01-09-2018, 10:00 PM | #23 | |
Rep 752
Really interested with an ~E20-E30 mix. Thought of putting in some 100 octane, $10/gallon lol
FSociety3816.50 |
01-19-2018, 02:12 PM | #25 |
Meh
929
Rep 781
Drives: M3CS & Cayman S
got an updated tune today pushing the ots map up by 0.5psi. the good news is i broke 400whp. the bad news is it crashes hard up top. eas thinks i need to reduce the spark plug gap. once i get back to a computer, I'll study the logs and see what happened.
http://www.bootmod3.net/log?id=5a624307d10b430edd6c787d http://www.bootmod3.net/log?id=5a62413ed10b430edd6c7874 http://www.bootmod3.net/log?id=5a623f92d10b430edd6c7872 |
01-19-2018, 04:10 PM | #26 | |
Rep 752
01-19-2018, 04:44 PM | #27 |
Rep 2,829
Oh yes!!!
Need to tweek something... Drive around with the tune for a week and see how it does with the tune and try another Dyno
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
01-20-2018, 12:42 AM | #28 | |
589
Rep 897
Unfortunately Allen's logs are all corrupted
01-20-2018, 02:19 AM | #29 |
IG @bmwF9xG80
3817
Rep 7,595
Wow! Strong numbers but I definitely see the data got stuck somewhere
You might need to - update OBD Agent version if you're WiFi box - download latest OBD Agent if using laptop and browser should bring you into 0.9.39
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
01-20-2018, 02:40 AM | #30 |
Rep 752
01-20-2018, 07:40 AM | #31 |
Meh
929
Rep 781
I'll try getting cleaner logs today. eas took the logs while it was on the Dyno, and I'm not sure if obd agent was updated. i have my own cable now, so I'll try again later
01-21-2018, 07:28 PM | #33 |
Rep 2,577
UltraMagic, were you getting 355whp as baseline with catback only on 91OCT? How is baseline ambient condition compared to the 400whp run?
A 45-50whp delta from a FBO+91OCT on flash is already impressive. Log your newest map on 3rd gear from 1500-7000. Should explain everything.
Lemania 2320
01-21-2018, 07:39 PM | #34 | |
Meh
929
Rep 781
FSociety3816.50 |
01-22-2018, 02:39 PM | #35 |
IG @bmwF9xG80
3817
Rep 7,595
Even on dyno
60-130 6.5s X4M
01-24-2018, 08:07 PM | #36 |
Meh
929
Rep 781
latest logs
http://www.bootmod3.net/log?id=5a69323ed10b434f82532cc0 http://www.bootmod3.net/log?id=5a6930e7d10b434f82532cbf why is cyl 2 missing? |
NO_USER_537.50 |
01-24-2018, 08:22 PM | #37 | |
IG @bmwF9xG80
3817
Rep 7,595
60-130 6.5s X4M
NO_USER_537.50 |
01-24-2018, 08:54 PM | #38 |
Meh
929
Rep 781
01-24-2018, 09:29 PM | #40 | |
Rep 2,577
Power wise, interesting fact: 2k5~4k5: same as mine (except for waste gate tuning) 4k5~6k: same as Tehboost 6k+: weaker than Tehboost but you should have matched him (provided fueling is there) if it were not for the nannies that I clearly see Dzenan put in all his OTS V3. I won't go more specific on that here. One more thing if you don't mind I speaking right in your face. AA intercooler performs poorly. Please upgrade.
Lemania 2320
NO_USER_537.50 |
01-24-2018, 09:40 PM | #41 | |
Rep 752
01-24-2018, 09:57 PM | #42 | ||
Meh
929
Rep 781
05-20-2018, 11:08 PM | #43 |
Rep 1,466
I realise that this thread is now about 4 months old, but I just posted in another thread about the timing issues I'm seeing with the BM3 Stage 2 91 Octane OTS map, and when comparing my logs to UltraMagneticAL's first set of logs in this thread, they look almost identical!
The latest logs posted by UltraMagneticAL however are much cleaner, AND they run the 93 Octane higher boost target of 17.22! My question to UltraMagneticAL is simple... what did you do to clean up your timing (if anything) in the later logs? Were you still using straight 91 pump gas, or are those logs after adding Race Gas, E85 or octane booster? Some charts to illustrate my point: My car with a 3:1 blend of 91 pump gas and Sunoco SS100 Race Gas (93.25 effective AKI), running v5.3 91 Octane Stage 2 OTS map (peak boost target of 15.77psi): UltraMagneticAL's car with I believe 91 pump gas running v3 91 Octane Stage 2 OTS map (peak boost target of 15.77psi): UltraMagneticAL's car with unknown gas, running an 'updated' tune (peak boost target of 17.22psi!). I suspect this log was taken in Sport mode rather than DSC Off by the way; the Throttle Angle dips are very typical of DSC intervention: I found that mixing in the Sunoco SS100 reduced my knock detected events, but hasn't helped the timing pull. Whatever either UltraMagneticAL or proTUNING Freaks has done has obviously worked to fix the timing pull.
2018 ///M2 LCI, LBB, 6MT...
05-21-2018, 11:34 AM | #44 | |
Meh
929
Rep 781
just pump gas from shell or 76. except for the dyno session where we put torco in due to temp, everything was straight pump 91 gas. |
