04-15-2020, 09:27 AM | #23 |
Rep 699
I've flashed my vehicle with ECUTEK maybe 14 or 15 times. If the battery is at a full state of charge you don't need an external power supply, or at least that's been my experience. If my battery tender is in a float stage I know that the battery is fully charged. The whole flash process only takes a few minutes. I can't imagine that it draws much current.
04-15-2020, 11:04 AM | #24 | |
Rep 1,466
There are parts of the flash process, even for a tune, which do draw a lot from the battery / PSU. I'm not sure exactly how much, but I wouldn't say it doesn't draw much current. By the way, another useful tip... if you happen to shut the trunk with the battery disconnected, the way to get it open again is to connect a 12v PSU (or jump leads from another car) to the front 12v and GND terminals under the hood. This will fully power up the car and allow all functions to work, including the trunk button and latch. You wouldn't want to start the car from a PSU I doubt! You probably wouldn't want to start the car at all - I've no idea what would happen if you did that and then disconnected!
2018 ///M2 LCI, LBB, 6MT...
///Monika186.50 |
04-15-2020, 02:27 PM | #25 | |
Rep 278
As always, good stuff. It's definitely a laptop so we're good and thank you for confirming the external enet cable support (you never know). I know that we keep a BMW battery charger on it pretty much anytime it sits for long periods of time or whenever we flash it (something like 20 seconds or so). I can't imagine needing to update the ECU outside of MHD. I'd imagine the amount of stress in hoping the update finishes properly. We'll just stick to diagnostics.
04-15-2020, 02:57 PM | #26 |
Rep 699
04-15-2020, 03:39 PM | #27 | |
Rep 7,543
Oh and yeah you won't really need a charger for mhd flashes, it's way too fast now with the F series wifi adapter.
04-19-2020, 01:15 PM | #29 |
Rep 278
OK, laptop is here (Win10) and I had no issues whatsoever loading ISTA+ 4.10.15 using the instructions provided. Using an external USB (3.0) gbit adapter, I'm connecting to the MHD OBD plug. Ignition on, Read Vehicle data > ID without vehicle test returns:
Code:
Device ID: VIN Type: ENET VIN: VIN Connection: 192.168.16.103 State: Free EDIABAS.ini (Rheingold Folder): Interface = REMOTE OBD.ini: Port = 1 EDIABAS.ini (EDIABAS folder): Interface = ENET (also tried STD:OBD) And the settings in ISTA > Vehicle Interface were left as-is. Although I did try EDIABAS default settings. Ive seen various posts and YT videos saying common issues are Port/COM settings but I have nothing like that in my Device Manager. I do see that my enet adapter is on port 13 but that config change didn't help. I'm a bit stuck at the moment and have tried a few permutations based on searches but nothing prevails so I'm hoping you guys have some tips you can share. |
04-19-2020, 02:15 PM | #30 | |
Rep 7,543
04-19-2020, 04:07 PM | #31 |
Rep 278
04-19-2020, 04:13 PM | #32 | |
Rep 7,543
Try this: But try setting it to ENET.
///Monika186.50 |
04-19-2020, 04:17 PM | #33 |
Rep 1,466
I can’t answer specifically about the MHD dongle, but the F Series cars have Ethernet actually in the OBD port natively, no active converter is necessary. The easiest thing for you to do, is to make up a cable. There are plenty of pin out diagrams on line. The only parts you’ll need are a resistor, Ethernet cable and an obd plug. Or... you could just buy one ready made, they used to be easily available on Amazon / eBay.
///Monika186.50 |
04-19-2020, 04:48 PM | #35 | |
Rep 7,543
There are also a few benefits to using the MHD adapter + ethernet cable over an enet cable that is purchased from ebay: 1) You can use any length of ethernet cable you want, I've had issues in the past with the enet cables from China and using ethernet extensions. 2) My mhd adapter allows me to use any ethernet cable, whereas my enet cable comes with a really thick connector boot. This is a problem especially on a macbook pro where the ethenet jack is really deep and the rubber boot on my enet cable prevents the cable from clicking in forcing me to cut the rubber boot. 3) The connection seems more stable on my mhd adapter, not sure if it is my crappy chinese cable from aliexpress, but I have tried a few enet cables now and it is not as good as the mhd adapter. It is not bad to the point where it will not connect reliably per say, but it is not as good.
///Monika186.50 |
04-19-2020, 06:57 PM | #36 |
Rep 278
I'm thinking my installation may be boinked (somewhere) at this point. I'm going to clean and re-do the install. The ini files look fine and everything I've read looks like I'm configured correctly. Last confirmation was the EDIABAS configurator which matched my settings. I even made sure that I had the latest drivers (USB ethernet) too and it must be working to at least read the VIN off the car .. So much to learn.
04-19-2020, 07:27 PM | #37 | |
Rep 7,543
04-20-2020, 09:15 AM | #38 |
Rep 278
Great news. Installed using a secondary source (possibly latest ISTA) that included a self-installer (nice). This worked out perfectly. Now I can communicate with the car using the USB enet adapter, MHD and a long Cat6 cable.
I read all the fault codes and verified that the system doesn't suspect an engine tune (nice). Can't really run a procedure (test) on the valvetronic because of stored fault code (P10E2; 135808). Although the info shows it's at 179 degree angle. I can see why you requested I record a video, the issue is (now becoming) intermittent but does still happen after a period of time. I was able to record a video before opening the drivers door, I just need to edit off the VIN and post it. Also discovered why the windows aren't rolling up/down upon opening/closing the door. Need to run a relearn on those. Only other error conditions were associated with the steering wheel heater (we have the performance wheel). UI is very intuitive. Unfortunately I have to run into the office for a few hours today. I'm curious if there is anything else I should 'check' before turning over the vehicle to the dealership. Last edited by ///Monika; 04-20-2020 at 10:31 AM.. Reason: Clarity |
04-20-2020, 02:19 PM | #39 | |
Rep 7,543
Ista wouldn't tell you if you had a tune if the hidden "ghost codes" that are suspected to exist do exist. Nope nothing else I have in mind for you to check, good luck!
///Monika186.50 |
04-20-2020, 03:39 PM | #40 | |
Rep 1,466
I was shocked when I got my car back from service a few months back and a whole list of error codes from about 6 months earlier when I was developing a meth fail safe (MAP Sensor codes) showed up... They didn't comment on them at all, but there is a lot of information that BMW gets that might not be obvious to someone with an OBD checker or even ISTA+.
04-20-2020, 03:44 PM | #41 | |
Rep 7,543
///Monika186.50 |
04-21-2020, 08:26 AM | #42 |
Rep 278
OK, so let me see if I'm interpreting this correctly. The car throws a code, you clear the code but the key is a secondary source of record (that's clever). Can you just take the secondary key which wasn't used (at time of code) to start/drive the car and use that when you go to the dealer? Or do the keys somehow sync (proximity) or is the car passing the codes to the keys every chance it gets ?
04-21-2020, 02:10 PM | #44 | |
Rep 7,543
///Monika186.50 |
