M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > Correcting LCI cluster scratches
      09-10-2020, 03:40 PM   #23
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Originally Posted by Matt Devo View Post
why the hell isn't there a plastic cover on this like the pre-LCI cluster?
Probably to reduce glare. That was a big complaint with the older cars.
That being said, they definitely should've made the matte finish on the LCI gauges more durable.
      10-18-2020, 06:49 AM   #24
andest2003
Drives: bmw x2
remove scratches
Originally Posted by acl26 View Post
Used 1 to clean off but really only 2 removes the scratches.
Under most lighting the scratches are gone but in heavy glare situations you will notice that the matte finish is gone from where the buffing is done.
However, I rather have that then the scratches in your face most of the time.
what did you use to remove scratches and then polish. I have fine scratches on my x2 clocks like yours and doing my head in
      10-26-2020, 06:12 PM   #25
Saintjah
Drives: M2C
Id love to know how you removed the scratches... I used a new, super soft microfiber cloth to try and remove some dust and it gave me a fucking HUGE gash like wolveriene fingered that cunt..... so pissed.
      10-26-2020, 07:42 PM   #26
acl26
Drives: 2018 BMW M2
Novus plastic polish kit and a lens cleaning cloth then another cloth to remove left over polish haze. Didnt need to use Novus number 3.
gphung193.50
      11-06-2020, 04:59 PM   #27
3t3p
New Zealand
455
I feel we are confusing subjective softness with actual hardness.
A MF towel feels soft but how hard is the polymer it is made of? If it is harder than the butter they use on the screen it will scratch.
So IF you have to touch it with a cloth the question is what is actually the softest material from a hardness scale point of view?
      11-07-2020, 05:10 PM   #28
gphung
194
Drives: 2018 M2 LBB - 6MT
2018 BMW M2  [0.00]
Any regrets knowing it's a bit different now?
      11-07-2020, 10:34 PM   #29
acl26
Drives: 2018 BMW M2
Def worth it for me. Look at my pics for the difference in regular lighting b4 and after. I rather fix scratches showing in regular lighting n sacrifice the matte coating. In heavy glare situations the matte surface barely does anything anyways.
gphung193.50
      12-22-2021, 02:43 AM   #30
Bonino101
9
Anyone tried this? https://nperform.com/products/bmw-f2...40647578484889
My cluster is badly scratched and I’m thinking of trying this to see if it makes the scratches less visible
      12-22-2021, 09:58 AM   #31
WedgeSalad
Drives: 2018 F87 M2
Could we apply a matte ppf?
      12-22-2021, 02:07 PM   #32
ROASTM
Drives: '20 M2C; '06 M3; '07 JKU
Also curious if anyone has tried this!
      12-22-2021, 02:15 PM   #33
SebsM2
SebsM2's Avatar
654
Drives: 2017 LBB M2
If anybody gives up on fixing the scratches, dm me. I have a brand new m2c cluster for sale
Instagram: SebsM2
Build thread: A Tastefully Modded FBO M2
ROASTM163.50
      12-22-2021, 03:51 PM   #34
Bonino101
9
I’ve just put an order through on the N Perform screen protector. Will report back once I install it on the car
      02-13-2022, 10:23 AM   #35
DadVibes
DadVibes's Avatar
1253
Drives: F87 M2 CS
It sounds like removing the cluster and using Novus 1 & 2 seems to be the solution to removing the micro scratches, correct?
I’m aware that this will remove the matte coating. However, the area over my Speedo and Tac are so caked with micro scratches from the dealer that I can barely see through it when there’s sun glare anyway. It drives me nuts.
      02-13-2022, 11:06 AM   #36
gphung
194
2018 BMW M2  [0.00]
Yeah acl26 did it and shared pics. Not sure if anyone else has used Novus though.
      02-13-2022, 03:03 PM   #37
DadVibes
DadVibes's Avatar
1253
Drives: F87 M2 CS
His results do look great. I'm probably going to end up going for it, myself. But I'd love to hear if anyone else has taken the plunge and can share their thoughts on sun glare after removing the scratched coating.
If not, I'll probably be the next guinea pig. But I'm still a bit nervous, despite the scratches staring me in the face, every time I drive.
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S
      02-13-2022, 07:57 PM   #38
SebsM2
SebsM2's Avatar
654
Drives: 2017 LBB M2
I have an extra laying around.. I'll be a Guinea pig!
Instagram: SebsM2
chris7197393.50
      02-14-2022, 08:53 AM   #39
DadVibes
DadVibes's Avatar
1253
Drives: F87 M2 CS
Amazing! Very curious to hear your results. If the glare isn't notably worse in direct sun light, this really may be the best solution to the issue.
      03-20-2022, 10:39 PM   #40
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
328
Drives: 2018 BMW M2 LCI
Those protective films/layer meant for a screen that are cut to fit.... can they be used for these? Just wondering.
These scratches look f*gly. I understand the frustration. Would drive me insane.
      05-03-2022, 02:27 PM   #41
BallHog5873
BallHog5873's Avatar
178
Drives: 997.2 Manual, 2016 328D Wagon
anyone tried this yet?
      05-09-2022, 08:51 PM   #42
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
328
if the plastic shield can be removed for polishing, can't it be replaced w/ a new part?
Is it as easy as removing the 2 top screws and pulling out??
I'd answer my question. looks like cluster's a whole unit according to real OEM.
      05-14-2022, 12:22 PM   #43
Saintjah
Drives: M2C
Just ordered the N screen protector soooo will post results once it arrives and I have it installed.
chris7197393.50
      05-14-2022, 01:00 PM   #44
KPM2C
Drives: BMW M2 Competitition
Do you have an M2 or M2C?
And planning to first remove scratches?
