info by PM as I might need the same approach in the same country and some references might support the case ;-)
Thanks !
      07-26-2017, 04:36 AM   #74
Franzino
Franzino's Avatar
Belgium
861
The squeal on mine is less impressive than with the Ferodo DS2500. I also drive it daily
So your RS-29 pads make less noise then Ferodo DS-2500 on the street?
      07-26-2017, 04:37 AM   #75
Franzino
Franzino's Avatar
Belgium
861
yes
Ferodo DS2500 is not a dedicated track pad...I would never use it on track.
      07-26-2017, 04:53 AM   #76
Franzino
Franzino's Avatar
Belgium
861
I have done 3x Nurburgring trackdays with the following brake set-up
- Endless ME-20 brake pads
- Steel linings
- ATE blue racing brake oil
Verdict: zero brake fade, zero judder, good bite, good brake balance, no problem when switching back to the OEM pads, a lot of noise (more then RS29)....
Trackday 3 @ Nurburgring
      07-26-2017, 08:35 AM   #77
OLO-M2
Belgium
38
Yes indeed !
      07-26-2017, 08:38 AM   #78
OLO-M2
Belgium
38
- Steel linings
Do you ride with the OEM rims & tyres in 19" or have changed the rims and use other tyres ?
      08-02-2017, 03:41 PM   #79
M2 Belgium
Excellent news !
Thanks !
They didn't even mention they noticed I was on track. Just brought it in, drove with the mechanic and they submitted a warranty claim at bmw. They made a video of the tolerances on the discs. Now just waiting for them to come in. Not in stock...
Still have not switched brake pads as I can't find the time.
OLO-M237.50
      08-02-2017, 04:54 PM   #80
Franzino
Franzino's Avatar
Belgium
861
OEM rims + OEM Michelin tyres....car is full stock besides UCP clutch pedal, Endless pads, steel brake lining, other brake oil and NO ASD
OLO-M237.50
Bosozoku695.00
      08-02-2017, 04:56 PM   #81
Franzino
Franzino's Avatar
Belgium
861
The noise of my Endless ME-20 pads is driving me crazy on the street, I need to find an hour time to switch them back to street pads....
OLO-M237.50
Bosozoku695.00
      08-03-2017, 05:32 AM   #82
OLO-M2
Belgium
38
The Endless seem particularly loud indeed (based on your video) ! The Pagid are rather OK. I have just switched back to OEM as I won't track it before 2 months and it remains though the best option for daily ;-)
      08-03-2017, 11:34 AM   #83
wolfbane1967
Where did you buy steel brake lining ?
      08-03-2017, 02:19 PM   #84
OLO-M2
Belgium
38
I ordered mines directly on Goodridge's website (but haven't installed them yet)
      08-03-2017, 02:32 PM   #85
Franzino
Franzino's Avatar
Belgium
861
Good ridge
      08-04-2017, 03:11 AM   #86
wolfbane1967
Great , Thanks guys
Porsche 991.2 GTS
      08-04-2017, 03:13 AM   #87
wolfbane1967
I also drives with other pads from Performace Friction, and man do they squeel on the street ;-) But hey, its a bit cool. Dont think the older Ladies think that tho . They turn there heads and holds for there ears
Porsche 991.2 GTS
