03-05-2023, 08:37 AM | #23 | |
Rep 557
I do the camber/toe-in adjustment at home when I swap pads. To get both settings marked up my alignment shop first did the -3 setup and let me mark the camber/tie-rods, they then did the -2 setup which I marked up at home. |
03-05-2023, 09:31 PM | #24 | |
Rep 359
So what's the ramification of me driving that far on-3 deg camber? |
03-05-2023, 09:40 PM | #25 |
Rep 435
Drives: F87 M2 DCT, F15 X5
Excess tire wear on the inside shoulder. Increased tramlining. Reduced wet grip.
03-06-2023, 08:37 PM | #26 | |
Rep 557
I'm fortunate that I only have a 27km drive to the track so set up at home & drive there on my A052 track tyres. Next month though I have a 200km drive to track for a club supersprint round so I'll commute all set up for track but swap tyres at the track. |
03-17-2023, 12:25 AM | #28 |
Rep 359
Just had the Vorshlag camber plates installed on the CS.
Now I'm noticing knocking sound on each side at low speed over undulated pavements. Is this normal? |
03-17-2023, 04:36 PM | #29 |
Rep 3,549
No, not normal to get noise with Vorshlag. I'd check to see if the damper shaft nut was tightened enough (Vorshlag says to use an impact to do it).
03-18-2023, 06:10 PM | #30 |
Rep 359
The initial install was not performed by me. So I have no way of checking whether everything was installed correctly.
FaRKle!, your video instructions was invaluable. Wish I had done it myself now. At least I would have no one to blame but myself. Well, I re-tightened everything and it eliminated about 50% of the knocking sound. |
FaRKle!4043.00 |
05-29-2023, 08:49 PM | #32 |
Rep 359
Well, if you really want to know, I had to order another whole new set of Vorshlag camber plates. Then when I was getting the third shop (the best shop) to swap out the damaged plates, they discovered that one of the strut thread was partially striped - likely from the initial shop install. So I would have to replace the strut in pairs, at $1500 each. That's for OEM struts, and they're back-ordered from Germany
As a result, I decided to replace both fr/re shocks with Bilstein B6 EDC dampers which are cheaper and apparently also better than OEM's. I now have 3 dampers in my possession, but the RF strut is on back-order. Once I get the damaged plates swapped out, I will send them back to Vorshlag to have them rebuilt and then I will sell them as used/reconditioned. I will report back once everything's in place. BTW, Vorshlag's tech support has been amazing. |
FaRKle!4043.00 |
05-30-2023, 09:15 AM | #34 | |
Rep 111
bhor holo dor kholo full poem |
05-30-2023, 11:24 AM | #35 | |
Rep 359
05-30-2023, 11:33 AM | #36 |
Rep 4,733
How far did you drive on those with -3 degrees? I'm curious because I'd be driving my car to tracks. I might need to rethink my wheel choice if it requires me to run -3 or more. Or figure out a reliable way to adjust the camber plates once at track. I don't mind bringing a different set of wheels with me.
05-30-2023, 11:55 AM | #37 | |
Rep 3,549
05-30-2023, 03:39 PM | #38 | |
Rep 359
BTW, Bilstein didn't have any parts listing on the B6 for the CS, but many shops list the M3/M4 CS as exact fitment. I hope they're correct. |
05-30-2023, 06:08 PM | #39 | |
Rep 648
Typical shop work to speed up the process. Real Engineers only uses special tools and torque wrench for any assembly job.
Ist der Motor kalt, Gib ihn sechs ein halb.....
05-31-2023, 07:57 AM | #40 |
Rep 648
Info for CS owners.
Camber plates Street BMW M2Competition, M2CS, M3, M4. The Street version adjust up to -3,2 dg. Product will be available on June 14, 2023 SKU 90481-M4 (NEW! Street version with polyurethane bushings. Reduces noise from suspension and tires compared to uniball version. Fits all suspensions). //////////////// Camber plates BMW M2Competition, M2CS, M3 F80, M4 F82 F83 adjustable up to -4 dg. Product will be available on June 14, 2023 SKU 90467-M4 //////////////// Camber plates M2C M2CS M3 M4 Racing Product will be available on June 14, 2023 SKU 90467-TTX
05-31-2023, 08:10 AM | #41 | |
Rep 4,733
05-31-2023, 08:44 AM | #42 | |
Rep 613
Drives: F87 M2 CS
That was the final straw for me. Now I will only take on suspension jobs myself. Making sure everything is replaced/torqued 100% to recommended spec.
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S |
05-31-2023, 11:51 AM | #43 | |
Rep 648
It's only when tracking I need about -3 and I don't mind the job. -3,2 dg (Street), is the max. obtainable unless you get the other available option.
06-01-2023, 09:19 AM | #44 |
Rep 4,733
As a point of info for the Vorschlag plates. I received a reply to my inquiry on using an Impact. Impact setting of 100 ft lbs should be fine. I was concerned because my "pulsed mode" on DeWalt 20v max XR will do the full 600ftlbs in pulsed mode. However, the first stop on the pulse seems to be close to 100 ft lbs as it doesn't reach the wheel lug torque on the first let up. If you keep pushing though it will quickly ramp up the torque. Use short pulses to keep the shaft from spinning to much.
My guess is that this is where potential noise comes from. If you don't tighten quickly enough your just spinning the shaft and may not be tightening enough.. They also mentioned using blue loctight on an install article. |
