09-22-2023, 02:39 PM | #45 |
Rep 20
Im the same really, mhd stage 2+, fbo, in the uk 99 ron fuel, so the next step would be dorch stage 1 and custom map, but then you maybe want a pure 500 turbo
then its new clutch as i have manual , 3k in money down by that point . |
09-22-2023, 03:56 PM | #47 |
Rep 320
09-26-2023, 03:40 AM | #49 | |
Rep 896
Drives: OG M2
- Dorch Stage 2.5 - catless dp - CSF intercooler - Remus exhaust - flex fuel kit - Mosselman Thermostat
09-26-2023, 05:55 PM | #50 | |
Rep 255
I'm running same set up, E50 mixed, log shows 14.5 at the top. |
09-27-2023, 04:10 PM | #51 | |
Rep 896
Drives: OG M2
https://www.bootmod3.net/log?id=64d8...90c665e0b54449 https://www.bootmod3.net/log?id=64d8...0b439c89d42a04
ericlr1225138.00 |
09-27-2023, 11:54 PM | #52 | |
Rep 255
Did you upgrade DV and turbo inlet pipe? I know it's not much but boost may hold 1.5-2psi higher if you have those upgraded. Mine was holding 17.2 till 6760rpm. This version got dialed down the low end a bit than last version so that stock turbo wouldn't drop too fast on high end. But I still miss the old version for street driving, was 50lbft more @3500rpm Last edited by ericlr1225; 09-28-2023 at 12:08 AM.. |
09-27-2023, 11:56 PM | #53 |
Rep 896
Drives: OG M2
I’m only running e85 bc gas prices have gotten out of control here in California lol. But yeah the car runs absolutely phenomenal on this setup!
ericlr1225138.00 |
09-28-2023, 12:11 AM | #54 | |
Rep 255
So I skip the pump gas cycle and kept running E85 for months. LOL Did u test what's the maximum E you can run for your set up? |
samsamdar627.50 |
09-28-2023, 12:13 AM | #55 |
Rep 896
Drives: OG M2
Yeah bro I’ve been filling up with pure e85 - no issues with LPFP or EKP module
ericlr1225138.00 |
09-28-2023, 12:15 AM | #56 |
Rep 255
09-28-2023, 02:40 AM | #57 | |
Rep 3,715
Maybe someone can try E70-85 to see if timing moves higher. |
10-02-2023, 12:35 AM | #58 |
Rep 896
Drives: OG M2
There was def some 91 still left in there - I did that log on my first "full fill up" of E85
ericlr1225138.00 |
10-02-2023, 04:48 PM | #59 | |
The Seeker
14175
Rep 3,422
Elevation: 371' Temp: 84° BP: 30.17 Humidity: 49% https://www.bootmod3.net/log?id=651a...90c6d6d32f2c27 Last edited by ///MPhatic; 10-02-2023 at 07:33 PM.. |
AmuroRay2373.00 |
10-07-2023, 02:23 AM | #60 | |
Rep 255
I filled E85 to full tank with 1/6ish E50 mix left and got E73 according to sensor reading. Bootmod3 IOS app glitch still not fixed. (Doesn't save logs sometime and shift light doesn't work for couple versions) It only captured/uploaded last 2 pulls, all fuel cut. Stock turbo Dorch stage2 hpfp Stock Lpfp By looking at the logs, Ignition, Fuel, Torque Factor all hit 1.0 maximum. So I don't think it's necessary to fuel more E after. Timing hit 14.5deg, and all other parameters look same as E50 fuel. https://www.bootmod3.net/log?id=6520...90c6f5c6cfa101 https://www.bootmod3.net/log?id=6520...729bdf0865a532 |
ZM22839.50 |
10-09-2023, 02:08 PM | #61 |
Rep 896
Drives: OG M2
Lol I learned the hard way on Saturday that the stock EKP/LPFP combo is really not the move for full E85. I completely killed the OEM EKP lol. Gonna be moving back down to E50 for the time being until I can custom wire up an upgraded LPFP. I shouldn't have any issues running E85 mix with shit CA 91 right? As long as I'm above E30?
