05-23-2022, 03:05 AM | #23 |
Rep 244
I've done a "plug-and-play" retrofit by ordering part number: 51162471107.
All works well, but the car / ISTA is now complaining about the following: - D90D25 - Interior rear-view mirror: incorrect variant fitted - D90D2d - Garage door opener: Unexpected LIN-slave. The car didn't come with Homelink/garage door opener from factory, which may explain the error. Any idea how I can code this in? As mentioned, everything works as intended with the exception of that error code. EDIT: I've found a potential solution: https://f30.bimmerpost.com/forums/sh...6&postcount=17 Last edited by squixs; 05-23-2022 at 03:11 AM.. |
05-24-2022, 04:15 AM | #24 | |
Rep 129
Solution in this post: https://f87.bimmerpost.com/forums/sh...8&postcount=46 |
05-31-2022, 09:19 AM | #25 |
Rep 104
To recap....I purchased 51169459440 from the G30, F90 M5, G31, G32, G11, G12 on ebay used for $150 shipped.
I received my mirror in the mail the other day and swapped it out this weekend. worked out well and no issues. Though the 4-pin connector and wiring is the same between these two mirrors, the cast aluminum mounting bracket is different, necessitating the change of the base use the trim around the mirror and forward camera....no way around this. many photos attached, but hopefully this gives a bit of perspective and measurements. I especially like the "U" alarm indicator...doesnt seem to project as brightly. Before the dome always seemed to draw your eyes to the car in parking lots at night...'why is that car blinking?!'...vs now you dont notice it until you notice the car first. The shape is better for my viewing....lower viewing area is wider. Also noticed that the auto dimming seems to transition faster as well. The Homelink buttons are also 'one touch' instead of the original 'press and hold'...but that my be operator error more than anything. Only down side is the compass printout no longer is on the mirror. not an issue for me, but may be a desire for others. Of note, you will have to reprogram the Homelink buttons....they transition with the mirror...an extra step that is not a huge issue. This part number DOES NOT require coding.... ~Ryan Last edited by rcodea; 05-31-2022 at 09:26 AM.. |
11-04-2022, 03:07 AM | #26 | ||
Petrol Head
139
Rep 164
Drives: Current: F87 M2C, JLU Wrangler
To unpin the wires from the tabs of the new G series mirror, I had to damage the wire tabs to find space to work through it. Not a big hustle.. don't need them anyways
Lagom...
"not too little, not too much" |
BMW DIY Guy3120.00 |
05-13-2024, 12:05 PM | #27 | |
Rep 19
I've been looking for a used 51169476753 rearview mirror for a while now and I finally gave up and decided to order a new mirror from one of the vendors. For some odd reason, they were extra attentive with matching VIN so I just searched for a used G20 M340i VIN from CarGuru and gave it to them. This morning, I got a call from the shop and they asked me if I'm sure I want to place an order since I provided the wrong VIN. Obviously I wasn't sure lol, because some of the people on the forum were getting 51169476754 or 51162471107 so I told them to give me until 11 am. I decided to check eBay one more time, hoping I get a hit and what do you know? Lo and behold, 51169476753 from X5 got listed for $125! Definitely snagged it ASAP and I can't wait to install it on my M2C. One quick question: when you installed yours, did everything work properly? Including road sign detection features? My 2020 M2C has premium package.
F87 M2 Competition
Driver: @readyeddie Machine: @516.m2c |
