01-10-2022, 06:53 PM | #771 | ||
Rep 3,415
01-10-2022, 07:10 PM | #772 | ||
Rep 3,415
That said, I love coaching brand new novices. I find it super fun and rewarding to watch them go around a track for the first times. Under no circumstances will I ride shotgun or instruct a random intermediate / advanced HPDE driver. I value my life over free track time. Regarding audio cues, I can't hear shit over my straight piped s65. Generally the cars around me can't either.
OG Shark4776.00 |
01-11-2022, 09:51 AM | #773 | |
4776
Rep 2,570
God bless you guys that run the straight piped S65s - you are doing the Lord's work there with that sweet symphony. I have to muffle mine a bit - just a bit too much for me during those long runs. Hoping my new earpieces really make an improvement though & might be joining you dumping the mufflers
DRLane3997.50 |
01-11-2022, 10:15 AM | #774 |
Rep 155
Has anyone experimented with different disc sizes?
Thinking of moving to a 390x36mm ap racing disc next disc swap, instead of the 378x36mm I'm currently running. The 450PS M2CSR uses 390mm while the 350PS version uses 378mm. Originally I had no idea a 390mm would fit in my 18" wheels, but apparently it does. Is a 12mm increase in disc size worthwhile in terms of cooling? I don't think it will make a massive difference to my brake bias. I'd have to buy new caliper brackets and hats too. |
01-11-2022, 10:33 AM | #775 | |
4776
Rep 2,570
01-11-2022, 11:07 AM | #776 |
Rep 155
CP9660+CP9449.
No fade at all. DS3.12 pads, no brake ducts. Around 18 track day old front discs now and they don't look like theyre about to crack. Rear is 355x32 disc and still looks new. (Same rears as the M2CSR). Have had to change front pads once on this setup while rear are still at 50% life. Usage only on GP circuits with a lot of trail braking. |
01-11-2022, 02:22 PM | #777 | ||
Rep 3,415
When driving to/from the track, I wear AirPods with noise cancel and listen to a podcast. Probably isn't protecting my hearing but I also don't rev out the car (much) on the roads.
01-31-2022, 02:01 PM | #778 |
Rep 155
Having trouble setting up my 3 way suspension. Been learning and experimenting with different settings over the past 3 trackdays. I think I have my high and low speed comp down now and moved to adjusting rebound.
My rear inside wheel is bouncing in long (>120kph) corner exits. Would that be too much rebound damping? I'm using the same clicker values front and rear. |
01-31-2022, 06:40 PM | #779 |
Rep 118
What suspension are you guys running? Been having a hard time deciding, have looked at everything from TCKline to KW CS to MCS/Nitron/etc and not sure what to pick. Looking for like 60/40 track/daily split.
01-31-2022, 07:08 PM | #780 |
Rep 296
Does anyone have ideas as to where to find 255-35-19 / 275-35-19 track tires? I've looked for Michelin, Hoosier, Toyo; most of the brands and cannot find a set in that size. Any leads?
01-31-2022, 07:57 PM | #781 |
Rep 484
01-31-2022, 08:02 PM | #782 | |
Rep 484
Track Forum General Chit Chat
To me, a major decision factor would be having a shop nearby that is competent with installation of the specific brand, and that can help with tuning the setup for your intended purpose. |
01-31-2022, 08:59 PM | #783 | |
4776
Rep 2,570
I might be a bit biased... but Nitron
01-31-2022, 10:46 PM | #784 |
Rep 296
The Yoko is all I can find. But these aren't much different, as far as I can tell, from the Sport Cup 2's I run on the street. I was looking more along the lines of the R7, Proxes RR, NT01, SuperCar 3R, etc..
02-01-2022, 01:31 AM | #785 | |
Rep 218
i just switched to a 18"x9.5 square set up and had a lot of options, including all of those you named. |
02-01-2022, 07:04 AM | #786 | |
Rep 296
I may have to give in and go to 18's in the end just to have better tire choice. What size tires are you using? |
neonbrown274.50 |
02-01-2022, 09:08 AM | #787 |
4776
Rep 2,570
The A052 is a good tire & would definitely take it over the 888
02-01-2022, 09:29 AM | #788 |
Rep 296
Thanks for the input. I can't decide however if the A052 is that much of an improvement over the Cup2's that I run on the car daily. If I get a set of dedicated track wheels/tires and go through the hassle of changing them out for events I'd like to go with the most aggressive tire that makes sense for me.
02-01-2022, 10:17 AM | #789 | |
Rep 502
02-01-2022, 10:52 AM | #790 | ||
4776
Rep 2,570
I run 18's on my comp since I have the Essex/AP kits on it. In Yokos I run 265/35/18 front on 10s and 295/35/18 rear on 11s. This is the setup I'll be running in Super Lap Battle at COTA in a couple of weeks.
02-01-2022, 01:07 PM | #791 | ||
Rep 218
02-02-2022, 03:26 AM | #792 | |
Rep 155
What clicker settings do you use on yours? |
