11-20-2022, 09:44 AM | #45 | |
Rep 127
https://www.splparts.com/products/bm...-m2-m3-m4.html
1997 Dakar M3
1999 Cosmos M3 2004 Imola M3 CSL clone 2017 Alpine White M2 Performance Edition |
08-01-2023, 01:07 PM | #46 |
Rep 50
Anyone know if this kit is still offered?
Current:
16 M2, LBB DCT. 14 335 Sport Superman Spec, 06 Avant 6sp Many Things, 06 Range Rover Sport Supercharged Past: 13 RS5 Coupe, 04 M3 Vert, 95 URS6, MK6 GTI, 69 Chevelle Copo 427 clone, many Fox Mustangs |
08-01-2023, 01:35 PM | #47 |
Rep 7,539
Yes it should be, just pm Westersund.
Gotfuel16.50 |
09-01-2023, 01:55 PM | #48 |
Rep 882
Just wanted to let you know that I cancelled the Prusa XL because I got tired of waiting (15 months now) and bought a Bambu Lab X1 Carbon Combo instead. The good news is that I'm back to printing and getting to know the printer. I will soon take orders again but I have to crunch the numbers first. There will be a slight price increase but all metal parts will be painted and hardware (stainless hose clamps, bolts, nuts, washers and zip ties) will be included but not the hose. I will offer the kit with 2" or 2,5" fittings and the backing plates will come pre-assembled. I will also make a small design revision of the air guide to direct the air a bit more towards the center of the disc.
The printer is a sweet machine so far, love it! One of the first test prints and it will improve quite a bit. I can start the printer from home or from my phone now as soon as I get an order for faster delivery. I'll make an update in a few days when I know more. But the printer is runing pretty much all the time.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
09-04-2023, 03:59 AM | #49 |
Rep 882
I've looked over the numbers and the new price for a complete kit is 380$ and with the added 30$ you get all hardware such as bolts/nuts/washers/zip ties and all metal parts come painted and the backing plates are pre-assembled and ready for install. The first 5 who order a complete kit will recieve an additional bonus consisting of meshes and winter covers or intake enlargers (no it's not what you think it is you pervert lol).
On the contratry to what I said earlier about the hose clamps, those will not be included. The reason is that a package to the US cost about 22$ if it's under 2 kg, if I add the hose clamps (6x stainless hose clamps weigh a bit) I'm not sure I can squeeze the package under 2 kg and an up to 3 kg package cost 50$. The added value will be lost so I think it's better you buy hose clamps separately. Also I made a small redesign of the air guides to more effectivelly guide the air towards the center of the rotor. Red is the old and green is the new. Just have to verify on my car that it doesn't hit anything, but I think it will work.
09-04-2023, 04:06 AM | #50 | |
Rep 7,539
Westersund511.00 |
09-05-2023, 08:02 PM | #51 |
Rep 3,715
Great to see this coming along. Will this work with AP 9660 fronts and 378x36mm discs on an OG M2?
Could you please explain how you would run these on the street when not on track? Remove hose or just insert intake blocks? |
09-05-2023, 08:17 PM | #52 | |
Rep 7,539
Ok the street I believe you'd just put the little cover onto the scoop and zip tie it on and you're done.
Westersund511.00 |
09-06-2023, 02:10 AM | #53 | |
Rep 882
I will make a blocking plate for those who want to cover everything up, for whatever reason, but it's fine runing the cooling kit all the time. I've had my kit installed for 1½ years without an issue, but the M2 is only used 6 months every year.
F87source7367.00 |
09-06-2023, 02:19 AM | #54 |
Rep 882
I test fitted the re-designed air guide yesterday and it caught a little at full droop of the suspension and full lock. I will adjust the cut out a little even if it's unlikely someone would be in that situtation (full droop/lock) and if they would the knuckle catching the air guide slightly would be the least of theirs problems.
F87source7367.00 |
09-06-2023, 02:25 AM | #55 | |
Rep 7,539
09-08-2023, 01:38 AM | #57 |
Rep 882
I have them in 2"! The kit is offered in 2" or 2,5".
09-21-2023, 03:46 AM | #58 |
Rep 882
As promised, covers for the control arm ducts for those who want to leave them on for winter driving. Holes in the center of the cover to secure the cover onto the duct with a zip tie, the cover itself will fit snug but the zip tie is for 100% secure fit. Relief cuts for easier removal. 30$/Pair.
"Enlargers" for the ducts for increased air flow, guides on the back side for a snug fit and 100" secured with the same zip ties as the control arm ducts. 50$/Pair.
F87source7367.00 |
09-21-2023, 12:32 PM | #59 | |
Rep 7,539
Westersund511.00 |
09-25-2023, 02:19 PM | #60 |
Rep 882
Some closeup pictures of what kind of finish to be expected (good or bad is up to the beholder). Overall I think the finish of the duct is very good, the rough parts are a result of the use of support which is a must to print the ducts the way they will be the strongest. But the rough parts won't be seen anyway and won't reduce the function. Printed in Bambu Lab PETG.
The re-designed air guides printed in Bambu Lab PETG. 2,5" funnel for the backing plate printed in Bambu Lab PETG. I've put a lot of time into getting a nice and even finish on these, even if no one will ever see then after they are installed. 2" funnels printed with my last roll of HD Glass (won't use it again when the roll is empty) and I haven't gotten to the level of finish I have with the Bambu Lab PETG but I'm getting there. Nothing wrong with the function though. The new addons, the enlarger and the cover. Will make a slight improvement on the cover as it didn't sit as snug as I wanted even if the zip tie would hold it in place nontheless.
F87source7367.00 |
09-25-2023, 02:20 PM | #61 |
Rep 882
Might as well add that I have 2 complete 2,5" kits ready for shipping.
F87source7367.00 |
10-03-2023, 08:56 PM | #62 | |
Rep 3,715
Question: Why not build the enlarger into the original part and then have blocking plates for that single piece? Also curious if you have any specs for the hose and clamps, and basic install instructions. Thanks. |
Westersund511.00 |
10-04-2023, 02:25 AM | #63 | |
Rep 882
The hose need to be 70-80 cm long per side (depending on routing) and the hose clamps 60-80 mm (50-70 mm might work). I have instructions how to install the kit and it will be included with the purchase.
F87source7367.00 |
10-04-2023, 02:30 AM | #64 |
Rep 882
This is how the backing plates will be delivered now, these are the ones I sent out to Uncle Ben here on Bimmerpost last week.
F87source7367.00 |
10-04-2023, 03:03 AM | #65 | |
Rep 3,715
If you’re at the Ring this weekend, you could just hand them to me since I’m racing in the NLS race. |
F87source7367.00 |
10-18-2023, 03:17 AM | #66 |
Rep 882
Another update with some fresh pictures so I can update the first post. It's been a little slow but now 2 of the 5 first kit that will recieve a bonus have been sold.
Race backing plates in 2". Race backing plates in 2,5". Covers for the control arm ducts, second picture illustrates how they look installed (zip tie in the middle holes holds it securely in place). Enlargers for the control arm ducts, will be held in place with the same zip ties as the ducts. Front brake cooling kit in 2". Front brake cooling kit in 2,5". Front brake cooling kit in 2" including enlargers as per how they were sent out to g2 here on the forum. Front brake cooling kit in 2,5" including enlargers and covers as per how they were sent out to ZM2 here on the forum.
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 Last edited by Westersund; 10-18-2023 at 03:29 AM.. |
