09-19-2023, 07:56 AM | #45 |
Rep 89
Drives: M2 Competition 6MT
09-19-2023, 08:56 AM | #46 |
The Seeker
14957
Rep 3,685
dead.pixel107.50 NathObeaN1526.50 |
09-19-2023, 11:13 AM | #47 |
Rep 17
09-19-2023, 11:14 AM | #48 | |
Rep 89
It’s not about how many he knows. It’s about the percentage. Let’s say he knows about 20 S55 cars tracked hard. If none of those had the failure then what is the failure percentage ? 0% Of course if you take all the S55 s there then there might be a failure or two, but that just proves the problem isn’t as big as it seems ( the whole point the thread was started ) . He filmed many videos with S55 M cars. He always asks about mods done to the cars by the owners. He’s got many friends there. The S55 taxis at Apex where Misha is a co founder (M3 and M4 ) both run stage 2 with the stock crankhub and they were tracked for hundreds and hundreds of laps and driven by pros at the limit. This is what I mean when I say Misha knows some stuff around the Nordschleife . No one was rude to you in this thread but in previous replies you claimed people want to pick fights with you. The problem is the way you reply. For example the fact you said my opinion is laughable is not that kind. You can disagree but I don’t understand what you’re trying to accomplish by disagreeing in a rude manner. I don’t care to be honest but I’m just saying. Anyway I’m not here to teach good manners. Thanks and have a good day. |
m2ss2123.50 |
09-19-2023, 12:19 PM | #49 |
The Seeker
14957
Rep 3,685
To suggest that a single person knows a significant percentage of M2 S55 owners just isn't realistic. I agree that Misha knows a lot of people, but reasonably you have to side with the number here. And again, even the guys he has spoken with would not always divulge these things, and BMW certainly will not because of a possible class-action.
It's just not possible to get these numbers, and even if we could we'd have to really dig deep into them with regards to mileage, mods, etc, to establish causality. It's just not feasible, and I would think that's pretty obvious. My apologies if I was rude, I just think the whole thing is obvious if you think about it for 2 minutes. BMW has the most/best information here, and they may not even know the exact cause, but they don't have to, they just have to change the design, which they did. |
09-19-2023, 12:52 PM | #50 | |
Rep 89
I respect your view on it. I never claimed Misha knows a significant percentage of S55 Owners. In the end it’s a personal thing whether you believe it’s a big issue or not.It definetly exists and there is countless of factors to take in consideration when debating this subject. On the B58/S58 the timing chain is at the back of the engine and we will never know for sure if the crankhub design changed because of the timing being behind or not ( maybe they decided to put it behind because of the crankhub failures, who knows ) But if the S58 had this crankhub design there is a high chance it would have been a big problem due to the power. |
09-19-2023, 01:08 PM | #52 | |
Rep 89
09-19-2023, 02:52 PM | #53 |
Rep 7,480
Take a step back and think about it. What if track use actually decreases the risk? There aren't violent kick downs, clutch drops, and drag racing on the ring. It's quite possible that the people that use S55 cars as track tools instead of driving like a nut on the street are actually at lower risk, which means this sample size Misha sees is biased.
09-19-2023, 04:50 PM | #54 | |
Rep 89
09-19-2023, 05:22 PM | #55 | |
Rep 457
Admittedly, I tend to judge if you’re past stage 1 power and you’re still sitting on stock suspension or “lowering springs.” |
09-19-2023, 09:48 PM | #57 | |
Rep 109
Drives: 2021 BMW M2 Competition
09-19-2023, 10:03 PM | #58 | |
The Seeker
14957
Rep 3,685
Put me also in the camp that thinks the F80/F82/F87 wasn't meant for actual racing, it's too damn big and top heavy. Of course, I would say that since my other car is an Exige, but still, let them haul ass in a straight line with springs only, it is what it is. |
09-19-2023, 10:54 PM | #59 | |
Rep 457
I do find it a bit funny you mentioned the F8x wasn’t meant for racing yet I see a lot of track built ones doing very well in their segment. Was even surprised when I saw the M4 GTS I believe it was impress Mischa on The Ring in a Turbo S. Coils definitely affect how you put down the power, I never forgot the day when I understood how they factored into launching off a straight and understood the hype of why everyone praised moving from the stock suspension to some form of an adjustable setup. I like power, I love controlled power more. |
Apexer92.00 |
09-22-2023, 05:36 PM | #60 |
Rep 1,072
I mean.. I had a 2021 S55 spin the hub just by turning the car on. 12,000 miles. 520hp. Never launched, Never used kickdown. Turned the car on and boom. It's fixed now and making well over 600
Instagram: M2_Medusa
09-22-2023, 07:54 PM | #61 |
Rep 1,358
Same issue on the NC Miata’s and they key the crank to lock it in place as the friction disc is not sufficient.
Albeit for cars that are driven hard, more power and hard shifting etc.
09-26-2023, 04:21 AM | #62 |
Rep 1,075
Drives: F87 M2CS / E92 M3
How hard had you driven on the last drive before you started it up again? Shame it happened but glad you're back up and running again. What aftermarket solution did you go with?
09-28-2023, 02:33 PM | #63 |
Rep 8,971
I've heard about a few spun hubs on startup.
Makes sense as the action of starting the engine is a pretty violent / instantaneous crank acceleration from standstill against the stationary valve train, all in the "undo" torque direction of the hub. |
09-28-2023, 03:41 PM | #64 |
Rep 7,480
I doubt it's that. If it's related at all it's probably because once the engine cools the metal contracts and less pressure is exerted on the failing friction disc. The dRPM/dT from a start is not high compared to operation.
09-28-2023, 04:00 PM | #65 |
Rep 8,971
Equal and opposite all things being equal. The hub may contract when cooling so reducing clamp force, but also the bolt will contract increasing clamping force.
The dV/dT is pretty high starting from zero V and over a very small T. And the static friction of the valve train is very high. Whereas revving an already rotating engine from say 2000-6000 rpm by throttle action will be more gentle. But agree, generally the more violent effects of harsh DCT downshift or manual money shift are likely worse. |
