04-05-2019, 04:02 PM | #23 | |
Chuggin' Along
333
Rep 588
I'll try to gt a video for you soon. I don't have any video equipment though. Trying to drive 6 speed and film with my phone won't work. |
04-06-2019, 01:27 PM | #24 |
Chuggin' Along
333
Rep 588
So, we had to run the boost back down. My ER intercooler can't keep up with the heat on repeated runs.
You might think that made me sad. Not at all! The car is retarded fast. Turning traction control off would be a death wish. Here's a google vid (that really sucks, but all I could do on my own) of the traction control coming on in 4th gear. https://photos.app.goo.gl/pwDhNfbRMPbXJbRQ8 |
04-06-2019, 02:06 PM | #25 |
Chuggin' Along
333
Rep 588
I'd appreciate it you guy take a look at my logs:
https://datazap.me/u/switlikbob/ I'm looking for the specific logs that show my intercooler not keeping up. I looked at a few, but I really don't have time right now to examine all of them (diaper changes)... |
04-06-2019, 04:05 PM | #26 | |
Rep 7,537
In another log you see IAT's at 64*F jump to 70*F at the end of the log so a 6*F jump which isn't too bad, but it depends on ambient of course which can cause IAT's to jump alot more on a hot day or heavy track use. Another log was really inconsistent so not much interpretation can be done on that, and another log had you at 90*F plus but not too much IAT gains so it could be because the logs were too short, but an ambient temp would be nice here as well. On the final log with a longer run and multiple shifts you had IATs from 72*F to 97*F which is a 25*F jump which is quite a bit, so if ambient temps were high this could be alot more dramatic. This was the run where I thought the ER intercooler imo not being able to keep the temps under control as the run progressed. On some other extremely intercoolers I see IAT's staying really steady or gaining maybe a couple of degrees or even dropping. But the PS2 at 20PSI + generates really hot IATs so it is to be expected. I also noticed some timing pulls being done on all 6 of the cylinders near the end of the logs which means you could have had some knocking as IAT's went past 90*F. This is just my quick overview to view IAT's, so if I made any misinterpretations then I apologize ahead of time.
04-07-2019, 12:26 AM | #27 |
Rep 390
That's unfortunate, what would be the next best intercooler to try out?
I was always under the impression that CSF, VRSF Race and ER were essentially on par. You wouldn't perhaps consider chemical cooling? |
04-07-2019, 10:02 AM | #28 | ||
Chuggin' Along
333
Rep 588
I am going to reach out to some folks and see if we can work on creating and air/water cooling system like is used on the S55. The way I see it, the ECU has the leads to control the S55 unit. Only issue is the adaptation of the dual inlets to a single. I'm sure any competent aftermarket manufacturer can create something to do the job right. In the mean time, I'm going to enjoy the hell out of the car, because it's an absolute blast to drive. |
04-07-2019, 03:54 PM | #29 | ||
Rep 7,537
Overall for street driving it isn't too bad, and I think you'll be ok drag racing too. But for the track I think you should look at a more effective intercooler, because PS2 runs really hot at 20psi+. Quote:
Raymondo123467.50 |
04-07-2019, 04:55 PM | #31 | |
Rep 7,537
1) His name is JRturboAWD and he is the first person that I am aware of making it fit on the E series N55 135i.https://www.n54tech.com/forums/showthread.php?t=50300 2)This guy has done it on the n54 https://*********************/boards...et-build.3516/ Both guys I believe are engineers so they were able to fabricate required parts quite easily.
04-07-2019, 05:12 PM | #33 |
Rep 7,537
NP! Just becareful with the intercooler part, aparently the S55 oem intercooler leaks so if I were you I would look at an aftermarket solution.
04-07-2019, 05:30 PM | #35 |
Rep 7,537
Most the existing S55 stuff should be bolt ons, but there needs to be additional supporting stuff to bridge the gap between S55 and N55.
04-07-2019, 09:00 PM | #37 |
Rep 2,577
I reviewed most of your logs.
