12-01-2014, 09:56 AM | #67 |
Rep 365
Well, Porsche uses a mid engined design for their fastest race cars, so I think that says a lot. And the now nixed 960 was to be mid-engined. The rear engined design definitely has advantages but mid-engine cars rotate better and still have excellent traction. Even GT3s were struggling with understeer for years.
The Cayman is handicapped by less development and inferior design choices like the strut rest suspension. By contrast, Porsche continues to develop the 911 because that is what they are known for. So it's not at all a fair comparison. |
12-01-2014, 11:13 AM | #68 | |
Diligentia Vis Celeritas
559
Rep 1,476
Drives: 335i
Re: the interchangeability... I don't suppose the 911 multi-link rear suspension can be retrofit into a Cayman S, can it... (?)
Ahead of the curve for specF30
12-02-2014, 12:15 AM | #69 | ||
Enjoying driving
388
Rep 1,169
Anything is possible with enough $$$ But something that will be worth your efforts and money, no. |
12-02-2014, 05:36 AM | #70 | ||
Rep 898
Drives: '69 GT3, GT4, 1M, 912
The high polar moment of the 911 rotates more slowly- easier to balance, but slower all else being equal. However all else is not equal- the difference is swamped by the suspension design. The modern 911's rear multi-link is the most sophisticated suspension design in common use, while the Cayman's strut is the least sophisticated. It shows.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
12-02-2014, 09:13 AM | #71 | |
559
Rep 1,476
Drives: 335i
12-02-2014, 11:03 AM | #72 |
Rep 898
911. Cost-performance wise a modified Cayman may well be ahead at the autocross, everywhere else the 911 will take it for practical purposes. And even at the autocross I'd generally rather be driving the 911, particularly if you can stretch to a GT3. There is no good Cayman rear suspension solution that I'm aware of yet, so you'd be rolling your own. Or perhaps waiting for the GT4- it's not clear what that's getting yet, but I'm hoping for raised pickups at the very least.
12-02-2014, 04:15 PM | #73 | |
559
Rep 1,476
Drives: 335i
12-02-2014, 05:36 PM | #74 |
Rep 365
For the suspension, I think so or at least you could get pretty close, apart from the widebody and rear wheel steering (991 models), which could get pretty expensive to convert. This link may be helpful:
http://www.elephantracing.com/tool-b...n-overview.htm But this is kind of like my predicament with the 135i. Having not jumped on the 1M quickly enough, I ended up taking a 135i anyway thinking that I'd never drive the car hard enough for it to matter. I ended up spending $4k in parts + labor for the majority of the M3 arms/wishbones, bushings, and BMW Performance Suspension. I still don't have the rear camber links, wheel/tire package, strut tower brace, or steering rack, which would cost thousands more to fit. So oddly enough, I think it's a better value to buy the GT3 assuming the 911 you want is fairly new, but of course the used values are much more reasonable on standard 911s and they make better daily drivers as well. So I'd probably rather spend the money on a GT3 or only lightly modify a standard 911. Full conversion is too costly. Once you start looking into the drivetrain, it makes even more sense to get a GT3 from the start. Last edited by vantagesc; 12-02-2014 at 05:43 PM.. |
12-02-2014, 06:53 PM | #75 | |
Rep 898
You can make nearly anything fit, though you may well be better off simply buying a used GT3 Cup car or RSR. The street car parts can be found here: https://www.stuttcars.com/technical/pet/ It all depends on your goals. And the depth of your pockets.
12-09-2014, 01:43 PM | #76 | |
Rep 13,167
///M is art ↔ Artemis
12-09-2014, 05:06 PM | #77 | |
Rep 365
The GTS models (whether 911, Cayman, or Boxster) are basically option packages. No doubt they represent good value if you like what's included, but I think Porsche's marketing is a bit of a stretch. For example, on the GTS models, you get as standard a number of things that are options on the regular S models, plus some special (mostly aesthetic) bits.
