Originally Posted by Anthony1s
Originally Posted by Chopper731
You have to hit the off button twice to put it in park from neutral like you said. Just pressing the off button once only puts the car in accessory mode and park from drive or reverse which then goes into the off mode once you lock the doors with fob. If you are in neutral and only press the off button once, it goes into accessory mode but won’t go into the off mode and subsequently park with the my fob because it won’t allow you to lock the doors while in neutral.
At least that is what I’ve been able to make of the system.
ahha. the difference with mine is that it's coded to turn off accessory mode when the doors are open. That explains why I wasn't able to put the car in neutral and get out.
Oh yeah be too, I guess that's why I also see this behavior.
