06-16-2021, 11:11 AM | #24 | |
Rep 3,715
https://f30.bimmerpost.com/forums/sh....php?t=1824994 |
06-16-2021, 11:45 AM | #26 |
Rep 3,715
Trying to decide if I'll go ahead and set it up for manual switching b/n 93 & E50, or just wait until I've got an ethanol sensor installed for auto switching/scaling.
Are you guys still set on using Bend's ethanol sensor kit? Still trying to figure out if I need the Universal, Basic Bootmod3, or Ultimate kit? |
06-16-2021, 11:46 AM | #27 |
Rep 2,526
Debating on flashing this for a track event on Friday.
06-16-2021, 01:26 PM | #28 | |
Rep 604
My current plan is to get a custom tune with this new mapswitching with the below maps: Stock 91 93 E30
ZM22839.50 |
06-16-2021, 02:18 PM | #29 | |
Rep 3,715
Or, do you have to use one of the multimaps for steering wheel map switching? |
06-16-2021, 02:20 PM | #30 | ||
Rep 604
06-16-2021, 02:32 PM | #31 | |
Rep 3,715
Guess I’ll skip this feature until I get a flex fuel sensor installed to scale bn 93 & E50 automatically via one of the pre-defined multimaps. (I think it can do this?) |
02-11-2022, 05:38 PM | #32 |
Rep 10
Problems with bm3 flex fuel
Hey guys,
I installed everything as indicated per the instructions. Installations went smoothly and using the steering wheel controls I am seeing % of ethanol content perfectly. the problem is I am getting a code. (CDA524 FA-CAN - Status eletrical fuel pump 0X335 missing). I removed everything twice back clear all the codes and I don't see this code once I disconnect bm3 harness and run everything again. here is my variable: I have an upgrade LPFP https://burgertuning.com/collections...walbro-upgrade I don't get any code on that alone. but wondering if the combination of the upgraded Pump and bm3 is consuming too much power? Anyone can help here? |
08-03-2023, 01:00 PM | #33 | |
Rep 57
08-04-2023, 11:10 AM | #34 | |
@_sunbish
294
Rep 612
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
08-07-2023, 10:34 PM | #35 |
Rep 57
08-10-2023, 12:58 PM | #36 |
@_sunbish
294
Rep 612
BM3 revised their harness to be like the B58 version. It now plugs into the module behind the passenger side kick panel. Too many people were having issues with the original one with that plugged into the EKPM.
Tags |
bm3, bootmod3, ethanol, flex fuel |
