07-09-2020, 05:04 PM | #45 | ||
Rep 7,540
It is up to you, but at this point I am unsure if your dealer even knows how to use the bmw etk properly seeing that they see SAF-xo linked to your vin... All I can say is you can check for yourself using bmw's etk (real oem) by putting your vin in, or look at bmw's TIS. I can tell you MSP/A will be coming up and not SAF-XJ. All the threads saying you need SAF-XJ is incorrect and based on residual information from the early days when the F8X launched (either through old forum threads or dealers that have yet to make the switch and are still making mistakes). The only acceptable fluid is MSP/A (as per bmw) which now may have had a p/n switch (still unsure). Again when you go in for the change tomorrow check the full part number the last 3 digits is irrelevant. But then again you will be able to see the bottle so you should be fine. I personally wouldn't let them put anything but MSP/A in since I know these diffs are finicky as hell. But at the end of the day it is up to you, if the dealer doesn't have it or insisits it being some other fluid you dont have a choice. Lucky for me if I request my SA to check with parts or service to relook at the TIS or ETK they will do it without questioning me, so I have never run into an issue like this before. Quote:
But no where did it say MSP/A was 75w90 it is 75w140. The link text is just misleading, the body of the site is correct.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 07-09-2020 at 05:19 PM.. |
07-09-2020, 05:09 PM | #46 |
Rep 7,540
My other fear in your case JustinHEMI is that your dealer might be one of the few that cannot get MSP/A so they are just resorting to SAF-XJ. If I were you I would ask them to go through the ETK right in front of me, but even if it did show MSP/A and if they do not have it you are pretty much out of luck.
JustinHEMI7453.00 |
07-09-2020, 05:22 PM | #47 |
Rep 7,540
JustinHEMI
https://www.realoem.com/bmw/enUS/select Put the last 7 digits of your vin into real oem, that will pull up USA (includes Canada) specific info for your specific car. Then go to rear axle -> rear differential/mounted parts -> item 11 and that will tell you what fluid goes in your car. Or you can call a different dealer and ask them. It is not the end of the world if it is SAF-XJ since it was used before, but bmw is making a switch to MSP/A and I do think there was a purposed behind this switch due to the huge failures in 2016 and earlier cars. So that is why im a heavy advocate of MSP/A or what ever bmw suggests to use. Normally I would not hesitate to go after market like for my manual transmission I am currently looking at motul or redline, but for the diff I am really unable to look past MSP/A since I know this thing has a track record of being finicky and failing. What is a big deal is SAF-XO, that is hugely wrong and not even close to what is supposed to be put in a LSD.
07-09-2020, 05:24 PM | #48 |
Not great. Not terrible
7453
Rep 2,700
Appreciate the further insights and tips.
All this confusion is why I may just change it to the castrol myself after they change it and document it.
Current: 2024 BMW X3 M40i.
07-09-2020, 05:31 PM | #49 | |
Rep 7,540
What fluid are they putting in it tomorrow? Can you give me a full p/n? Because as long as it is not SAF-XO or SAF-XJ + FM, and it is either MSP/A or SAF-XJ (not really preferred but should be ok) and you wont have to flush it to castrol syntrax. I also have to clarify I do not hate SAF-XJ but I prefer syntrax because it is suggested to be a suitable replacement by bmw. Also because I know castrol syntrax used to be named castrol SAF-XJ (or something along those lines) and when they reformulated it they changed names too so that is why I think syntrax would be a better fit than SAF-XJ since the forumlas could be more similar to MSP/A than SAF-XJ is. Sorry if that sounds super confusing.
07-09-2020, 05:32 PM | #50 | |
7453
Rep 2,700
Anyway, I called the dealer suggested above, and they used my VIN and said "83222365988," so I'm going to insist on that at the place doing the work tomorrow. If they can't, then at least I'll have documentation that they put the wrong stuff in to begin with, and then document why they flushed and changed it to what they did. Then I'll dump it and do it myself.
07-09-2020, 05:39 PM | #51 | |
Rep 7,540
And yes you will definitely want that documentation. Keep us posted and I really am hoping they have MSP/A for you, and I am hoping that your diff is ok and they messed up on documentation and not in actually filling it up.
07-09-2020, 05:44 PM | #52 |
7453
Rep 2,700
I will update what they do tomorrow. Thanks for all the tips and insights! I'm glad I saw this topic and checked my paperwork!!
07-09-2020, 05:46 PM | #53 |
Rep 7,540
Oh one more thing to note JustinHEMI when they do the flush tomorrow I would recommend them to tighten the drain bolt then fill the diff up and then drain, that is 1L. Then fill it up with the second liter drive to have it circulate, drain. Then fill with the 3rd liter. You really don't need 4 because the diff is 1.3L capacity and unless you remove the cover there will be a residual amount left over.
The reason why you want the drain bolt closed is because if they just pump in a whole 1 L and let it just run out you will not clear anything because the drain and fill bolt is situated in such a position anything going in will likely just run out without cleaning up anything inside. https://www.turnermotorsport.com/p-2...uine-bmw-part/ You also want to go on a quick drive so all the clutch discs and gears have the fluid circulate through to clean up all the old stuff.