Those are the main highlights, but there are some smaller items that I likely missed. So yes, you do get a few things that aren't available on the standard S model, but in terms of how the car drives, you can achieve more or less the same thing as a GTS with an appropriately optioned S. But the S will cost more and then you are still missing some of the GTS exclusive bits. Last edited by vantagesc; 12-09-2014 at 05:30 PM.. |
12-11-2014, 11:37 PM | #78 |
There Is No Substitute
1909
Rep 1,070
12-12-2014, 08:42 AM | #79 | |
559
Rep 1,476
Drives: 335i
12-12-2014, 04:59 PM | #80 | |
Rep 898
If you're not 'most drivers', on the other hand, the GT3 is a far more special machine than the Carrera. Fully redone suspension including new uprights, geometry, rear wheel steering which gives it unmatched agility and stability, bespoke tires tuned for the car, ballistic powerband with a soundtrack to match, etc. On the track or the autocross the GT3 is on another level. The GT3 as an experience is a whole different beast, and the market treats it as such. Carrera S depreciation has been over 2x the GT3s, and this was true even before the GT3 stopped coming in a manual. On the other hand the GTS offers a combo of practicality, speed an comfort that many drivers are looking for, but at a very high cost of ownership. It may be remembered as one of the last great manual 911s, but it will likely always play second fiddle to the 997 GT3 or the 50th anniversary edition. If you're looking for a GT car and are OK with the cost of ownership (likely far higher than a GT3) it's one of the best around. Personally, however, I find GT cars never inspire me as much as sports cars, and the GTS lacks enough of the GT3's DNA to get my heart racing as I'd use the car. Porsche doesn't make a bad car, the issue is finding the one that best matches how you'll use it. Porsche prices its cars as if faster is better, but the truth is that for most of us it's not. It would take a very specific customer for the GTS to be their ideal match.
12-12-2014, 10:02 PM | #81 | |
559
Rep 1,476
Drives: 335i
In my case, I would only be able to buy used; I did a quick search online and found some 2011-2012 models of both cars on sale with roughly the same miles, and the GT3s run about $50k more. Am I missing something?
12-12-2014, 10:45 PM | #82 | |
Rep 898
New GTS cost of ownership has in the past been quite high due to steep depreciation vs the GT3, though if you time a used buy right it could work in your favor. You'll need to look carefully, however, even counting cost of money. The 997 GT3 may have stopped falling; the GTS has not.
12-12-2014, 11:28 PM | #83 | |
559
Rep 1,476
Drives: 335i
12-12-2014, 11:34 PM | #84 |
Enjoying driving
388
Rep 1,169
To give an example to what Pete is mentioning: I bought my base 997.2 GT3 in 2010 for $105K at 2K mi. The last offer I had on it after putting 36K additional miles (3-4K track miles) was $92K at the beginning of 2014. 997.2 GT3 RS still has an asking price of over $130K, RS 4.0 is beyond $250K and some close to $350K (MSRP was $180K originally). I don't even know where GT2 RS sits, but it is probably beyond its original MSRP as well. Good to excellent 996 GT3s still command over $50K, its original MSRP 15 years ago I believe was around $95K.
The GT3 variants and RS variants of 911s almost never diminish in value, and the luckiest buyers are the 2nd and 3rd owners IMO. However, I do not believe this will hold true for the 991 GT3, we'll see. |
12-13-2014, 04:48 PM | #85 | |
559
Rep 1,476
Drives: 335i
What are your thoughts between a 2012 (997) GTS versus a 2012 (991) Carrera S in terms of a daily driver / weekend track car? In a few years, they should both be in the same price range as a new M2...
12-13-2014, 08:36 PM | #86 |
Enjoying driving
388
Rep 1,169
I'd recommend the 991S if you have to have a Porsche, but if it is my money, I would go with the M2 probably depending on what it turns out to be But than again, probably our objectives and what we are looking for in a new car are different.
12-14-2014, 01:47 PM | #87 | |
Rep 5,580
So supposedly the 991 is a lot more refined then the 997. I believe he said the 993 GT3 was a brutish every day car. The 991GT3 has handling that is physics defying and has reliability that neither the Lamborghini Aventador or McLaren MC's posses, though the new Ferrari's are built very well, still the GT3 has great reliability as a track car. Few months back a Youtuber Nick Murray was detailing a litney of issues with a 991, his story was widely repeated. Have no idea of what to make of his reviews. Was told some smart car guy collector types were not happy with the present Porsches; think it's a quality of materials, size, and overall sensation thing. The 993's seem to be garnering a following. Singer industries (Magnus Walker) and their 964 bassed cars, low volume but has really cemented the air-cooled models. Un-crashed air-cooled 911's of any year of course have a big following, how does that effect the water-cooled values, or does it? Then the news this week about the ECU's on the ZO6's dialing back power has reports of people backing out of deliveries this week. And few weeks back people were saying the M2 was what everybody was talking about at SEMA. Anyway, football is depressing so think will head out to the dealership and see if they have any M4's. |
12-15-2014, 01:58 PM | #88 |
559
Rep 1,476
Drives: 335i
What are your objectives for the M2 (assuming it meets expectations)?
