07-15-2020, 10:09 PM | #45 |
3897
Rep 54,605
Drives: F80 M3
chief1richard383.00 |
12-16-2020, 02:44 PM | #46 |
383
Rep 731
To be sure, you mean complete new Camber Plates, is that correct?
At a Point above 7,000 RPM.
12-16-2020, 07:30 PM | #47 |
Rep 1,094
No, this thread is very old. It says directly on the Vorhlag web page that if you upgrade from OEM type spring to a coilover you just replace the perch part, not the whole plate. I don't know the cost but I'm planning to inquire when I go for coilovers.
12-16-2020, 07:58 PM | #48 |
Rep 132
The way they designed these plates with as little space available is incredible. Machining and tolerances are fabulous! Huge bearings for long service life and yes, if you run a OEM/lowering springs set they can swap out the lower perch if you go coilovers. Not sure if you can go the other way though?
Mine are set to 2.5 camber and zero toe for aggressive street. When I max the camber plate it goes to 3.4 and I end up with 1/16" total toe out. OEM shocks and Swift springs. 👍👍 |
chief1richard383.00 VicF87OG72.50 |
12-16-2020, 09:45 PM | #49 |
383
Rep 731
Thanks, I'm planning on putting on some Vorshlage Camber Plates after Tracking my M2 with Stock Suspension for three years now. I've taken it as far as I can in Stock form, and am ready to upgrade the suspension. Would be good if I could use them on Coil-overs down the road.
12-18-2020, 09:12 AM | #50 |
383
Rep 731
Vorshlag Camber Plates
Am about to install Vorshlag Camber Plates, and have researched the crap out of getting top nut tightened, which seems to be a common problem with installing these. All shock manufacturers state never use an impact wrench while tightening Top Nut. Vorshlag's Video says always use an Impact Wrench when tightening or it will cause bearing failure. I don't understand why using the proper Open end Socket Wrench and nut to prevent shaft from spinning is considered by Vorshlage to be the improper way to tighten this nut. Any installers with hands on experience have any input on this.
12-18-2020, 02:05 PM | #51 |
Rep 132
Richard, don't worry about getting the nut tight.
There's a lower strut shaft bushing that will end up butting to the top nuts once assembled. Bench assemble everything and you'll see what I'm talking about. Once it's in the car for real you'll hear your impact bottom out after a few bumps. I've got 250 mi on mine after install and it's perfect. 👌👌 |
12-18-2020, 02:39 PM | #52 | |
383
Rep 731
12-27-2020, 10:44 AM | #53 |
383
Rep 731
On the drop down menu what Strut Type would you choose if you had BMW M Performance Suspension? Is it same as OEM? Are these in stock?
12-27-2020, 03:04 PM | #54 | |
3897
Rep 54,605
Drives: F80 M3
https://www.hpashop.com/Vorshlag-F8X...shlag-F8XM.htm |
03-03-2021, 07:28 PM | #55 | |
Rep 21
03-03-2021, 09:04 PM | #56 |
383
Rep 731
No not on mine. Mine came pre assembled to Ohlins Coil-Overs. I took out OE Coil-Overs with Top-Hat still connected, and installed new Coil-Overs with Vorshlage Plate installed by 3DM Suspensions. You will need a set of Pass-Through Sockets for that.
03-01-2023, 05:14 PM | #57 |
3897
Rep 54,605
Drives: F80 M3
These are the latest and greatest Vorshlag camber plates for the F8X M2C M3 M4 using OEM style springs and struts.