Things are exactly as I anticipated. Trading some 3 degrees of ignition is basically how it's possible for you to run at 21psi on pump gas and under extremely cool 60+F of IAT (ambient should be 30+F or so, freezing cold). The following log of yours shows the fragility and incapability of your hardware for the aggression of the map. Under 90F of IAT, to say the engine runs no good is a huge understatement. You keep doing such pulls, your engine will physically break. https://datazap.me/u/switlikbob/log-...17-18-19-20-21 https://datazap.me/u/switlikbob/log-...17-18-19-20-21 This map of yours is only for dyno and drag under perfect ambient condition. And I would seriously doubt it'd break 450 on dynojet even on a freezing cold day without octane booster. Because I've seen many enough - with N55 EWG hybrid STG2 turbo, the 450whp normally comes with 19-20psi (more importantly high filling %) and maxed out timing. I would dial back, considerably. Bigger IC or W2A IC will not address the temp issue at all. If anything, they would hold up temp a little bit longer before eventually heat soaked. The real issue is that the hybrid turbo is working way out of its efficiency zone at 20+psi. If you read compressor map, there is a flow (lbs/min) point, passing which each pounds of boost come with significantly more heat. We normally call 75+% area the high efficiency zone. Meaning 75% of energy produced is for pressurizing the air and 25% for making the heat. When pushed above 20psi, N55 hybrid is absolutely way below efficiency threshold. You can chemically cool it down for a couple runs, but everything heat soaks quickly. The point is, working with an overloaded turbo, however much heat the bigger IC or W2A IC can absorb, if it doesn't cool itself quick enough, it's not sustainable. And you can't just blame the cooling. I know everyone can have different acceptance criteria. But normally engine should be running excellent up to 90F of IAT, and see acceptable correction up to 120F. For sure above 120, there will be noticeable timing pull, but nothing like in your case where it's all over the place down to the ground even at just 90F. If you pull out knock channel I'm sure it's super knocking already. I don't even want to start on the octane issue. PR coils maybe improve a bit, but certainly not by much according to your log. If anything, the extremely low ambient temp should take all the credit. If you want to run good at 80+F, dual CM10 meth injection is an absolute requirement, which BTW isn't reliable at all with heavy use. Apologies for these harsh comments ruining the party. This thread of yours can and may have already misled many to wrong understanding of N55 hybrid turbo capability on PUMP GAS, like many threads before you.
Lemania 2320
4
04-07-2019, 10:41 PM | #38 |
Rep 7,537
I just looked at the original post it's on a Dyno com, those things read higher than Dyno jets do so likely it's not 500whp.
04-08-2019, 09:32 AM | #39 | |
Chuggin' Along
333
Rep 588
I am going to get out this weekend and get some new street logs. I think they will show better IAT's, but I have no doubt that my IC is not capable. Let's see what the next set of logs show. |
nothingman522.00 |
04-11-2019, 11:39 AM | #40 |
Chuggin' Along
333
Rep 588
I logged a bunch yesterday. You can clearly see the new logs dated yesterday.
I feel like the logs show my car behaving nicely with th eboost turned down. IAT's never really get more than 15 degrees over ambient (60F) when the car is moving. Here's an example: https://datazap.me/u/switlikbob/4-10...data=3-7-15-25 @SeanWRT , can you look and share your thoughts? |
04-11-2019, 12:22 PM | #41 | |
Not Mids
64
Rep 85
2013 135i N55 - FBO
SOLD 2020 X3 Competition - Alpine white, dp + stage 2 SOLD 2018 LBB M2 FBO, Pure Stage 2 turbo |
04-11-2019, 12:52 PM | #42 | |
Chuggin' Along
333
Rep 588
The car is an absolute beast. It pulls so hard to redline, I don't know when it's time to shift (6MT) anymore. Seriously, I'm scared to turn traction control off because of how snappy the rear end behaves now. |
04-12-2019, 10:25 AM | #43 | |
Rep 1,835
Drives: 2020 X4M CS
To the person that commented about torque falling off at 5k...Thats actually perfect. Torque cant be linear, its a measure of work, as hp is a measure of power over time...you can calculate one knowing the other and the rpm of the hp or tq you want to calculate. And with that hpfp and slightly bigger turbo running 22psi, there should be no taper of boost...BC the turbo/fmic in the M2 heats so fast and direct injection mortors like timing as much or more than boost...Some tuners believe you get a better curve and more power across the upper rev range by lowering boost slightly (as it really heats) and this allows for a leaner LAMBDA and extra timing advance which make more power than the boost thats been lowered...
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
04-12-2019, 01:17 PM | #44 | |
Rep 7,537
