01-27-2020, 08:01 PM | #23 | |
757
Rep 2,149
EDIT: Ok. I see what you're talking about now. The image you posted a while up that says "When installing a new vehicle battery, the battery must be registered" I was commenting on you saying used batteries must be registered and that that is harmful. The discrepancy is only in that statement. |
01-27-2020, 08:21 PM | #24 | |
Luxury at the redline :)
9108
Rep 7,563
When you run the ISTA+ program, you can access the current battery's profile, a histogram of charge cycle, the prior registration date, mileage, projected life, ect. Registration just means your telling the vehicle that their is a new battery and it should forget everything it knows about the current battery profile and adapt to a new one. That's it, it's not that complicated. My friend had bought an OEM battery, he never registered it, it died within a year. BMW refused to replace it under the warranty because there was no hard data within the vehicle's computer to show the last date of registration. If you don't register the battery, as prescribed by BMW, on top of it dying prematurely, the warranty would not be valid. |
01-27-2020, 08:24 PM | #25 | |
757
Rep 2,149
01-27-2020, 08:34 PM | #26 | |
9108
Rep 7,563
But you "should" register the new battery or like I mention several times already; it will cause the battery to die prematurely or BMW will invalidate the battery's warranty, if they can't verify the last time the battery they sold you was not registered properly via the vehicle's computer. |
01-28-2020, 09:25 AM | #27 |
Rep 2,505
I read that if someone wants to put a Lithium battery from the M3/M4 into their M2c that the IBS cable needs to be disconnected. Will this throw a check engine light on the dash?
I'm sure this could be retrofitted to work 100% with the IBS cable attached. The entire engine including alternator is the same on the M3 and M2c. I wonder what else is different between the m2c and m3/M4.
01-28-2020, 05:35 PM | #28 |
Rep 1,263
My Anti Gravity Battery just arrived. Will be installing it tomorrow or Thur latest. Will take some pics...
Its lighttttttt!!!!!!!!!!!!
Anthony1s756.50 |
01-28-2020, 05:48 PM | #29 | |
9108
Rep 7,563
So I guess the only work-around if you choose to use the M4's battery is bypassing the IBS, which can be hazardous during a crash if the airbags deploy, since the IBS setup works in conjunction with the collision system. Do you mind sharing your source on this bypass suggestion. Thanx. |
01-29-2020, 09:47 PM | #30 |
757
Rep 2,149
I don't know if this is a mistake or not, I imagine it is, but these lightweight batteries are listed from $178 to $240 depending on model.
https://www.hpashop.com/Braille-Ligh...ht-battery.htm |
01-31-2020, 11:13 AM | #31 |
Rep 1,263
I installed the Anti Gravity drop in 40Ah=1500Ca(cranking amps)
https://antigravitybatteries.com/pro...tive/ag-h7-rs/ As others have mentioned the M2 software does not allow any other battery to be registered other than OEM 80ah. I'm not worried about it. The Antigravity drop in is working great and came with the Battery Tracker Bluetooth kit. It allows me to monitor my battery from my phone. Its simple and effective tech.. https://antigravitybatteries.com/pro...acker-lithium/ I also have a Lithium trickle charger that I'll use when the cars not being driven. It weighs 15.6 lbs vs 58.7 lbs for the OEM Lead Acid. 43 lbs+ rear seat delete =~100 lbs of easy weight loss. I'll also go with the QRT seats in a few years as well. Saving another 100 lbs. The Essex BBK along with 18" rims will save even more weight. Next step is the Essex front BBK, 18 rims with 275/35 sq setup running the new Goodyear Eagle F1 Supercar 3R's. or 285/30 BFG R1's. Along with TC Kline's D/A Koni setup.
09-12-2021, 04:01 PM | #33 |
Rep 2,882
Do they have any problems tolerating heat? For interest I put a sensor in my battery well, and on track was getting temps up above 140 (ambient about 89-85, and some longer sessions, 45min plus).
09-13-2021, 12:30 PM | #34 |
8312
Rep 18,880
Drives: BMW
No problems. Most times the battery is much cooler inside the vehicle than if were installed under the hood.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
Maynard3861.50 |
02-15-2022, 02:00 AM | #35 | |
Rep 660
02-15-2022, 08:28 AM | #36 |
Rep 1,263
I have the 40AH one. The battery itself has built in adaption to compensate for charging. I tried to have it "registered" but the options available did not match the new battery. I've had it in the car for over 30K miles now. no problems
02-15-2022, 10:49 PM | #37 |
Rep 660
Awesome, great to hear, thanks! I might split the difference and get 60AH and just register it as 80AH - from reading this thread, that is the lowest it'll go for the M2 (which I assume you did? Or did you not register it at all?)
02-20-2022, 08:28 AM | #38 |
Rep 216
Thanks for the reply, SEAT TIME RULES, useful data point.
Does the M2 software allow configuring "lithium" as a battery chemistry type? Even if it only caters for 80ah, I'd expect that to be substantially better for longevity. I'm concerned that the charging circuit may treat the battery with lead acid AGM charge curves, instead of a more appropriate lithium chemistry charging curve. Battery capacity curves according to voltage is very different between the two chemistries. I'm aware that the alternator output on our cars are digitally controlled, unlike old style alternators that simply targeted a specified voltage at all times and varied amperage according to RPM. Does anyone know of a way to alter the car's programming to utilize different charging chemistries that are available in other BMW lineups? From memory, my '09 N54 135i had options for both lithium and lead acid. |
02-23-2022, 09:33 PM | #39 | |
Rep 660
BTW SEAT TIME RULES I checked in bimmercode, and it allows me to select these values: 20 Ah 40 Ah AGM 46 Ah 55 Ah 70 Ah 70 Ah AGM 80 Ah 80 Ah AGM 90 Ah 90 Ah AGM 105 Ah AGM So it does seem we can go below 90 AH AGM (stock value)? Last edited by eeyang92; 02-24-2022 at 12:22 AM.. |
FTP2034.00 |
02-23-2022, 10:17 PM | #40 | |
Rep 87
Has the OE battery weight been confirmed?
The OE F80 Li battery might be a decent option, assuming it fits the F87. Part $: 61.21.9.312.759 Specs: 12V 69Ah 770A/860CCA Weight: 29.85lbs |
02-24-2022, 09:17 AM | #41 | |
Rep 1,263
Be careful, I remember adjusting my Battery level using Bimmercode. I very quickly got some weird codes. Went back to OEM and all is well.
02-24-2022, 09:22 AM | #42 | |
Rep 1,263
My M2 sits in the garage for 7-10 days at a time and the battery still has 75% charge. I live North of Boston an my garage can get well below freezing ...You will be fine with the 60, or 80ah.
FTP2034.00 |
02-24-2022, 03:01 PM | #43 |
Rep 660
I see, thanks for the heads up. I'll give it a shot, but otherwise leave it at OEM if it doesn't work out. Seems like you haven't had any issues so I think it should be fairly minor.
02-25-2022, 02:07 AM | #44 | ||
Rep 195
