06-13-2017, 05:47 PM | #67 |
Rep 7
Had my first proper AutoX this weekend past with the new MP suspension bits added putting me into STU, combined with 18" wheels shod with RE-71Rs and the grip was pretty insane compared to the Contis. The RE-71R has a sharper edge at the limit but still quite easy to recover if you get over-ambitious.
More mods planned to prepare fully for the rules in STU but we already had 5 seconds on our nearest competitor in an admittedly light class. All I know is that my face hurt from smiling so much during and after competition! |
06-13-2017, 07:25 PM | #68 |
Rep 70
Drives: 2021 HS 6sp
I am running BS class with MPSS tires. I am not doing well against a Focus RS and S2000 on RE71's. I have dialed in the tire pressure at 34psi hot. If I push too hard i plow thru corners and scrub speed the wrong way, too late. I run Sport+ and tried all nannies off on one run and spun out on a 90 to 100 degree off camber turn. The braking on the inside in those situations when in Sport+ is a real help on tight turns. The DSC will cut power if the yaw sensor senses you are getting out of control. I am getting better at finding this fine line. When I get it right I will improve my time and the car feels balanced, smooth and fast. That said these other guys are beating me. I am assuming it is a driver problem, I have only been autoX'ing for two years but am interested in what others think and some tips.
One thought is to just run with all of the nannies off and feel the car. It might be ugly at first by I will get used to it and correct. Another thought is install KWv3's and some other goodies but the penalty in STU is large. Again appreciate any comments. |
06-14-2017, 06:14 AM | #69 |
Rep 3,361
Yes, absolutely. The ONLY way to drive the car is with DSC fully off. Otherwise you losing the ability to put power down when/where you need it, but also, just as importantly, with DSC engaged in any mode the car is teaching you very poor habits as a driver since it is constantly doing one-wheel braking, etc, as it tries to guess what is needed. This is one reason why many people who don't really have a lot of good experience at driving a powerful car immediately crash when they turn off DSC since they have built driving skills based on the car constantly trying to correct poor habits.
You have to drive the "real car" and develop the skills necessary to properly manage the throttle. Especially in autocross, throttle control is extremely important both adding it and reducing it to control weight transfer in order to keep the front and rear contact patches right near/at their peak tractive force limits as much as possible. I would suggest doing the Phase 1 and Phase 2 Evo school. The events are very well run, and you'll learn an enormous amount. Instead of cementing bad habits with practice, you can learn good habits and then practice them from now on. Regards, Chuck
Current Stable:
kvndvs59.00 |
06-14-2017, 02:38 PM | #70 |
Rep 70
Drives: 2021 HS 6sp
Chuck, Thank you! I looked at the info on the Evo site and will be taking a course in July. I also read most of the articles and they were very helpful.
06-14-2017, 03:25 PM | #71 | |
Rep 3,361
It's a oldie but still very useful: Andy Hollis' ten tips for autocross. I had already been autocrossing for more than 30 years when I took some Evo schools and their Extreme school more than 10 years back now. What a wonderful experience, and working with Mike (Junior) Johnson was really enlightening. Swapping back and forth with me driving and then him in my E39 M5 was a fantastic experience. I went from typically top 10-15 place PAXing to sometimes overall PAX FTD but always in the top 10 locally afterward in my old E46 and then later on in my E90 M3 in F-street.
Current Stable:
norberts84.50 |
06-15-2017, 07:24 AM | #72 |
Rep 177
CSBM5 with DSC fully turned off the throttle is not as responsive in sport +. However, so that is the case that the ECU will pull power even in Sport + if it detects a loss in traction?
Coming out of a fast corner I was going flat out once the car straightened up enough but it felt like power was being pulled. I mean normally flat out the torque feels very strong, it felt kind of gutless. Is this DSC pulling power? I'm going to have to try next event with DSC fully disengaged |
06-15-2017, 07:45 AM | #73 | |
Rep 3,361
Speaking of throttle response...I always have students place their car in the least responsive mode since that allows the most precise control over the throttle which is a very strong component of the ability to control weight transfer. When you're right near the limits in a long sweeper, for example, controlling the direction (overall slip angle) of the car is almost totally a function of throttle position (or should be). A jumpy throttle creates large changes in weight transfer with very little driver input which is the opposite of what's required (and can easily result in "losing it" with a very powerful car too).
Current Stable:
06-15-2017, 08:42 AM | #74 |
Mspired
186
Rep 346
Agreed - I run my E46 in standard throttle because sport is way too sensitive for throttle control in auto-x.
I find the Sport+ to be slightly too sensitive in the M2, while Sport is slightly too numb...somewhere in between would be ideal. That said - Sport+ and even MDM are absolutely pulling power without you realizing, and the car will not open up unless DSC is fully off.