JustinHEMI7453.00 |
07-09-2020, 05:50 PM | #54 | |
Rep 7,540
BTW: I checked your P/N for oil and filters, they both are good. You have 0w30 and the mann HU8011Z filter just like you should have gotten.
07-10-2020, 08:32 AM | #55 |
Rep 1,423
So spoke to bimmerworld rep, he said if we were to order the bottle from their site it would be the new bottle (pics above) package rather than what's listed on their site. He said 988 was replaced by 992, and sometime BMW don't label the bottle the same way, maybe different manufacturers when I asked him about MSP/A.
JustinHEMI7453.00 |
07-10-2020, 08:33 AM | #56 |
7453
Rep 2,700
Ok done at dealer. They did the flush the way I wanted and ended up using 3qts of fluid.
The 992 is the fluid called for according to their system and what was put in. Documents state why we had to flush and replace. I'm satisfied I'm covered from a warranty perspective, but I'm still going to reach out to BMWNA and try to get them to cover me longer. At the end of the day, I have Geico mechanical break down insurance so if this rear end dies after warranty, I'm still covered. I'll be keeping all documentation of this error and communication with BMWNA in my safe and electronically. May be overkill, but I am concerned about potential long term effects of the 1000 miles I put on it with the wrong weight fluid. After I drive it this weekend with the new fluid, I'll talk about a perceived difference I thought I felt a few days ago before I knew about the wrong fluid being in there. I want to see how she performs at the rally this weekend first.
07-10-2020, 08:48 AM | #57 |
Rep 1,423
Castrol 1543C9 and liqui moly 20042, seems to fit the bill.
07-10-2020, 09:02 AM | #58 |
Rep 744
You have never looked at the actual filters have you? the only delta is that one has M printed on it so they can ask from more MMMoney from you.
07-10-2020, 09:22 AM | #59 |
Rep 1,423
Now the question is i ran the 992 fluid for 20K miles, if I replace it with castrol syntax what procedure should I follow as far as flushing out old and in with the new? Thinking drain and fill, and change it again after about 1K miles. Any suggestions?
07-10-2020, 02:38 PM | #60 | ||||
Rep 7,540
Guys, first off I would like to make a request. Don't use the last 3 digits because the new MSP/A is also the same as saf-xj in regards to the last 3 digits, call it new MSP/A, old MSP/A, and SAF-XJ.
I forgot to ask you to take the fluid as a sample for oil analysis, that would've shown how much metal was in there and gave indication of wear. There's a whole list of compatible fluids on the link from newtis I posted on page 1. But yeah there's alot of compatible fluids. Quote:
Also I'm not sure how expensive it is where you guys are, but in Canada from lordco auto parts (an approved mann dealer) it is only a few cents (maybe 50 cents at most) more for the hu8011z. Quote:
Good idea, drain the old stuff, fill it with the Castrol syntrax and drive for 1000k miles (even a couple hundred miles should be more than good), drain and refill with new syntrax
07-10-2020, 02:52 PM | #62 |
Rep 7,540
Glad you got the incorrect fluid flushed out. Keep us posted after your ralley.
JustinHEMI7453.00 |
07-10-2020, 04:39 PM | #63 |
Rep 7,540
Ok this whole SAF-XJ vs MSP/A being used at dealerships has me a bit curious as to why USA dealers are having alot more difficulties finding MSP/A compared to Canadian dealers, since normally dealers in the USA have a wider access to parts compared to dealers in Canada and Canadians are the ones normally scrambling to find parts.
So I started to look at break in service threads, which is a huge hassle since very few people posted their invoices, but based on what I saw (not including early 2016 before the diff recall) Canadian owners and European owners are getting MSP/A. Alot of American owners are getting SAF-XJ. Below are some quick examples, you will probably have to scroll. But I am not sure why this is the case, especially since USA spec and Canadian spec cars are really similar and almost identical and are supposed to be using the same diff fluid. Plus MSP/A is shipped out of NJ iirc, so the USA should be able to access this quite easily. https://f87.bimmerpost.com/forums/sh....php?t=1542581 https://f80.bimmerpost.com/forums/sh....php?t=1438794
m20e30871174.50 |
07-10-2020, 09:23 PM | #64 |
Rep 7,540
Just wanted to point out that I was really confused with all the part numbers being thrown out yesterday and after rereading JustinHEMI's post and talking to m20e3087 again I realized there is no "new" part number for MSP/A. The part number listed on bimmerworld's site that was thought to be a new MSP/A is actually just SAF-XJ, so bimmerworld is being hugely misleading by selling SAF-XJ with an image of MSP/A.
So disregard all the talk about a new P/N for MSP/A if you are looking for MSP/A there is only one part number for it and it is: 83222365988
07-11-2020, 12:48 AM | #66 | |
Rep 7,540
Also when was this service done? I know in early 2016 there was still a possibility of using SAF-XJ because it was at the beginning of the transition period. Let me set this straight, SAF-XJ is not terrible though as it was used prior to the fluid switch without real issue so don't get me wrong as me saying it is the end of the world if you get SAF-XJ, it just isn't what is spec'ed by bmw as of now. What is the end of the world is if your dealer messes up and gives you SAF-XJ + FM (I have seen this happen alot) or even more rare SAF-XO (not even meant for the M LSD and not even the correct weight).
