05-15-2021, 09:12 PM | #507 | |
Rep 7,543
05-16-2021, 07:33 AM | #508 | |
Rep 258
05-16-2021, 01:29 PM | #509 | |
Rep 7,543
Stage 2 91 octane isn't impressive to see on Chevron 94, if it was real 94 they'd be able to run full stage 2 93 tune. Idk I might try it out if I feel like it, but I really don't want to mess with it. I recently talked to my old sti and frs tuner and he told me Chevron 94 was still absolutely sh*t in his experience.
05-16-2021, 04:44 PM | #510 | |
Rep 258
i dunno, something may have changed coz i remember 2 years ago i couldnt run chev 94 on a stage 1 dinan piggyback cos it ran like dog shit. but now im seeing members of my m2 club running it on stage 1 or 2 bm3 tune with no issues. youd still see timing pulls but not as bad as youd expect. |
05-16-2021, 06:22 PM | #511 | |
Rep 7,543
06-02-2021, 03:15 PM | #512 |
@lbb_kev
496
Rep 516
Just got the okay from Dorch to let everyone know that they will be starting production on the Stage 3 HPFP kit soon!
F87source7368.50 |
06-02-2021, 03:33 PM | #513 | |
Rep 7,543
If I get time I will revamp this whole thread to add pictures, and make it a whole lot nicer.
06-02-2021, 04:07 PM | #514 | |
@lbb_kev
496
Rep 516
Some additional information from Chris at Dorch: "As for the production kit, the final flow percentage gain number still may change, so that’s the only thing not set in stone. That call will be made in the next month here as we finalize more testing before ramping up production (finally!). The kit will come with a new flange and it will work with existing S1 and S2 kits, but depending on when the original HPFP kit was purchased, their pump may need to be sent in for an update service. This will most likely be free of charge with the purchase of the lift kit."
F87source7368.50 |
06-02-2021, 04:34 PM | #515 | |
Rep 7,543
This is so cool! I wonder if they'll make a "stage 4" with the s55 dual hpfp setup + upgraded hpfps for those who want to hit crazy 4 digit power numbers.
06-02-2021, 04:47 PM | #516 | ||
@lbb_kev
496
Rep 516
To "marry" the existing Dorch stage 1/2 pump to the upgraded vacuum pump you'll need to use a different flange size, which Dorch will provide. That said, like Chris mentioned, if you were an early adopter of the stage 1 or 2 pumps (Not sure when the date cut-off is), you'll need to send your hpfp in for servicing to support the upgraded vacuum pump, which is still a great option for these owners (No need to purchase a new hpfp).
06-02-2021, 05:14 PM | #517 | |
Rep 7,543
But if we are able to see another ~30% flow like the s55 is, that would be immense. Very good though on behalf of dorch to keep pushing the envelope for the n55.
06-02-2021, 09:50 PM | #518 | |
@lbb_kev
496
Rep 516
06-02-2021, 10:12 PM | #519 | |
Rep 7,543
Is that a total increase in flow or ontop of what the stage 1/2 hpfp already does? What is the percentage increase ontop of a stage 2 dorch hpfp? And how much will it cost? Those are the two important questions to determine if it's worth it.
06-02-2021, 10:22 PM | #520 | |
@lbb_kev
496
Rep 516
So if the stage 2 flows 75% over stock and hypothetically the upgraded vacuum pump yields an additional 40% of flow then 75% + 40% for a total of 115% total increased flow over stock with the stage 2 + upgraded vacuum pump set-up. Same exercise for stage 1 + upgraded vacuum pump: 45% + 40% equaling 85% total increased flow over stock. Will be interesting to see the final flow numbers for sure!
06-02-2021, 10:59 PM | #521 | |
Rep 7,543
You'll need an even larger EFR turbo. Plus injectors may once more become a limiting factor. Good thing a few companies (nostrum irc) are working on an injector upgrade.
06-03-2021, 11:06 AM | #522 | |
@lbb_kev
496
Rep 516
Another injector upgrade option like you mentioned would probably be needed at 650whp+ on full E85. The EU5 N55 or EU5 S63 injectors will pair well with the Stage 3 kit for the most part and will start reaching the limits of the injectors at around 600whp and 650whp, respectively (Based on conservative lambda targets). In our testing we're limited by turbo, the single Walbro 525 LPFP (Will confirm 100% once lpfp sensor is in), and then the EU5s S63 injectors in that exact order. Stage 2 HPFP + upgraded vacuum pump has not shown any sign of stumbling yet. A note on the LPFP side of things. At 620-650whp at E88-E90, my single Walbro 525 set-up is very close to if not at its flow limits. So if you're pushing enough to require beefier injectors than the EU5 S63s then you'll probably need to convert to a dual pump set-up for the LPFP side. The stages seem to line-up quite nicely.
F87source7368.50 |
06-03-2021, 03:28 PM | #523 |
Rep 258
Anyone notice on the bm3 app under the hpfp options that dorch has separate options for stage 1 and stage 2 pumps? I wonder what this calibration does. Is it to address the chirping sound? Anyways, i just flashed the stage 1 dorch option and im about to go for a drive. Ill let yall dorch peeps know if i notice a difference.
06-04-2021, 02:22 PM | #524 | |
Rep 3,715
06-04-2021, 03:02 PM | #525 |
Rep 258
I flashed via laptop. I noticed the same thing. I used my desktop to set up the config and saved changes with dorch stage 1 selected. Then i went to my car to flash with my phone but i couldnt see the changes i made there so i had to flash with my laptop instead. The chirp that i was getting at partial throttle around 1200-2000 rpm is almost gone though. I forgot to log but i think im seeing higher fuel pressures as well.
ZM22839.50 |
06-05-2021, 02:59 AM | #526 | |
Rep 415
Yeah you should see a higher fuel pressure, 2800ish instead of 2400 I believe. My chirp is worse when cold but still there when fully warmed up, getting a bit annoying now. I think the laptop version gets updates quicker than the phone app? I just checked my iPhone app and it’s still just as ‘Dorch’. I’ll hook the laptop up and see what it’s saying and report back. |
06-05-2021, 11:41 AM | #527 |
Rep 258
Yep im seeing 2800 psi. The chirp is very momentary now. Mostly on low speed high load throttle inputs. Is there anything else in this update other than addressing the chirp?