..: 2004 E46 M3 Coupe 6MT CB/B
..: 2011.5 E90 M3 Sedan 6MT ZCP Slicktop JB/Speed Cloth ::: >E90 ZCP Build Thread Gone but not forgotten: 2011.5 E90 M3 ZCP DCT, 2007 E92 335i, 2006 E90 325i, 1998 E36 M3, 1999 E36 323is |
06-15-2017, 02:19 PM | #75 |
Rep 7
We experimented with Sport+ vs. Comfort>DSC off (long press to deactivate). In doing so we found that with DSC fully deactivated, the car was fairly easy to control in rotation and power delivery without intervention from the DSC at the last AutoX. A rear facing GoPro captured pretty sounds from the exhaust but more importantly documented several double ribbons of RE-71R rubber being painted on the tarmac as we went.
Lower (or more linear) throttle sensitivity=easier modulation; exactly what we wanted in a car that can make things happen at a high rate of knots when you are making it dance at the limit. |
BAN_M2C4195.50 |
06-29-2017, 08:19 AM | #76 | |
Libertarian
71944
Rep 4,035
The previous Mustang GT weighs around 3,650lbs with 412hp, it's in FS, the M4 3,650lbs, 435hp, it's in AS. |
06-29-2017, 10:08 AM | #77 | |
Mspired
186
Rep 346
It's going to be a tough battle with the C6 Z06 and M4. M4 isn't really competitive but it absolutely wops the M2 in power. Lol.
06-29-2017, 10:30 AM | #78 | |
Libertarian
71944
Rep 4,035
06-29-2017, 12:36 PM | #79 | |
Mspired
186
Rep 346
You went with M3/4 sizes? Manual or DCT? I was looking to go wider in width and take advantage of some slight downsizing in the sidewall. MT here.
06-29-2017, 07:07 PM | #80 |
Libertarian
71944
Rep 4,035
RE-71R's in most popular 18 sizes are available. I have a DCT M4.
06-29-2017, 08:14 PM | #81 | |
Rep 70
Drives: 2021 HS 6sp
I ran this weekend with all the nannies off, loved the car with no interference. I was throttle steering a bit to correct and balance any under steer. I have more to learn but the car was very balanced. It took me a while to turn all of the nannies off on my 135i also but once I did I was happy I did and it was easy to control the car. The suspension on the M2 is so much stiffer than the 135i, you can really feel the difference. I am going to the EVO class on a Saturday and the next day is a scheduled AutoX. I hope I have enough tires left for Sunday. |
CSBM52756.00 |
06-29-2017, 08:21 PM | #82 | |
Rep 70
Drives: 2021 HS 6sp
07-10-2017, 11:02 PM | #83 |
Rep 3,009
At last month's ax I noticed a few folks spraying water on their tires between runs to help cool them down. Does this really work?
When looking at the TPMS info my tires only increased in pressure from 35 to 37 and most were ~97°F, the left front was the hottest at 113°F. |
07-12-2017, 02:48 PM | #84 | |
Mspired
186
Rep 346
I do codrive the cars and would notice rapidly decreasing amounts of grip/increased wear when running the tires overheated. It all depends on your driving style, braking zones, course surface, ambient temperature, and elapsed time between runs...there are many variables. There's not much loss to trying it if you think it will help. Pick up a $5 sprayer from Walmart and bring it along next event. If you are spraying to cool and the tires do not need it, then you would be decreasing the temperature to the point where the tires need to warm again - which would be counterproductive. AX tires have an optimal temperature point where they are stickiest.
omasou2093.00 |
07-17-2017, 08:19 AM | #85 |
Rep 70
Drives: 2021 HS 6sp
I took the EVO class, 1st level. Great instruction and seriously qualified instructors. I could not do the class and then our local event the next day but plan in catching about 6 more AutoX events this year and putting this new info to work.
08-09-2017, 01:48 PM | #86 | ||
Rep 3,009
08-10-2017, 08:33 PM | #87 |
Rep 969
Seats are not comfort and convenience. If they were part of the ZCP package which puts the car in AS along with coilover suspension and whatever other bits, you'd need to have all those bits included. Cat back exhaust does not put you out of BS/AS. For a real run at STU, you'd have to put your car on a serious diet. I personally think a M2 can be competitive in BS even with limited camber, and with higher COG. Those folks looking solely at hp and weight really aren't getting it. The SAC looks at width, length, suspension, and consider real world limitations or benefits such as gearing, ability to overcome nannies etc.
Sold 2011.5 E92 M3 ZCP.
08-12-2017, 08:24 AM | #88 |
Rep 3,089
2004 BMW X3 [8.25] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Last weekend fun..
Follow me on IG
