BIMMERPOST Universal Forums > Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) > Jack For Lowered Cars
      04-25-2024, 08:11 PM   #23
disintegrator66
disintegrator66's Avatar
Drives: '18 340i M-Sport 6MT THP MPPSK
Originally Posted by ipilcher View Post
But once you lift a corner of the car up with the scissor jack, how are you supposed to get it onto a jack stand?
You're looking to avoid a floor jack and there aren't many options. While a scissor jack isn't quite as stable as a jack stand, its arguably more stable than relying on a hydraulic floor jack. Again, not MY first choice, but an option if you don't want/can't use a floor jack/jack stand combo. I use ETA Manufacturing jack stands which need a floor jack...
noemon90.50
      04-26-2024, 12:48 PM   #24
s_ribs
Drives: '15 535i xDrive M-Sport, E30
I've been watching the long reach HF jack for a while now and it's finally on sale for $199 ($40 savings). If you are considering one, I'd get it while you can.
      04-26-2024, 02:09 PM   #25
No one
Drives: F21 118i
In my experience it's exactly the opposite. Say, when using a scissor jack I did bother to put a wheel underneath the raised car just in case. No need with the HF floor jack which is rock solid (yet, no getting under the car, of course!). Yes, you should mind the hydraulic jack's condition, but if it works it just does. A scissor jack doesn't feel that stable and it eventually breaks (the BMW one got it's plastic bushing destroyed by the metal screw rod, luckily at the best moment possible though yes, there had been signs of weakness before that happened).
And by the way, a very nice garage you have!
      04-26-2024, 02:20 PM   #26
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2683
Drives: 11' 335is DCT
Agree same experience as well. When I just need to do something quick like swap a wheel or plug a tire, something like that where I won't put myself under the car, I tend to only use my jack and it's pretty stable. I have the jack in the picture.
      04-26-2024, 03:25 PM   #27
disintegrator66
Let me clarify. If you put a gun to my head I’d much rather be working on or underneath a vehicle that’s on a sole scissor jack versus a sole hydraulic jack. This is due to the possibility of a hydraulic floor jack losing its seal and dropping the car by a number of different means. The scissor jack is not going to unscrew itself in any situation. Having said that, I personally wouldn’t use a sole scissor jack or a floor jack to hold my vehicle in place while I’m working on it. No matter what I’m doing I’ll jack it up and place it on the jack stand. I’m too old to get crushed by a car! I’ll leave that for the young kids!! Lol
      05-03-2024, 11:58 AM   #28
s_ribs
FYI - just got an email that there is a new coupon, on sale for $189.99 now. Darn good deal on this.
MoeTE87745.00
      05-03-2024, 05:47 PM   #29
PaleoMan
Drives: BMW M235i
I took the easy way out. I have an old Craftsman low profile jack and I just built a pair of mini ramps with 2"x12" boards. I cut a 30 degree angle on one end, and then nailed a 1" think piece on the other end, to get enough height for the lowered 325iS I owned.
I'd runt he front wheels up on the ramps, jack the front, add stands, then jack the back without any need for ramps for rear wheels (as long as I didn't jack the front up too high).
      05-04-2024, 09:48 AM   #30
to_riffic
to_riffic's Avatar
Drives: rwd
Originally Posted by NWH83 View Post
If you're looking for something to just swap out wheels, check out the Daytona 1.5 ton low profile/low weight (only 36lbs) from harbor freight. (I know HF doesn't have the greatest reputation but the daytona jacks are pretty good, at least in my experience).
https://www.harborfreight.com/15-ton...ump-58811.html
Have this as well. The notch on the frame with the front low profile wheel bar make it super easy to slide under a lowered car. I have a 3 ton CAT and it wouldn't fit under the CS' jack points, but with the Daytona you can remove that jacking point and use the entire flat surface as well, so it cuts another probably 1/2" that can slide under the vehicle. Slide a jackpoint jack stand under there afterwards and you're golden. Kinda expensive when you compare it to the cheaper Pittsburgh ones for sure, but man, it's such a good jack, can't recommend it enough.
~loud noises~
      05-10-2024, 07:27 AM   #31
Autoaddict
Autoaddict's Avatar
Drives: 2008 BMW 328xi Sportwagon, G80
These jack stands are really slick!
      05-10-2024, 02:53 PM   #32
335i54n
Drives: e90 335i, e39 m5
this is a pretty cool tool imo. fyi this small hf jack also fits under front center jack point-msport height (no lip)
https://www.harborfreight.com/automo...ump-64545.html
https://www.amazon.com/AGM-Products-...s%2C193&sr=8-3
      05-10-2024, 03:11 PM   #33
PRINCE THUNDERNIGHT
PRINCE THUNDERNIGHT's Avatar
Drives: 2023 BMW M240i XDrive G42
Car weighs more than 1.5 ton
      05-10-2024, 03:17 PM   #34
chris3g
Drives: 2023 M3 xdrive
you arent lifting the entire weight of the car from a single jack point
      05-10-2024, 03:19 PM   #35
335i54n
^yup, lifted ez no probs (only 1 click on stands though)-1.5 tons is 3307 pounds, e90 total is 3600 ish
      05-10-2024, 07:35 PM   #36
PRINCE THUNDERNIGHT
Oh yeah, duh!
      05-11-2024, 06:14 AM   #37
Autoaddict
Autoaddict's Avatar
I have that jack rod and it’s really good. Highly recommend it.
      05-11-2024, 03:49 PM   #38
yousefnjr
salty cowboys fan
yousefnjr's Avatar
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Originally Posted by 1and1 View Post
Fan of the long reach low profile jack, it's nice to reach the center jack points easily
however, the one I have is neither light nor small....
https://www.harborfreight.com/automo...ack-64781.html
I have one of these in bright Lambo green and it's one of my favorite tools. Heavy as piss and maybe overkill for just wheels, but I love it like a friend. +1000 for the Daytona jacks, I think these ones in particular are clones of and/or made in the same factory as the Snap-ons. I forget the exact story.
she’s home! '22 M4 Comp xDrive
      05-11-2024, 04:39 PM   #39
disintegrator66
Thanks... Money well spent!
tcphoto3558.00
